VegasGT's "Clifford The Big Red Unibody" - Page 81 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 03-26-2014, 11:15 AM   #1201
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Originally Posted by NW99XJ View Post
RUFF STUFF SPECIALTIES.... $16.50 for DOM tubing and a pair of bushings.
(X2 = $33) ...add shipping and other raw materials, and I bet you'd be into it less than $50 still.
http://www.ruffstuffspecialties.com/...t_Code=BUSHDOM
that and a chunk of 4x2x.125 tubing cut to about 4.625".....
And a hole in it for the DOM....
You're only a couple more cuts and a few welds away from DIY motor mounts.....
(PICS COURTESTY OF TORX @ NAXJA)
...and nobody to blame but yourself if they fail
D3<!L!>3D
S8NNG8 is online now   Reply With Quote Quick reply to this message
Unread 03-26-2014, 12:43 PM   #1202
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Stopped by the house on lunch to get a look at my current mounts. They dont appear to be as bad as I had envisioned. Ive seen pics of them crumbling to pieces and these dont really look that way. It almost looks like theres a gap up top, hard to tell though.
Drivers:
Pass:
Thoughts?? Ive got a ride scheduled for mid April, planned to have rockers done and a Solid diff cover by then. Think I could put mounts on the backburner for a couple months? Or should I go ahead and replace? The IRO mounts are about the same money as the diff cover. Both will get done, just trying to pick which first. Im honestly leaning toward the cover for now (mines had a rough life) and then mounts after the next ride. Second opinions welcome.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 01:40 PM   #1203
Luke95
Get the cover then the mounts. Gearing is $$ postponing that is nice.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 03-26-2014, 01:52 PM   #1204
NW99XJ
Yor DS motor mount looks like it;s got a run or two left on it... MAYBE... I wouldn't put that off for TOO much longer...
But I agree... get the diff cover, and THEN the motor mounts... who knows maybe in the next month you'll get a wild hair to build your own....
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 02:00 PM   #1205
crockett07
1992 XJ Cherokee
Double post deleted
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 02:01 PM   #1206
crockett07
1992 XJ Cherokee
I wouldn't be concerned with either of those mounts. Get your rockers going
Unread 03-26-2014, 03:26 PM   #1207
Vassago
that's what mine looked like before i changed them, totally worth it. get a pry in the passenger side from under your jeep abd push between the frame rail and the moutn and watch how much your motor moves from side to side.
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f177/...lding-1575841/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 08:10 PM   #1208
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Just to throw in my 2 cents:
After wheeling a few times with my stiffeners I had the pleasure of replacing my radiator because my fan chopped into it. Granted, the ZJ fan clutch I had in there brought it forward more than stock but it still had good clearance. The worn out rubber factory mm's gave too much. I went ahead and swapped in Brown Dog poly mounts while my cooling system was outta the way.
The stocker mounts looked okay when I took them out but evidently looks aren't everything. The BrownDogs are without a doubt more beefy and solid over the puny oem mounts. BDs aren't the only option out there but they are relatively cheap, US made, offer a JeepForum discount, and pretty easy to swap.
IMO you should hold off on the rockers, swap in better motor mounts, and buy some diff covers - which Solid covers are just that: solid; and they're inexpensive.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 08:30 PM   #1209
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Wow, thanks for all the advice and insight guys!
All 3 of these things WILL be getting done, and sooner than later.
That said, I'll probably put the motor mounts and diff cover ahead of the rocker replacement for the short term. Ideally Id like to have rockers done too before the mid April ride but in the event money gets tight and I cant make that happen Ive tried to break it down into necessities to make the choice for me.
Considering the trip to WBR is about 2 hour round trip, and that I drive mine down there, the whole theme of things has been to try and slowly eliminate potential failures that could affect my commute back home. A factory D30 cover with a gaping hole in it could complicate things, as could the motor shifting over just far enough in the wrong way to dig into the radiator.
Compared to those things, the rockers arent quite as high on priorities, but still right there with them. Worse case scenario, I dont get them done by that trip and just smash a sheetmetal rocker Im cutting out anyway. If it gets into the door even better, gives me an excuse to trim the doors and go up with the tube even farther. Glass half full.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-30-2014, 04:38 PM   #1210
Luke95
So when are the 609 and s9 going in?
Unread 03-30-2014, 05:34 PM   #1211
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Originally Posted by Luke95 View Post
So when are the flux capacitor and continuum transfunctioner going in?
To be determined.
Seriously wtf are you talking about?
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-30-2014, 07:07 PM   #1212
Luke95
A 60/9" hybrid and a sterling 10.5 9" hybrid axles
Unread 03-30-2014, 08:31 PM   #1213
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Ahh I see. And not happening anytime soon lol.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-30-2014, 08:54 PM   #1214
Luke95
Just do it up
Unread 03-30-2014, 08:54 PM   #1215
Luke95
So like next week?
