VegasGT's "TastefullyCheap" Build - '99 XJ - Page 63 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > VegasGT's "TastefullyCheap" Build - '99 XJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOfficial Chassis Saver Rust Preventive Truck & Auto UnFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 11-27-2013, 10:49 PM   #931
PeteNnewburg
Glue
I have a '98 'Stang .. waiting. Too many projects makes for a very empty wallet!
1995 ZJ DD, http://www.jeepforum.com/forum/f22/95-zj-dd-1470403/
2000 Cherokee, http://www.jeepforum.com/forum/f22/plain-jane-00-xj-slower-build-1555543/
1998 Mustang GT
'89 F150, 4" Rancho
PeteNnewburg is offline   Reply With Quote
Unread 11-27-2013, 11:10 PM   #932
PeteNnewburg
Both my ZJ & XJ need rocker repair, rusty PA thank you. I'll start with the "RuffStuff" http://www.ruffstuffspecialties.com/catalog/XJRAIL.html .
1998 Mustang GT
'89 F150, 4" Rancho
Unread 11-28-2013, 08:54 PM   #933
VegasGT
Bolt Snapper
VegasGT's Avatar
Oh yes, my wallet is featherweight. Its sad because Ive set back enough money for my car to do stiffeners, rocker replacement, and control arms for the XJ lol. The wife doesnt mind me dropping money on the Mustang as much for now haha.
Ill be buying HD offroad stiffeners when the time comes. Good pricing and they are pre drilled for several rosette welds, plus goos thickness for welding to the thin rails easily.
- '99 XJ -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
VegasGT is offline   Reply With Quote
Unread 11-29-2013, 06:43 AM   #934
ibjeepin95
Your Jeep sucks...
ibjeepin95's Avatar
Do the stiffeners first. If you crush a rocker between now and then, oh well.
ibjeepin95 is offline   Reply With Quote
Unread 11-29-2013, 06:53 AM   #935
VegasGT
Bolt Snapper
VegasGT's Avatar
Yea, I suppose you all have a point. Ill probably wait a little longer on the project then. ****in unibodies and their thin ****.
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 11-29-2013, 06:58 AM   #936
PeteNnewburg
You guy's know the XJ better than I, but it seems doing the rock sliders before the frame just moves the crushable point from the rockers to the frame. That could result in much worse damage than rockers.
my $ .02
1998 Mustang GT
'89 F150, 4" Rancho
Unread 11-29-2013, 07:07 AM   #937
VegasGT
Bolt Snapper
VegasGT's Avatar
my $ .02
Possible, but people run bolton sliders to the factory rail all the time. Most of those only have two bracing legs with a minimal mounting plate held on by some self tappers.
Id be running 3 legs to lengths of 3" angle welded to the rail. 3" angle is all stiffeners are for the most part really. I have access to a good chunk of it for practically nothing, could just make my own lol.
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 11-29-2013, 07:08 AM   #938
Luke95
my $ .02
Nailed it.
Lost one of my nuts due to not paying attention.
LOW COG wannabe http://www.jeepforum.com/forum/f177/zips-2-0-my-98-a-1498978/
Luke95 is offline   Reply With Quote
Unread 11-29-2013, 07:12 AM   #939
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
my $ .02
The unirails will take a more significant hit than the rockers. But cutting the stock rockers out and burning 2x6 rockers in before you do uni-stiffeners just doesn't make a lot of sense. Without tie-ins you just have a hunk of steel waiting to be pushed up into everything. And without stiffeners you don't have anything to tie-in to.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote
Unread 11-29-2013, 07:59 AM   #940
VegasGT
Bolt Snapper
VegasGT's Avatar
I dont have a bit of disagreement that stiffeners are a needed item to maintain longevity of the Jeep as a whole, but using 3" angle iron to plate the areas the legs are mounted to would be plenty strong to take a side hit. As good as stiffeners are, these Jeeps arent going to fall apart and snap in half out there running tires in the 33" range.
Think about your front rails. They are not plated with stiffeners. Your trackbar bracket is mounted to a relatively small length of the rail which is just as thin as the rest of the rails. It hangs below the rail, mounted to the trackbar which constantly acts on that small area of thin unibody rail as a lever, keeping the entire axle located. Every time you wheel all that force is constantly beating, banging and prying on a 6" long section of thin unibody rail.
By the same logic how is it that that 5 feet of 3/16" tube welded to the top then braced to the rail with 3 legs, that all weld onto 3 6" long pieces of 3" angle iron plug and stitch welded to the sides and bottom of the rail would taco my Jeep when I come down on a rock? Only difference between this way and bought stiffeners is the 3 plated areas would be connected.
I say all this with full intent to do stiffeners, just doing a little devils advocate here to get the brain flowing.
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 12-02-2013, 10:51 AM   #941
VegasGT
Bolt Snapper
VegasGT's Avatar
Death to ****ty shackle angles.
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 12-02-2013, 10:53 AM   #942
crockett07
1992 XJ Cherokee
Righteous!
crockett07 is offline   Reply With Quote
Unread 12-02-2013, 10:54 AM   #943
Luke95
Bank! I'm jelly
Unread 12-02-2013, 10:57 AM   #944
NW99XJ
NW99XJ's Avatar
HD FTMFW!!!
(i'm going with the lift option though - when I get mine)
5" of lift, 33's. Armored, Lighted, Chipped, & Locked up Front. Soon to come: winch, gears, axle shafts, and more...
My Build Thread: http://www.jeepforum.com/forum/f22/f...-build-970888/
Built Not Bought - Senior Member
NW99XJ is offline   Reply With Quote
Unread 12-02-2013, 01:27 PM   #945
VegasGT
Bolt Snapper
VegasGT's Avatar
Originally Posted by NW99XJ View Post
HD FTMFW!!!
HD has some genuinely beefy stuff for sure! I had considered the lift version but Im pretty happy with my current height. That and with my cut and fold I can already see the entire shackle, didnt know if itd look right hanging down any farther.
Ive got another pair of longer shackles that Im going to try and run with these to pick up a half inch of lift or so just to support extra weight of tools and fullsize spare I added.
- '99 XJ -
4.5"/35's
July 2013 COTM
