want to go bigger! - JeepForum.com
post #1 of 14 Old 06-24-2012, 05:16 PM Thread Starter
TBULL96XJ
want to go bigger!
i have a 3 in rough country lift on my cherokee right now and want to go bigger.. was thinking about getting shackles and spacers and piecing it together. you guys think it would be cheaper to do that or just save up and buy another lift
TBULL96XJ is offline
post #2 of 14 Old 06-24-2012, 05:46 PM
blackolive99
Im running a Rusty's 3" with the shackles/spacers. Love it! 1" tc drop, 2* shims, fixed upper and lower control arms for 4", and adj. trac bar.
blackolive99 is offline
post #3 of 14 Old 06-24-2012, 06:02 PM Thread Starter
TBULL96XJ
awsome, i think im gonna go with the shackles and spacers. i figured i would be happy with the 3 in lift but after a couple of months of looking at my jeep i just need to go bigger.
post #4 of 14 Old 06-24-2012, 07:31 PM
blackolive99
That's how I felt!
post #5 of 14 Old 06-24-2012, 07:32 PM
Texsun
just chop your XJ up!
Texsun is offline
post #6 of 14 Old 06-26-2012, 11:07 AM
ibjeepin95
Are you wanting more lift for bigger tires?
ibjeepin95 is offline
post #7 of 14 Old 06-26-2012, 11:56 AM
pumpkinXJ
Like others asked, bigger for more lift or for bigger tires? For bigger tires if you don't mind cutting and welding I vote to cut it. I did on mine. And can clear 38s on 5.5in currently on 36s.
current 99xj (5.5 on 36s)
past 98 xj (4.5 on 33s)sold 95 zj (stocker)sold
Originally Posted by -Deepskyy- View Post
If it ever happens to me, I'll just put the clutch down to the floor, and start revving the YJ up to about 3500 and then yell out "I'M SORRY I CAN'T HEAR YOU OVER THE SOUND OF AWESOME COMING FROM MY JEEP!"
pumpkinXJ is offline
post #8 of 14 Old 06-26-2012, 11:58 AM
jeepinjeffrey
The addiction will get you
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #9 of 14 Old 06-26-2012, 03:24 PM
Howard92XJ
1992 XJ Cherokee
If you're wanting to go with bigger tires, I have to agree with everyone above. I started with a 2 inch lift, and immdeiately wanted to go bigger. Ended up cutting the fenders and running 32's with a 2" lift for a little bit. I am now at 3.5" lift and 34's.
92 XJ 3.5" lift, trimmed fenders, cut & folded lower quarters, 34x10.50 Swampers, JCR Stage 1 front bumper, Stage 2 rear bumper, lots of Herculiner
For Sale:v8 zj draglink, leather rear seats from 95 zj
Howard92XJ is offline
post #10 of 14 Old 06-26-2012, 03:56 PM
Motorcharge
Flex isn't limited by suspension height, its limited by the components you use in your suspension. Bigger lifts call for more components to be safely run at that height, and this is why an out of the box 3" kit won't net you the same flex as an out of the box 6.5" longarm. Put many of the components from the 6.5" longarm lift on your 3" springs, and you will have a rig that flexes very similarly to it's taller counterpart (in many cases even better).
A flatter leaf spring allows more suspension travel than a taller, highly arched leaf spring. With a linked type suspension a flatter control arm angle will allow superior suspension droop over a control arm that is already at a steep angle to begin with.
http://www.cherokeeforum.com/f2/low-cog-suspension-setup-tricks-tips-32980/
You don't need more lift height to achieve better flex.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #11 of 14 Old 06-26-2012, 05:50 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
All of that depends on the style of wheeling that's done. I need more than that for my wheeling habits an terrain. There is no perfect height. LCOG is NOT always better.
To the OP. If you are not wheeling and just going for a taller looking XJ then you'll be fine with shackles and spacers. Even if you are doing very mild wheeling and not carrying loads of weight you'll still be ok. But if you want to perform better on the trail, I'd build your rig for your specific type of wheeling and use quality parts. Sometimes lower is better. Sometimes not.
1990JEEPXJ is offline
post #12 of 14 Old 06-26-2012, 05:57 PM
Motorcharge
Missing the point, I'm not advocating it for all situations but some of the information in there, especially pertaining to how flex is affected is universal.
|SOLD|
| June 2015 COTM |
post #13 of 14 Old 06-26-2012, 07:40 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
And I never said that LCOG is bad. I said there is a time and a place. So I fail to see how I missed the point. I told him to build his rig around his wheeling terrain/style. Sometimes higher is better, sometimes not. Which is what that thread said, and what I said.
post #14 of 14 Old 06-26-2012, 07:50 PM Thread Starter
TBULL96XJ
I have a set of 31s right now just picked up a set of 33 mickey thompson mtz gonna trim..but i still wanna go bigger with the lift
want to go bigger GTRJACK XJ Cherokee Technical Forum 5 09-22-2011 07:18 AM
Help me go Bigger GTEIS300 XJ Cherokee Technical Forum 3 12-26-2010 07:40 PM
Bigger? Broklee XJ Cherokee Technical Forum 2 04-09-2005 07:15 AM
bigger calipers need bigger rims... myth or reality? twisted_ed XJ Cherokee Technical Forum 5 01-27-2005 11:25 AM
Must... go... bigger... JoeHo XJ Cherokee Technical Forum 2 01-15-2004 06:15 AM
