VegasGT's "TastefullyCheap" Build - '99 XJ - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > VegasGT's "TastefullyCheap" Build - '99 XJ
Steinjager TJ tube doorsJK Front Lower Adjustable Control Arms!JK Rear Adjustable Control Arms!
Unread 03-18-2013, 10:02 AM   #196
Camfam07
yeah I was looking at them one day and I went with stupid blocks instead.. so now I have a bastard pack ready to swap in... but I wanted to try the shackles they look pretty nice.
Camfam07 is offline   Reply With Quote
Unread 03-18-2013, 10:10 AM   #197
VegasGT
Bolt Snapper
VegasGT's Avatar
Yea, the shackles are pretty beefy. Just make sure you get the ones for a 88-98 full size Chevy. There is another type Autozone carries for certain Fords and they are too wide.
- '99 XJ -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
VegasGT is online now   Reply With Quote
Unread 03-18-2013, 10:15 AM   #198
Camfam07
thanks for the info~! ill have to grab me a pair it looks like but im hoping I get about 3" from the s10 leaves. if so I will only run a 1" or .75" shackle.
Unread 03-18-2013, 03:23 PM   #199
VegasGT
Bolt Snapper
VegasGT's Avatar
Decided to ditch the hoodmount lights and mount them on the bumper via eye bolts. I wanna do smaller diameter A Pillar lights later on though.
Eye bolts are a good way to get fatter lights to fit on the stock bumper. I still need to trim the extra light mounting stud but heres a couple pics.
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 03-18-2013, 03:59 PM   #200
Weeder1
Now fab some a pillar mounts and get some 3.5" warns like me! Lol
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote
Unread 03-18-2013, 04:06 PM   #201
VegasGT
Bolt Snapper
VegasGT's Avatar
You're kind of my inspiration there haha. Liked the look of the small lights up there and I could definately used something to light up the sides a bit better.
You fab your brackets or get Detours?
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 03-18-2013, 05:13 PM   #202
Weeder1
Haha. I love mine there, i fabbed mine.
-98 xj sport-
Unread 03-18-2013, 05:46 PM   #203
VegasGT
Bolt Snapper
VegasGT's Avatar
Got any close-up pics/advice? Im mainly just trying to figure out the best way to keep the mounting point level during welding.
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 03-18-2013, 06:15 PM   #204
Weeder1
I held it up there, tacked it then adjusted where i wanted then threw a bead on it.
-98 xj sport-
Unread 03-18-2013, 06:27 PM   #205
VegasGT
Bolt Snapper
VegasGT's Avatar
Thanks! Howd you put the bend in the part that sits flat on the a pillar?
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 03-18-2013, 06:37 PM   #206
Weeder1
I just cut a slit in the flat steel and welded it back up. That way the bend is sharp not rolled as if i were to bend it.
-98 xj sport-
Unread 03-18-2013, 06:39 PM   #207
VegasGT
Bolt Snapper
VegasGT's Avatar
Good thinking!
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 03-18-2013, 06:44 PM   #208
Weeder1
really easy to fab just take your time and make sure measurements match on both sides.
-98 xj sport-
Unread 03-18-2013, 07:09 PM   #209
VegasGT
Bolt Snapper
VegasGT's Avatar
Yea, didnt look too tough. I need to come up with a switch panel if I keep adding stuff. Like to add aux fan overide, backup aux lights, and the a pillar lights. Thats 4 switches there. Where do people get these fancy switches that are labeled and have symbols? Lol
- '99 XJ -
4.5"/35's
July 2013 COTM
Unread 03-18-2013, 07:24 PM   #210
Weeder1
Ive seen some online at 4wd places. Im gonna build one where the cig lighters are one day. I want two rows of four toggles. Same spot as now but diff switches. Those switches will be moved down by the shifter with two rows of two.
-98 xj sport-
