VegasGT's "Clifford The Big Red Unibody" - Page 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
Unread 05-06-2013, 08:25 PM   #301
Weeder1
Originally Posted by VegasGT
I will! Theres almost no pics of em out there right now, still pretty new I guess. Ill be sure and whore it out.
Good! Man i want it bad lol
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 11:10 PM   #302
BomberJeep
2003 WJ
Your XJ is awesome. Its what I want to do with mine. Even though im 2WD
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 05:59 AM   #303
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
I need to get my wheels sand blasted.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 01:04 PM   #304
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Thanks man! Still got a lot to do!
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 06:30 PM   #305
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Got a little bit of work started this afternoon.
Got shocks installed:
Noticed I got some rubbing at full lock in reverse. Went ahead and starting pulling inner fenders out for good.
Thats as far as Ive gotten today. I got burgers to grille and tasty adult beverage to consume.
As far as the plan, Ill be pulling the flares off to trim them in that area and repaint them in black bedliner. Will also be trimming sheetmetal under there to match the cut on the flare. Basically be taking it a couple inches straight back by the pinch seam and blending to in an effort to make the flare still look somewhat untouched.
Still a lot to do before next weekend. Jeep will likely be sitting til then. Ill be cruising in the pimp white Corolla in the background up there til then.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 05-08-2013, 06:56 PM   #306
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Ok back at it. Whew theres a part of me that really wants to just do a mild trim and say eff the flares. I think the biggest thing I hate about the trimmed look is how unfinished it looks with a stock bumper. But i do have that Dirtbound bumper comin... hmmm gna be a tough call.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 05-08-2013, 07:04 PM   #307
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Opinions on my situation anyone? Ima do some thinkin on it tonight. Im just worried the 32s will look smallish then but they are pretty beefy still so Idk.
Imagine my DBOR bumper is on and it looks badass from the front this way lol.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 05-08-2013, 07:12 PM   #308
davyboyXJ
what size/lift do u have on urs?
davyboyXJ is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 07:26 PM   #309
Weeder1
Cut it up!!!!
-98 xj sport-
Unread 05-08-2013, 08:11 PM   #310
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Im running RE 4.5" coils and add a leaf + 1" shackle, with 32x11.50s. Mine is on the lowish side for 4.5" tho, my 4.5" RC on my last red XJ was noticeably taller.
Originally Posted by Weeder1 View Post
Cut it up!!!!
Haha I know I know! I might do my trimming on the flares a bit and throw em on to wheel at a lil spot around here and see if it rubs. I just went ahead and pulled my front bumper in prep for the DBOR front.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 05-08-2013, 08:20 PM   #311
davyboyXJ
and urs rubs with 32's? mine with just a 2" lift cleared 32's fine. wheel specs are 15x8 -15 et
Unread 05-08-2013, 08:23 PM   #312
Weeder1
Cut it and be done! I can tell you want to sooooo bad. Haha take your time and put door edge on it so it looks factory.
-98 xj sport-
Unread 05-08-2013, 08:36 PM   #313
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Only rubbed at full lock backing up, and possibly only one direction lol. Are you saying you ran brand new 32" MT's on 2" lift with your flares and did not rub?
And Weeder, you are partially right lol. But mainly I want do the minimum necessary to make it work. If I go full on trim I know whats next. "ohhh I got all kinds of room, MOAARR TIRE!" and then the cycle goes on lol.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 05-08-2013, 08:46 PM   #314
Project1
How do you like those shocks .. I'm running them now too, before I had the cheap rough country ones and I think I may have liked the cheap ones better????
Project1 is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 08:47 PM   #315
Weeder1
Lmfao so true dude, so true. Looks good either way!
-98 xj sport-
