VegasGT's "Clifford The Big Red Unibody" - Page 43 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-22-2013, 09:33 PM   #631
MountainMan864
Now just buy the JCR cutandfold bumper and be done with it.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 05:29 AM   #632
Weeder1
Whats "buy" mean?
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 07:27 AM   #633
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Already bought a rear bumper, its on my roof. "some assembly required"
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 08:55 PM   #634
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Started on the bumper, got the beginnings of it tacked in. Still a lot to do but you can kinda use your imagination at this point.
****ty night shot:
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 07-23-2013, 10:24 PM   #635
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'm no fan of "do it all black", but your black grill is really a better look for your rig
D3<!L!>3D
S8NNG8 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 07:50 AM   #636
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Thanks man, i think it fits in a lot better with everything else.
Got a better shot of the start of the rear bumper. Tried to get a good compromise of keeping it high and tight while still offering some protection if I back into something. Hope to have it mostly finished my the end of the week.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 07-24-2013, 02:09 PM   #637
Weeder1
Lookin good. You gonna notch it at the frame and pull the corners in?
-98 xj sport-
Unread 07-24-2013, 02:12 PM   #638
NW99XJ
Also....are you gonna extend it into the frame/unibody, and tie into the same mounts as a trailer hitch/gas tank skid plate does?
This would be a little harder, and a bit more work, but WELL worth it in the long run.
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 04:03 PM   #639
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
As it sits currently, its mounted to factory location. I trust that enough to keep it from falling off on a bump and thats about it lol. I will be welding up angle iron and tie in to an additional 4 hitch mounting holes per side. I will be building my own nut strips out of 3/16 and the angle iron will be below the rail to sandwich the whole area. I feel that will be plenty.
@Weeder1,
Aesthetically, I originally intend to pull the sides in to flow with the hatch. It just makes sense, but I know I could also benefit from the extra protection in the taillight area if I did not do this. With that said, Ive done about a million measurements to get the main tube to sit exactly where I want it. As is there are no gaps visible when looking down at it from above, and even at the sides it is still tucked in a good bit more than the factory bumper.
It looks a bit funky right now since its still a blank canvas, but once I get the ends angled/capped, side wings on, taillight gaps taken care of and 2" receiver integrated it will all really come together.
Heres one similar to my plan.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 07-25-2013, 10:56 AM   #640
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
ok now make me one pls.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 09:50 PM   #641
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Lol Im about burnt out on all the little work tied up into this project already.
Got a couple hours of work in after work today. Burned in main tube to the mounts solid, cut the ends and cut off the beginnings of the side wings.
Also got drivers side quarter cut/boxed/sealed to prepare for building the wraparound portion of the bumper.
I have to say, all the writeups on the cut n fold had me expecting it was a big job. I honestly think it just sounds complicated with measurements and all that. This was by far one of the simplest things Ive done to the Jeep lol.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 07-26-2013, 07:30 AM   #642
Luke95
I love the. It and fold it works amazing, keeps my junk off the ground.
But I have to ask do you scrape? I'm at 3 ish and I scrape like its my job now.
I <3 rockrash
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2013, 02:48 PM   #643
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
I <3 rockrash
Rocks are pretty big down there where I wheel. I scrape everything still because Im on that "bypass trails are for *******" mindset, even when I get into **** I probably shoulda avoided. I need to look into a belly and tank skid soon, and stiffeners before I beat the rails up anymore haha.
Ive been careful not to crunch the lower quarters in the past two trips, but now that I know it wont be an issue theres no telling what Ill **** up this time. Im going down early Sunday and staying all day, Ive got til Saturday night to get the bumper at least mostly finished. I at least will get the side wings burned in and everything capped off, then just do the receiver/tie-ins/taillight fillers when I get back. Ima try and go hard and finish it if I can tho, without halfassing it of course. Ill go bumperless before I rush the process.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 07-27-2013, 10:52 AM   #644
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Slowly getting there.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 07-27-2013, 11:29 AM   #645
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Damn good work sir
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
