VegasGT's "Clifford The Big Red Unibody" - Page 33 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-13-2013, 06:10 PM   #481
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Theres work to be done:
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 06-14-2013, 07:13 AM   #482
Luke95
I approve
Iro tie rod?
Sent from my xj
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2013, 07:29 AM   #483
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
^yep.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-14-2013, 07:51 AM   #484
Luke95
^yep.
Mint
Mash it for me let me know what you think
Sent from my xj
Unread 06-14-2013, 08:06 AM   #485
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Originally Posted by Luke95 View Post
Mint
Sent from my xj
It will be put to the test next weekend for sure!
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-14-2013, 08:11 AM   #486
Luke95
Does it take the stock tres if so I'd grab a few for spares
Sent from my xj
Unread 06-14-2013, 08:21 AM   #487
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Sent from my xj
Yea it does. Technically makes the TRE's the weak point but Id rather that be the "fuse" in the setup. I have spares and thats an easy trail fix. Much easier than trying to straighten a mangled factory rod lol
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-15-2013, 04:54 PM   #488
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Well, today is the day I tackle something Ive been puttin off for a while, unibody rail repair. Im halfway done but am taking a beer break before I burn anything in.
For safetys sake, I pulled the tank. Went super smooth, and I manhandled it out with no problems. Note the shadetree mechanic status I got going on, doin it all on my back porch slab like a boss.
With no tank in the way, my view and peace of mind is much better, on the pass side rail near the bumpstop you can see my problem.
Inside the rail:
Outside (yikes):
Im still a little unsure how this spot got so much rust, the rest of the Jeep is very solid. My last '99 had rot in the same area, strange. Either way its gotta come out, so starting with the outside rail I cut out the rust on that side and grinded down to metal around it where the new 3/16" plate will be burned in. As u can see in the pic, I had original made incisions to cut a rectangle out but realized most of that metal is still good so I went with a trapezoid.
Thats where Im at for now. Ive precut the 3/16 plate to run about 15 inches down the rail, and contoured it to the slight bend. Plan is to burn it in on the outside, then weld it from the inside of the rail before I do the inside plate. Then after doing that I will cap it together with bottom plate and call it good.
Ill update this later on once I get more progress in.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-15-2013, 09:23 PM   #489
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Despite my welder acting up and burning through the rail at one point, I got the outer plate burned in nice and solid. Tomorrow morning I will finish up plating the inside and bottom of the rail. Its already greatly improved the areas rigidity, I could flex the whole rail prior to this.
After that was done, I took the time to violently remove a mole or two from my property.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-16-2013, 12:26 PM   #490
Weeder1
Looks good man!
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 02:21 PM   #491
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Originally Posted by Weeder1 View Post
Looks good man!
Thanks man! Its funny how the first half of the build was mostly cosmetic stuff and now for the most part I wont buy/do anything to the Jeep if it doesnt help me on the trail in someway.
I still need work on making my welds pretty lol, they always look so good on the bench but when I started burning the steel onto the Jeep it didnt turn out as well. But its all solid as can be so ohh well. Still not bad for a small 110 stick welder.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-16-2013, 02:30 PM   #492
Weeder1
Its crazy how that **** works once you start wheelin.
As for welding try to get as close and as comfortable as you can. Practice on the bench welding the same way you would on the jeep (vertical, upside down, etc). What kinda arc are you using?
-98 xj sport-
Unread 06-16-2013, 04:31 PM   #493
Luke95
2 things 1 your right
2 **** you you cursed my tie rod so it bent haha
Sent from my xj
Unread 06-16-2013, 04:47 PM   #494
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
****ty Harbor Freight special run reverse polarity DC for the 6011 rods. Tinkered with a lot of settings til I found a sweet spot. My biggest problem I think is being able to maintain a good arc length and angle in awkward positions.
That and I really need a 220 connection out here, Im used to welding on a much bigger unit but I picked up my lil 110v job to do odd things around the house, its been great for a wide variety of things but it has been VERY inconsistent during this whole process. There was a couple instances where it would have a weak arc and stick the rod, then moments later it would pick up and practically blast through the rail. All with no settings touched. First time it has done that.
Going to try and build a garage in the next year and have me a nice hosscat of a welder for my duties then. For now though Im moving on with what Ive got. Went ahead and cut out the rotted inside edge of the rail, although it was about to come out on its own, heres one piece that stayed together.
Now that Ive got that opened up, I plan to also weld that outer plate from the inside of the rail before I cap everything off.
I also believe I will leave a hole in the bottom plating for drainage. Ive had 3 XJ's now that have had rust in this same spot, 2 of which were totally solid otherwise. No signs of rear end collision. I can only assume water getting trapped there plus exhaust heat has caused this over time. Once its buttoned up I plan to pump ATF in the rails from time to time to help prevent future issues with corrosion. I HATE RUST, and the unibody thing makes me fear it even more.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 06-16-2013, 05:13 PM   #495
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Sent from my xj
Haha oooppss my bad. Upgrade time!
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
