VegasGT's "Clifford The Big Red Unibody" - Page 68 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
Dan's 15% Birthday Sale!USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-21-2013, 08:46 PM   #1006
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Originally Posted by PeteNnewburg View Post
What brand of CPS did you install?
Well I went with a BWD part from Advance Auto, got a hookup there for 20% off. I figured Ill see how it lasts, has lifetime warranty. I just spent a buttload on Xmas presents and a new .357 so Im willing to take a chance on the cheaper part.
- '99 XJ Sport -
Lifted, Locked, Stiffened
July '13 and '14 COTM
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 12-23-2013, 09:06 AM   #1007
NW99XJ
Yup when I did mine I used THIS: (a whole bunch of socket extensions)
Here's the write up I did on the whole process: http://www.jeepforum.com/forum/f22/f...l#post11800247
(just to share - and for others looking for some tips when the time comes to do theirs)
5" of lift, 33's. Armored, Lighted, Chipped, & Locked up Front. Soon to come: winch, gears, axle shafts, and more...
My Build Thread: [URL="http://www.jeepforum.com/forum/f22/first-jeep-99-xj-build-970888/"]http://www.jeepforum.com/forum/f22/first-jeep-99-xj-build-970888/[/URL]
[COLOR="Black"][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought - Senior Member[/COLOR][/URL][/FONT][/SIZE][/COLOR][/COLOR]
NW99XJ is offline   Reply With Quote Quick reply to this message
Unread 12-23-2013, 09:34 AM   #1008
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
My CPS connection was directly above the transmission?
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 12-23-2013, 10:07 PM   #1009
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Nice writeup! I enjoy how you worded that up there, by the way. "For when the time comes..." It does seem to be an inevitable issue on XJ's. I was pleasantly surprised that my OEM unit made it to 207k miles before CPS failure.
- '99 XJ Sport -
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 12-25-2013, 05:01 PM   #1010
motoinsane
1997 XJ Cherokee
Hey man, I browsed through the thread and didn't see anything about a slip yoke conversion maybe I missed it. What's your take on it, is it something that needs to be done or can you get away without it?
motoinsane is offline   Reply With Quote Quick reply to this message
Unread 12-26-2013, 04:26 AM   #1011
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Depends on what size lift you're at, would recommend it regardless, but I still have yet to install mine.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 12-26-2013, 06:22 AM   #1012
motoinsane
1997 XJ Cherokee
i have a 4.5 RC lift with 33" mickey T's. The lift isnt on the car yet but will be after the new year.
Unread 12-26-2013, 08:46 AM   #1013
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Currently Im not running an SYE or a t case drop. I honestly dont have any real vibration issues except above 65, then I get an annoying rhythmic rumble. It has not bothered me too much, but I intend to pick up an IRO hack n tap in the semi near future. Im trying to plan out a trip to drive down and wheel at Turkey Bay, its a 2.5 hour drive on mostly parkway. I dont wanna hear the damn thing the whole trip down and back haha.
I should note every XJ seems a bit different. I lifted a 92 3" and it vibes so bad I had to drop the case an inch to make it even driveable.
- '99 XJ Sport -
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 12-26-2013, 01:52 PM   #1014
Spokes
Mall Crawler
Spokes's Avatar
Lucky you. I had horrible vibes even after sye needed a 4* shim now it's like butter... Well for a lifted jeep lol
Red 00 XJ lifted
Build -->http://www.jeepforum.com/forum/f177/...hread-1280981/
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline   Reply With Quote Quick reply to this message
Unread 01-07-2014, 05:37 PM   #1015
VegasGT
Rustler of Jimmies
VegasGT's Avatar
No major updates, but did encounter an issue recently that required some problem solving.
Like most of you, we've been dealing with unusual cold. Been hovering between -6 and 3 degrees for a couple days now. Drove the Jeep in that crap to work yesterday, and when I came back home I stopped in the driveway to see this.
Yikes. No oil pressure. Freaked me out, obviously but no odd noise or behavior from the ol 4.0. This wasnt improving on its own however, and knowing Im behind on an oil change by a good margin was not easing my mind.
I pulled it in the heated garage at the office after I picked up some Havoline 5w30, Mopar filter, and a new oil pressure sending unit after noticing mine was cracked near the nut.
Old oil was definitely nasty, and old sending unit snapped off at the plug like nothing when I went to remove it. Got fresh oil, filter, and sending unit in and all is well again. Crisis averted.
- '99 XJ Sport -
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-07-2014, 06:29 PM   #1016
crockett07
1992 XJ Cherokee
My oil pressure gauge has never worked. I've tried 3 new sending units and I still can't get it to work. Oh well
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2014, 07:49 AM   #1017
NW99XJ
Since I have owned my Jeep, I have swapped out that oil pressure sending unit 3 times.
They seem to be prone to failure....
Unread 01-08-2014, 10:06 AM   #1018
S8NNG8
1995 XJ Cherokee
I cracked mine the first time I changed the oil on my XJ, due to it's location and the filter being on too tight.
D3<!L!>3D
S8NNG8 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2014, 04:09 PM   #1019
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Definitely seems to be a common failure. And Im with you S8NNG8, it is in a vulnerable place if you are trying to fight a tight oil filter.
- '99 XJ Sport -
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-08-2014, 04:11 PM   #1020
Luke95
Theirs a reason I went to a manual gauge
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
