VegasGT's "Clifford The Big Red Unibody" - Page 32 - JeepForum.com
post #466 of 2859 Old 06-13-2013, 09:58 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'm all about saving money. I would rather take the 1/2 step(LSD) vs. The locker(which has potential to break things). I'd go full lock, f&r, w/bigger axles if it weren't a dd.
D3<!L!>3D
S8NNG8 is online now
post #467 of 2859 Old 06-13-2013, 09:59 AM
alexrule123
alexrule123's Avatar
Originally Posted by S8NNG8
Oh, you can beat that feeling. Laughing at a broken axle shaft, when the victim wasn't even on a tough part of a trail.
Or laughing at an LSD rig that lifted one tire off the ground and now acts like it has an open diff.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #468 of 2859 Old 06-13-2013, 10:12 AM Thread Starter
VegasGT
1988 MJ Comanche
Im not too worried about breakage on 32's. Ive got trail spares if I do though. I wouldnt waste money on an LSD honestly.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #469 of 2859 Old 06-13-2013, 10:14 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I see where this is a possibility, but a little tug, and I can drive away instead of pulling out the hi-lift and spare shaft.
D3<!L!>3D
post #470 of 2859 Old 06-13-2013, 10:15 AM Thread Starter
VegasGT
1988 MJ Comanche
So true.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #471 of 2859 Old 06-13-2013, 10:41 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I have to admit, I don't need the locker. You guys wheel way more and way harder than I do. You're probably better off with a locker, but how many shafts are you willing to break. At some point you realize 'I coulda bought a bigger axle with how much I've spent on this D30.'
D3<!L!>3D
post #472 of 2859 Old 06-13-2013, 10:52 AM Thread Starter
VegasGT
1988 MJ Comanche
We are not talking about a D35 here, man. Theres plenty of people running locked 30's very reliably, even ibjeepins only broke a couple shafts running 35's. Breakages happen but I wouldnt consider a d30 to be a weak axle within reasonable tire size.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #473 of 2859 Old 06-13-2013, 11:07 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
There are a lot of experiences I haven't had. I don't wheel my rig lookin' to push it to its limits. I find my joy in showing up the non-Jeeps, which is pretty easy wheelin'.
If it makes you feel better, I'd say you talked me out of wasting the $ on an LSD
D3<!L!>3D
post #474 of 2859 Old 06-13-2013, 11:11 AM Thread Starter
VegasGT
1988 MJ Comanche
Its all good man, my main motivation is the guys I wheel with are locked f/r, and having open diffs has really made certain obstacles a lot harder than they should be. So I have been long overdue a good locker lol
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #475 of 2859 Old 06-13-2013, 11:15 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
On a '60's Bronco w/ 9"rear & D44 front, is the front diff on the correct side for an XJ.
D3<!L!>3D
post #476 of 2859 Old 06-13-2013, 11:20 AM Thread Starter
VegasGT
1988 MJ Comanche
Not sure on that one.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #477 of 2859 Old 06-13-2013, 11:31 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
On one like this... I found 1 I may be able to buy.
D3<!L!>3D
post #478 of 2859 Old 06-13-2013, 11:40 AM
Luke95
This. I'd rather break shafts then get pussed ad floor it and break other stuff
And as far as as many shafts I don't have a problem I get them at work for $5 a peice or $40 with a good unit bearing
Sent from my xj
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #479 of 2859 Old 06-13-2013, 11:43 AM
Spokes
Sent from my xj
self control my friend haha ill try anything in my jeep. but if i no its not going to happen i just drive away. because i always remind myself that i need to drive it to school,work,gf,food,and anywhere else i plan on going
...well i did get my limabean good to go now so its less of a DD but still haha
oh and yes the bronco rears should work. just make sure they 44 wedges arent cast! other wise you should be good! the cast were in the late 70s though but still double check!
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #480 of 2859 Old 06-13-2013, 11:56 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
No, I wanna know about the front diff being on the proper side?.
D3<!L!>3D
