VegasGT's "Clifford The Big Red Unibody" - Page 60 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 11-04-2013, 06:34 PM   #886
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Originally Posted by NW99XJ View Post
Here's what I did for "Disco Keepers"
No more Whiskey Tango zip ties/rope/wire holding them up when out on the trails.... My welds aren't the prettiest, but they hold up. (sorry for the dirty pics - this is post trail use - and a little more mud than should be up there for picture's sake)
1/2" x 2.5" hex head bolts, welded to my front tow hook brackets.
they're not there any more as i'm not running my tow hooks any more.
(its the tow hook brackets those are welded to)
Worked real good though.
Thats fantastic! That is EXACTLY what I had in mind. Great minds.
Only thing is, I too dont have those brackets, and my tie-in brackets for the Dirtbound bumper dont really land where I can weld the hanger to it. Ive been out here staring at it, having a beer and sorting out my options.
I can either:
A: weld plate steel to my tie in brackets, and bring the back off the brackets far enough to weld the hanger pin on. This will give me a good base to weld off of, and make it a removable ordeal so if something should happen to this rig (God forbid) in the future, it will make transfer of mods to a donor easier. Thats prob thinking too far ahead though.
B: find where I want the pin to go on the rail, then plug and stitch weld a small plate on that area to give me a solid welding surface to burn the hanger onto.
Either way will work I believe, A is a bit more "modular" of an approach, B is a bit more "its a damn pin, quit overthinking it" approach.
Ill have a few more beers and ponder this. I am open to criticism.
Thanks for keeping tabs on me over here NW99XJ, your input is always helpful. I feel plenty competent in most of the build projects I work through but there are times another set of eyes/opinions are very handy.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 11-04-2013, 08:35 PM   #887
crockett07
1992 XJ Cherokee
why don't you just weld a bolt onto the frame rail up and out of the way? Its not like these hangers will be holding a lot of weight, and if you ever get tired of it, just cut them off with an angle grinder
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2013, 09:02 PM   #888
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Thats kinda the plan, but I guess Im overthinking things. I just know I get rowdy sometimes and bounce this thing around. I just dont want the damn thing flopping around and tearing a hole in the rail.
Side note: had too much beer. Should prob reanalyze this all in the am.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 11-05-2013, 08:42 AM   #889
NW99XJ
I over engineer EVERYTHING.... gets me in trouble at work most times.
I just keep hearing the words of my old engineering professor in my head....
"Keep It Simple Stupid"
Really there's virtually NO force on the swaybar, and most of the mass is taken up by the bushing mounts anyways while its disconnected. Even with my crappy welds and a Home Depot bolt, my set up held thru numerous wheeling adventures. Hell....those damn bolts are STILL on those brackets. And I BEAT on em a couple times getting them out to do the bumper.
Hey no prob man,
You got a good build goin on, and I dont mind helping other's out by sharing my OWN experiences. I cant tell you how many times I've had a nother Jeeper over at the house and we just sit there and point at stuff and BS about different ways of doing crap to the Jeep.... lol
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 04:40 PM   #890
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Thanks for all the insight everyone. Looked at it with a clear head this afternoon and noticed the rail is double layered in that area. I went ahead and welded the pins straight to the rail, seems plenty strong for the application. Ill get pics up shortly.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 11-05-2013, 05:34 PM   #891
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Hangers done:
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 11-05-2013, 05:57 PM   #892
crockett07
1992 XJ Cherokee
professional grade! I think that setup looks better than my RC disco's
Unread 11-05-2013, 06:00 PM   #893
NW99XJ
Nicely done sir....now go get 'em dirty!
Unread 11-05-2013, 07:18 PM   #894
PeteNnewburg
very nice!!!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 07:21 PM   #895
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I don't suppose there's much movement(flex) between the front of the rails, but if a person were to pin the discos up too tight, could it break them?
D3<!L!>3D
S8NNG8 is online now   Reply With Quote Quick reply to this message
Unread 11-06-2013, 09:21 AM   #896
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
After looking at it I dont believe it will be an issue. Not much load on the hangers.
Originally Posted by PeteNnewburg View Post
very nice!!!
Thanks a ton! Im real happy with the overall result here, already had a couple people ask what brand they are lol.
Heres a short clip of the disconnecting process. Pretty painless.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 11-07-2013, 08:57 PM   #897
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Did a little trail maintenance behind the house today, getting more and more done all the time. Also got to put my disco setup to good use. Disconnect was a breeze, and reconnect went pretty smooth, had to grab bumper hoops to rock it a bit til it was level. Still was a super quick job.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 11-08-2013, 06:19 AM   #898
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Do you have spacers on your wheels? I don't remember your tires sticking out that far.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 07:52 AM   #899
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Nah, just the same Cragars Ive been running, 15x8 4" BS. I dont take many straight on shots of the Jeep though, so all the angled pics could make it look narrower than it is i guess.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 11-09-2013, 08:38 AM   #900
PeteNnewburg
I may have missed it, but what type of threaded rod did you use for your disco's? (size/ type - zinc coated/ stainless?) 1/2" Heim's?
I picked up some 2" x 5" x1/8" box tubing to make a winter bumper project.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
