VegasGT's "Clifford The Big Red Unibody" - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > VegasGT's "Clifford The Big Red Unibody"
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-16-2013, 11:05 AM   #1
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
EDIT. Current Photos as of 10/31/14:
Not new to XJ's by any means, Ive had several and I had no intent on making a build thread for my latest. I have no extreme plans, as the Jeep is my primary DD. Things never go as planned though, and my original plans of Rubi wheels and no lift were quickly tossed out. However the new XJ is pretty clean (dent and mostly scratch/rust free), so the build will be based around the ideaology of a mild yet capable rig thats easy on the eyes without going all out on spending.
Jeep is a solid '99 XJ, 4.0/AW4 with hp30 and 8.25. Bought it off an old man that took good care of it and stayed up on maintenance for the most part. Has lots of new gaskets and everything is in nice shape in and out.
Heres a few pics to get started from the day I got it.
More to come!
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 11:16 AM   #2
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Wasnt long until I had it up in the air to start the teardown.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-16-2013, 11:31 AM   #3
Luke95
Needs updates.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 01-16-2013, 11:35 AM   #4
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Originally Posted by Luke95 View Post
Needs updates.
Lol I just posted 15 minutes ago.
Im tooling around at work for the moment, will be adding more progress when I get a time gap. Do not fear haha.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-16-2013, 12:09 PM   #5
paintball10148
Needs updates.
Hahaha xD that's funny... I agree, this build thread is taking too long... Haha but seriously.. That's a good looking jeep to start with!
1997 zj 4.0 np242 5.5" iro lift. 33x12.5r15 khumo mtrs.---- rolled and sold :'(
1997 zj ltd 4.0 np249 black np 4" rough country lift 33x12.5r15 mtrs.----sold
1999 xj sport 4.0 np242 waiting for 4.5." Lift and 33s :D
paintball10148 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 01:43 PM   #6
moses21
I wish my jeep was that clean!
moses21 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 02:01 PM   #7
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Haha thanks^
For the sake of keeping this moving, heres some more progress.
I went cheap on the lift as Im not 100% certain that I wont upgrade to 4.5" down the road. Used FatBobs garage 3" spacers (same as I used on my 01 with good results) and a long add a leaf. Until I track down fair priced JK Rubi shocks I just spaced up my lower front shock mounts for now.
Prior to tearing anything down I PB Blasted all the bolts for a few days. My last 99 XJ was options wise the same exact Jeep but a lot rougher, and I named it "Resistance" because it fought me the whole way through. Seemed like I broke every bolt I touched on that Jeep. Broke trackbar bolt, u-bolts, swaybar links, LCA bolts, nearly everything. With how clean this Jeep was I expected things to go much smoother.
Starting with the trackbar I noticed it was wore out badly so I pulled the frame side off first. Took a BFH but it came out without too much fuss. By taking frame side off first this guaranteed me that the axle side bolt would not be under any extra pressure. I put a lil pressure on it and broke the head off almost instantly. Piss. Cut the old bolt out and replaced it with 10mmx75mm 1.5p metric grade 12.9 bolt and grabbed a new tracbar. With exception to one swaybar endlink the front end went smooth otherwise.
The rear went downhill. The Hulk torqued down my u-bolts, so I had to slowly muscle those off, but otherwise all was ok until i got to the shocks. Rear upper shock mount breakage has been well documented, and lets just say ive been there a time or seven. I left those alone since I did not have any replacement shocks at the time. I went to unbolt the nut on the lower mount and snapped all the threads off. Uhhh ohhh. Other side? SNAP.
Checked the forums to see others with the problem cut and drilled it all out but thats a big job. The load bearing shank was still instact, only the threads were absent. Ill get pics of my fix later on but I just grinded the remaining threads away, welded threads from a grade 8 bolt back on and put it back together. Holding up great. To sum it all up, the rear end had the sparks a-flyin'.
Finished height on training wheels.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-16-2013, 02:56 PM   #8
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
The height was right now, but it definately needs more appropriate shoes. In the meantime however I had some other things to address. Bumper caps and trim were faded so I put them in my little "has no use at all" pile with a couple rear swaybars.
Painted the bumper caps with Duplicolor Trim Paint. Nice finish for the job. At the time of photo I had yet to gain the motivation to remove the door trim tape.
And fixed here:
After that I placed another order to jegs. Overused rims but they just work and I dig the look/backspacing (4").
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-16-2013, 02:57 PM   #9
ibjeepin95
Needs more dents .!..!.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2013, 03:12 PM   #10
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Haha one of these days Im going to have a trail only rig and Im gna beat the everliving **** out of it just for you lol.
This one will likely see some damage in time. My lil girl is big enough to go along on rides now so I can get around to wheeling more often. Im going to try and snag some ungodly wide sliders to do the tree pivoting for me. From past experience after the first dent you just dont care anymore haha.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-17-2013, 10:52 AM   #11
NJXJ91
I like the way this build is headed
NJXJ91 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2013, 11:12 AM   #12
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
^ Thanks man! Better things to come!
Forgot to mention but somewhere along the line I added Autopal H4 lights and clear marker lights. I am going to wait til it warms up some for a harness upgrade. The housings alone increased usable light enough to keep me happy for now.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-17-2013, 11:18 AM   #13
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Also, ive got 3 Firestone Destination MT's of the 31" variety Im going to pull out of retirement to mount on the Cragars. Ill just order a 4th one to fill the set out. The others are 50-60% tread, they wear really well so Ill likely buy one or two at a time til I end up with an all new set. Keep from having a big hit at once and Ill have several good spares that way.
This is what they look like for those not familiar.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-17-2013, 05:48 PM   #14
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
Moarr junkk mounted up!
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
Unread 01-17-2013, 08:29 PM   #15
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
You go through more Jeeps than I do haha. Moar!
Amp'd 2014 JK - Build Thread
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline   Reply With Quote Quick reply to this message
