VegasGT's "Clifford The Big Red Unibody" - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
Unread 03-07-2013, 08:19 AM   #151
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Haha I saw that. Thats a big reason why Im pushing for getting sliders done ASAP.
@Luke95,
I plan to eventually go with relocation brackets, but want to pick up a little longer shackle first and go from there. Once it warms up Ill be getting to work on the fun part of the build. Straying away from bolt-ons and building everything. Cant wait to get started.
Here's a shackle for ya, I love 'em. JKS dogleg shackles, they are 2" longer so they provide 1" of lift. But cuz of the shape, they don't hang down far in the back
D3<!L!>3D
S8NNG8 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2013, 08:23 AM   #152
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
D3<!L!>3D
Unread 03-07-2013, 10:44 AM   #153
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Yea Ive been eyeballing those. Kinda put the shackle thing on the backburner for now, its not really all that low in the back, more of an illusion created by the front flares being mounted higher than the rears.
Ive had a bit of a hard-on for Napier PP flares here lately. May eventually do a bit of a go-between on my two possible build plans, picking up those flares and run 33s at current height.
That will have to wait a bit, In going to get some oddball maintenance needs caught up first. Got a roaring hub bearing thats in need of replacement, among other smaller things.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 03-07-2013, 10:51 AM   #154
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
On the flare issue, this is the stance when you get the front and rear clearance to match without trimming.
I really don't favor this look, but the problem is only .5" and it'd be perfect. I figure it'll sag to perfect eventually
D3<!L!>3D
Unread 03-07-2013, 11:08 AM   #155
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Yea, I think I know whats going to happen. Ill more than likely run a shackle and duplicate the stance from my last 99.
33x10.5 with trimmed front (wrapped in rubber pipe insulation) and OE rear flares. No rubbing. I just want to take extra care in doing all that because my current '99 is in significantly better shape than my last was.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-07-2013, 11:31 AM   #156
ibjeepin95
Jeep is looking good man! Keep up the good work.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2013, 12:44 PM   #157
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Thanks! Still a lot to do but it is the curse we all bear.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-07-2013, 01:27 PM   #158
gasperooch
1988 XJ Cherokee
So since the original build plans kinda went out the window, are you planning any gearing, axle, or tc mods?
gasperooch is offline   Reply With Quote Quick reply to this message
Unread 03-07-2013, 01:49 PM   #159
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
For now I think Ill let nature run its course. Go up in tire size, wheel til it breaks, upgrade, etc. I will be picking up an SYE and double cardan shaft at some point this summer though, regardless of other mods.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-07-2013, 03:32 PM   #160
Luke95
Needs moar welding.
Obligotry practice weld pics.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2013, 05:15 PM   #161
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Originally Posted by Luke95 View Post
Needs moar welding.
You need a little MORE education
D3<!L!>3D
Unread 03-07-2013, 06:18 PM   #162
Luke95
That was mocking pirate a bit
Sent from under my broken Heep
Unread 03-07-2013, 06:35 PM   #163
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Needs moar welding.
Im running behind on the build at the moment. Between house payment and frivelous purchases elsewhere Im a little tapped out on the fun spending for a little bit. That and its going to be nice for the first time in 3 weeks, so Ill probably opt to not spend the weekend under the Jeep on anything major.
Plan to spend the weekend over good drinks and ESPN, hopefully watching Duke beat the **** out of UNC Saturday if anybody watches college ball.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 03-07-2013, 06:35 PM   #164
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Aye sea!
D3<!L!>3D
Unread 03-10-2013, 12:37 PM   #165
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Nothing major but I put my wore down 31" spare in the back. Flipped the OE threaded rod up so it was a couple inches higher and ran it through the hole. It wouldnt fit on the original pedestal due to the soundbar, so I had to put it beside it. Backseat still latches though!
Nothing else really new. Ran new wires to rear speakers, and adjusted draglink to center the wheel. Need to pick up ZJ tierod. My OE rod refuses to budge for adjustment. Also put my OE amber parking lights back in, will likely sell the clears or tint them and reinstall. I missed the factory look of the amber lights.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
