Using Old XJ Alternator as a Motor - JeepForum.com
post #1 of 5 Old 09-11-2013, 02:58 PM Thread Starter
korneld
I just pulled my alternator, the bearing started to go. Got a new one, installed it, but now I'm thinking to keep the old one and play with it.
You see people applying voltage to their alternators on YouTube and they run just fine. I can't get it to work though. I hook up my hot lead to the terminal and I attach the ground to the housing and nothing happens. What am I missing here? I've tried 12 and 24 volts from car batteries. Btw, it should work without the coil inside energized. This is according to the videos anyway.
korneld is offline
post #2 of 5 Old 09-11-2013, 03:17 PM
sAe23
1995 XJ Cherokee
Apparently there is more to it that just hooking up power... One site I Googled (I am NOT an engineer and have NEVER tried this) implied there are internal mods that need to be done, along with external controllers. They also used 36 volts to get it to work.
FWIW, I Googled "alternator as a motor".
Good luck!
sAe23 is offline
post #3 of 5 Old 09-11-2013, 03:49 PM
wgirvine
1992 XJ Cherokee
Nope, won't work. You can supply 12 volts to a GENERATOR, and it will turn (but very weak.) But not an alternator. They just don't work that way.
The road goes on forever, the party never ends....
wgirvine is offline
post #4 of 5 Old 09-11-2013, 07:12 PM
sAe23
1995 XJ Cherokee
Yeah, I was having my doubts, but hey, it's on the Internet so it must be true
sAe23 is offline
post #5 of 5 Old 09-12-2013, 09:40 PM
Muddy97Cherokee
1997 XJ Cherokee
Ya, it's definitely not as simple as just throwing the alternator on the belt.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
