VegasGT's "Clifford The Big Red Unibody" - Page 42 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
Labor Day Sale!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-21-2013, 02:48 PM   #616
VegasGT
Bolt Snapper
VegasGT's Avatar
Originally Posted by WJ04runner View Post
i always get it from home depot but im sure lowes an stores of that kind would have it aswell
Thanks, I was actually in Walmart earlier looking around and came home with this:
Anxious to see how it does!
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is offline   Reply With Quote
Unread 07-21-2013, 05:49 PM   #617
VegasGT
Bolt Snapper
VegasGT's Avatar
Went ahead and did my grille. Turned out just how I wanted, might become addicted to this stuff for oddball things around the house, pretty neat product.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 07-21-2013, 06:39 PM   #618
S8NNG8
1995 XJ Cherokee
There's still too much shine... do the windows
D3<!L!>3D
S8NNG8 is offline   Reply With Quote
Unread 07-21-2013, 07:42 PM   #619
IDIdiesel
looks alot better IMHO. Try doing the bottom of the doors to the first body line. Iv always liked the way that looks almost 2 tone
1991 Ford F250 7.3L IDI diesel
2001 Cherokee sport "AGENT ORANGE"-DD BUILD THREAD: http://www.jeepforum.com/forum/f177/agent-orange-build-1306755/
1948 Willys CJ2A++1994 Wrangler 4cyl. manual trans++2012 JK 4dr unlimited 6spd
IDIdiesel is offline   Reply With Quote
Unread 07-21-2013, 07:46 PM   #620
S8NNG8
1995 XJ Cherokee
If it peels so easily, perhaps the rockers may not be a good idea.
D3<!L!>3D
Unread 07-21-2013, 07:54 PM   #621
IDIdiesel
Not a perminate solution but as a way to test if he likes the color there than go ahead and bedliner it
Unread 07-21-2013, 08:14 PM   #622
S8NNG8
1995 XJ Cherokee
I'd more likely take a razor blade to a black garbage sack, and a roll of cheap masking tape. Step back to see if you like it. Cheaper, less effort, and easier removal.
D3<!L!>3D
Unread 07-21-2013, 09:04 PM   #623
VegasGT
Bolt Snapper
VegasGT's Avatar
Thanks man, been something Ive wanted to do for a while. Ive considered doing the 2 tone like you are talking about. I did that on my last 99 out of necessity (paint imperfections), but I never got around to it here cause the paint is in good shape.
Next step is at the rear. Cut n fold rear quarters and starting on rear bumper build. Getting tired of the quarters hanging down, almost smashed them last time out.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 07-22-2013, 09:10 AM   #624
ibjeepin95
Looking good Vegas! I'd recommend doing a wrap around bumper when you cut and fold the quarters, I need to do this myself...
ibjeepin95 is offline   Reply With Quote
Unread 07-22-2013, 12:27 PM   #625
VegasGT
Bolt Snapper
VegasGT's Avatar
Thanks man! Wrap around is the plan picking up steel in a bit actually. Building it out of 2x4, and mounting inside frame to hitch mounts. Basically will angle cut/cap the ends of the bumper, then use 2x4 on the side wraparounds (turned sideways for more clearance).
Should be similar to this but I plan to fill gaps under taillights and probably do a 45 degree angle at the ends instead of having a sharp 90, if thar makes sense. Idk if Ill have all this done by my trip this weekend but if nothing else I need to fold the quarters. It was a miracle I didnt crush them last trip out.
Should be simple enough to make. I plan to add a 2" receiver in there also, but for now im mainly just building it for side protection, clearance, and to tidy it up a bit back there. Stock bumper looks tacky as hell from the side.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 07-22-2013, 01:29 PM   #626
VegasGT
Bolt Snapper
VegasGT's Avatar
Steel acquired.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 07-22-2013, 03:23 PM   #627
NW99XJ
NW99XJ's Avatar
And good advice on cable upgrades guys! Ive got new stock style terminals right now so that will be put on the backburner a bit longer. Late fall I intend to redo ALL my wiring. I will consult your build NW99XJ when I get there. You and JeepN4KC both are fantastic at writeups in your build, by the way.
Thank you very much for the kind words!
I hope it helps. if/when the time comes and you have any questions or concerns, hit me up, i'll be more than happy to help you out.
The new paint on the jeep looks great by the way.
And I cant wait to see how that rear bumper turns out!
5" of lift, 33's. Armored, Lighted, Chipped, & Locked up Front. Soon to come: winch, gears, axle shafts, and more...
My Build Thread: http://www.jeepforum.com/forum/f22/f...-build-970888/
Built Not Bought - Senior Member
NW99XJ is offline   Reply With Quote
Unread 07-22-2013, 03:38 PM   #628
VegasGT
Bolt Snapper
VegasGT's Avatar
Thanks man!
And I went ahead and pulled the stock bumper off and cut n folded the pass quarter. Still need to seal it up but I stopped for a beer break.
I pretty much winged it honestly. It turned out really well except for the front part closest to the wheel. I cut more off the outerpanel side than intended. Luckily I left enough material to overlap under and cover gaps, just not as pretty. Went surprisingly smooth otherwise. I just gotta tackle the driver side now, then that will pave the way to get to work on the bumper.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
Unread 07-22-2013, 06:14 PM   #629
Weeder1
hurry up!!!!!
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote
Unread 07-22-2013, 06:59 PM   #630
VegasGT
Bolt Snapper
VegasGT's Avatar
Originally Posted by Weeder1 View Post
hurry up!!!!!
Lmao.
Sealed:
Painted:
Side profile:
Ill do drivers side tomorrow probably then I can get to cooking on this bumper.
- '99 XJ Sport -
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
