VOTE! for December's Cherokee of the month - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VOTE! for December's Cherokee of the month
View Poll Results: pick Decembers cherokee of the month
ben1.8t 22 30.56%
Jeeplesjeeper 1 1.39%
89eliminator 8 11.11%
Hussler 2 2.78%
dcorn 11 15.28%
Corcor4 3 4.17%
kyjeeper4life 8 11.11%
SFRautomotive 7 9.72%
GtiKyle 6 8.33%
JeepXJMike20 4 5.56%
Voters: 72. You may not vote on this poll
Unread 11-25-2011, 12:23 AM   #1
The_Blacksmith
Genius with this metal
The_Blacksmith's Avatar
1993 XJ Cherokee
Hope everyone had a good turkey day, now once you are done with the turkey coma, you can look at pictures, because nobody reads the mod lists, and VOTE lol
(if you entered and dont see your jeep here, we picked 10 jeeps like were gonna every month, it was very difficult to decide.
you'll be automatically resubmitted for the following years contest if your jeep wasnt picked, if you don't win and wanna try to get in again, you can resubmit when I start taking entrys for januarys.
ENTRY 1
Year: 1996
Model: Cherokee SE
Drive Train: 4.0L, AX-15, sye'd 231, 4.10 d30 riddler cover, CA skids, 760s, timken hubs, 4.10 8.25, shaved bottom
Suspension: total = 4". rough country 3" springs +1" spacer, 1.5" shackle w/ bastard packs. spring plate bumpstops, hand made spring clamps
Wheels/Tires: 17x7" dodge charger steel wheels, 32" (255/75) BFG Mud Terrains (JK Rubicon takeoffs), stock center caps
Other Notable Modifications: sye, sliders, full factory skids, welded exhaust manifold, cookie tray floors, train horn, hellas, 2 spares
Favorite Modification: home made front bumper D rings and/or gutter mount roof rack brackets
Least Favorite Modification: a halloween egging that took paint off or fred flinstone floors.
Favorite Trail: sound side of cape hatteras point, or reading anthracite coal piles.
Best Trail Damage: cracked header panel from going through a 5' snow pile full throttle in 2nd.
Build Thread: Link
ENTRY 2
Jeeplesjeeper
Year:1998
Model:Jeep "XJ" Cherokee
Drive Train:Dana 30 up Front and Chrysler 8.25 Rear, SYE
Suspension:6 inch Skyjacker
Wheels/Tires: 33inch Bfg allterain's, 15x9 Alcoa 8's
Other Notable Modifications:Front Bumper, Sliders
Favorite Modification:Lost of Lights
Least Favorite Modification:None so far
Favorite Trail:Mounds Off Road Park
Best Trail Damage:Rear Bumper on tree
Build Thread: http://www.jeepforum.com/forum/f177/...-slow-1232574/
ENTRY 3
89eliminator
Year: 1989
Model: Comanche
Drive Train: 4.0/AW-4/231 AA SYE
Suspension: Front: 6.5" Rustys coils, homebuilt 4-link using Johnny Joints, 12" travel Bilstein 5150s, limiting straps, homebuilt adjustable bumpstops. Rear: SOA with stock 2wd MJ leaf packs, RC 1" lift shackle, 12" travel Bilstein 5100s
Wheels/Tires: 33x10.5 BFG KM1 with Pro-Comp rims
Other Notable Modifications: Homebuilt front and rear bumper, spare tire mount, rock sliders, Warn M8000
Front Axle: HP 30, lock right, 4.10s, JCR OTK, homebuilt tracbar with mount on top of axle
Rear Axle: D44, rockcrusher cover, 4.10s, detroit locker, KJ disc brakes.
Favorite Modification: longarms or lockers
Least Favorite Modification: sliders, made too thin and they are now bent every which way
Favorite Trail: Probably Badlands since its close.
Best Trail Damage: Exploded t-case
ENTRY 4
Hussler
Year: 1992
Model: Cherokee (thats right, no trim package BARE BONES)
Drive Train: 4.0, ax15, np231 with SYE and lengthened front ds for rear, ARBs front and rear, c clip elim rear, 4.10 gears, custom trans crossmember
Suspension: 2in bb on pro comp 4in springs, rancho shocks pro comp control arms, bastard pack rear, rc shackles, jks quicker discos
Wheels/Tires: Crager d's with 33" cooper stt's
Other Notable Modifications: All armour hand built by me.
Favorite Modification: Big ****ing hole in my roof
Least Favorite Modification: Big ****ing hole in my roof. Just kidding, my ****ty paint job
Favorite Trail: Tassel Hill park
Best Trail Damage: Broken front axle
I'll be straight, thing was a pile of **** when I first got it. Smashed windshield, bad brakes, leaky radiator, blown pinion, bad fuel pump ect. ect. But with enough hard work and love she became the most reliable vehicle in the family.
ENTRY 5
dcorn
Year: 1998
Model: Cherokee Classic
Drive Train:
4.0L engine w/ 146k miles
IronMan Offroad motor mounts
Spectre cone filter, custom high clearance exhaust (dynomax cat, magnaflow muffler)
AW4 transmission w/ B&M cooler
CSF 3-core radiator
NP231 w/ AA SYE and Tom Woods rear driveshaft
D30 w/4.56 gears, ARB locker, RCV shafts, Ballistic truss, brand new Timken unit bearings, brembo pads/powerslot rotors
C8.25 w/ 4.56 gears, Powertrax no-slip, Yukon shafts, G2 disc brake kit
Currie Currect-link Steering w/tie rod flip OTK
Rebuilt YJ steering box tapped for hydro assist
Suspension:
Poly Performance 3-link long-arm kit
RE 4.5" springs w/1" spacer front
RE 3.5" leaf packs with 1" shackle rear
Bilstein 7100 reservoir shocks (F) (brand new, less than 1000 road miles)
Poly Perf. upper shock adapters
OME long travel shocks (R)
JKS high clearance rear shock brackets
DPG rear bumpstop plates
JKS discos
RE HD track bar and bracket
Wheels/Tires:
35x12.5" Goodyear MT/R w/Kevlar tires
15x8" Mickey Thompson Classic locks
Armor:
Rigidco FbG bumper with BG11 grille guard, custom mounted Warn M8000
Detours Tailbone rear tire carrier
TnT Customs Belly pan
Ruff Stuff diff covers front and rear (new front cover w/countersunk bolts)
JCR rear quarter guards w/LED tails
Currie LCA skids
Extras:
Alpine head unit w/ Infinity and Alpine 6.5" speakers
Transmission temp gauge
RunCool hood louvers
The Source 10lb CO2 tank
ARB mini compressor (to run locker)
trimmed fenders
Removable doors (all four)
Cobra 19 CB with 2' firestick
upgraded H4 lights with silverstar bulbs
IPF 968 lights
Custom storage box built for rear hatch
Brand new Diehard Platinum battery
Bottle opener on rear bumper
Removable doors
JCR 4 bolt steering conversion that was supposed to match up with the YJ box. Not even close.
Favorite Trail:
Any steep, slippery uphill trail that requires a lot of wheelspeed and momentum
Best Trail Damage:
Sheared 6 teeth off the front ring gear on the last climb out of Pennsyltucky at Big Dogs. Had to pull the ring gear out at the campsite so I could drive it home.
Build Thread:
http://www.jeepforum.com/forum/f153/...axles-1284529/
pics:
The_Blacksmith is offline   Reply With Quote Quick reply to this message
Unread 11-25-2011, 12:28 AM   #2
The_Blacksmith
1993 XJ Cherokee
ENTRY 6
Corcor4
Year: 2001 Xj
Model: Cherokee
Drive Train: need a sye D:
Suspension: 5.5" super lift
Wheels/Tires: 33" wrangler duratracks, soft 8s
Other Notable Modifications: Sliders, bushwackers, aalpine speakers and headunit, exile 800w amp, 10" exile sub, cb, tint, quick discos, driving lights, extended brake lines, roof rack with ski rack, adjustable track bar.
Favorite Modification: sliders, saved my a$$ a few times
Least Favorite Modification: 1.5" block in the rear
Favorite Trail: Firebreak 5, tillamook state forest cuz i can't make it up it and always leave with some carnage!
Best Trail Damage: Coil spring went through my spacer, bent in my slider.
Build Thread: http://www.jeepforum.com/forum/f177/...ee-xj-1252097/
DSC00980 by CDC_1994, on Flickr
DSC00988 by CDC_1994, on Flickr
DSC00995 by CDC_1994, on Flickr
jeep friends
DSC01023 by CDC_1994, on Flickr[/QUOTE]
ENTRY 7
kyjeeper4life
Year: 1995
Model: Cherokee Country
Drive Train: 4.0, Np231, HpD30, 8.25
Suspension: Rubicon Express 6'' short arms with drop brackets, Rustys Adj trackbar, Bds Shocks
Wheels/Tires: Craiger D windows 15X10, BF Goodrich KM2's 33/12.50/15
Other Notable Modifications: Cut fenders, Custom cb mount, Cargo area rino lined, Arb bull bar bumper, Roof Rack,K@N Cold air intake, Tom Woods front and rear Drive Shafts, ZJ v8 TREs, New Splicer U-Joints in drive shafts and axle[/B]
Favorite Modification: Rubicon Express 6" lift
Least Favorite Modification: No front Sway bar
Favorite Trail: Grape vine, Harlan Ky
Best Trail Damage: Hit a Tree at DTOR Off Road PARK in Bedford Ky, Knocked out passanger side front door glass and caved in the sheet metal behind the rear window
Build Thread:No build thread at the moment, One in progress
ENTRY 8
SFRautomotive
Year: 1992
Model: Cherokee Sport
Drive Train: 4.0/ AX-15/ NP231 with SYE/ D30 with 4.10's/ Ford 8.8 with 4.10's, trussed, and locked
Suspension: 4.5" homebrew. Front- homebrew uppers and lower control arms, Rustys 4.5" coil, 12" travel shocks. Rear-Homebrew double triangulated 4 link, DOM control arms, LJ rubicon springs, shock hoop/unibody brace with 14" shocks, limiting straps,
Wheels/Tires: 35x12.5x15 Pro Comp MT's on 15x10 aluminum wheels
Other Notable Modifications: Homebrew front bumper/recovery points, rear hitch, KC lights, bedlined floorboard, homeade t case skid, Rustys steering, double sheer track bar
Favorite Modification: 4 link
Least Favorite Modification: only the ones i havnt done yet.
Favorite Trail: Alpha Pit
Best Trail Damage: some tree marks on my drip rails, and some damage to my rockers.
Build Thread: http://www.cherokeeforum.com/f46/project-florida-crawler-74408/
ENTRY 9
GtiKyle
When the zombies come, I'm busting out in the hills Warn VR8000 on multimount and custom bumpers to come.
Year: 1998
Drive Train: 4.0 AW4 NP231 D30/8.25
Suspension: 6.5" RE Long Arm, Skyjacker components
Wheels/Tires: 35" Goodyear Wrangler MTR Kevlar
Other Notable Modifications: 4.56 locked F/R, Bushwackers, Kenwood deck, Infinity reference speakers, Kicker CompVR 10"
Favorite Modification: Custom storage box for tools, recovery gear, and weapons for slaying zombies
Least Favorite Modification: Stickers didn't add HP like i thought they would
Favorite Trail: Evans Creek
Best Trail Damage: Busted out window (so far)
Build Thread: http://www.jeepforum.com/forum/f177/...t-1-a-1272741/
ENTRY 10
JeepXJMike20
1996 xj high output 4.0
2. Lifted 2"-3" RE rubicon express and oem running 31x10.50 with 15x8 cragars rims soft8 with 4" backspacing/ swaybar quick disconnects/ custom cut fenders/ custom winch bumper and warn m8000 winch/ roof rack and back up lights/ skidplates.
This jeep is a handown from my father, i built this from stock. it does everything i ever ask it to do./ it is my daily driver and weekend wheeler. i build my jeep and really like wheeling it. it does mudding /sand trails/sand dune/rockclimbing anything i put it through.
Year: 1996 xj
Model: Jeep Cherokee Sport
Drive Train: 4.0 high output
Suspension: lifted 2"-3" front height 2.5" and rear height 3.25" with rubicon express and custom leafspring build and oem coilspring insulators.
Wheels/Tires: 31x10.50 bfgs 15x8 w/ 4" backspacing cragars rims.
Other Notable Modifications: N/A
Favorite Modification: lift and tires custom winch bumper and warn winch m8000.
Least Favorite Modification: N/A
Favorite Trail: St hellen orv trails/ the mounds/ silver lake sand dune/ rocks and valleys.
Best Trail Damage: broke my clevis pin by swaybar / suspension crashing down to hard on it lost it on the trails.
Build Thread: http://www.jeepforum.com/forum/f22/m...ld-xj-1156115/
Unread 11-25-2011, 08:58 AM   #3
JeepXJMike20
this is a really nice contest alot of great rigs this month. good luck everyone.
4.5" Rough Country x series lift kit/ lifted xj 31x10.50 15x8 4"backspacing cragar rims/ trimmed front rear fenders/custom swaybar quick disconnects/custom winch bumper w/ warn winch/custom roof rack/ lights mounted.
my build thread http://www.jeepforum.com/forum/f22/my-jeep-build-xj-1156115/index3.html
JeepXJMike20 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2011, 10:21 AM   #4
Ed-de
Junior Member
Kyjeeper4life bump
Ed-de is offline   Reply With Quote Quick reply to this message
Unread 11-25-2011, 11:53 AM   #5
PChamb
Originally Posted by Ed-de View Post
Kyjeeper4life bump
x2
PChamb is offline   Reply With Quote Quick reply to this message
Unread 11-25-2011, 02:34 PM   #6
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
Stuck. Good luck, and Happy Thanksgiving All!
Kyle - I mod stuff®
2005 Subaru Legacy GT
SOLD!!! - 1999 XJ Build Thread
ReconMill is offline   Reply With Quote Quick reply to this message
Unread 11-25-2011, 06:20 PM   #7
The_Blacksmith
1993 XJ Cherokee
it really is a good contest, with DOUBLE the amount of entrys we had last month, it was really hard to pick only 10.
Unread 11-25-2011, 07:05 PM   #8
Durt_Diver
close call between dcorn and sfrautomotive..... but i have to go with dcorn
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline   Reply With Quote Quick reply to this message
Unread 11-25-2011, 10:53 PM   #9
Azzy
Hussler all the way, love that soft top so much Im going to clone it next year.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline   Reply With Quote Quick reply to this message
Unread 11-26-2011, 07:13 AM   #10
Ben
Hack
Ben's Avatar
Nice group of Jeeps to be counted among.
Thanks Blacksmith and ReconMill for bringing this back around.
5.3L TJ
Ben is online now   Reply With Quote Quick reply to this message
Unread 11-26-2011, 08:07 AM   #11
The_Blacksmith
1993 XJ Cherokee
it was really close from all the entrys, there were no clear landslide rigs, I figured this contest would be really close and everyone in it could feel good about the comp.
So many unique mods on these rigs really stand them apart but bring them together. The other people who didnt get in this month, would have been the same fit which made it even harder to choose. I really hope I get 10 + people entering every month, keep it intresting and honest.
Unread 11-28-2011, 06:34 AM   #12
The_Blacksmith
1993 XJ Cherokee
bump
Unread 11-29-2011, 11:31 AM   #13
dcorn
2014 Jeep Grand Cherokee Summit
dcorn is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 12:04 PM   #14
JeepXJMike20
only 55 votes we need more people to vote
Unread 11-29-2011, 01:54 PM   #15
The_Blacksmith
1993 XJ Cherokee
the poll is running and extra day because when I made it, I forgot November fails at having 31 days in it.
