TPS?, no. IAC?, no... look what I found!!! - JeepForum.com
post #1 of 74 Old 03-29-2011, 11:53 AM Thread Starter
NW99XJ
On my way into work this morning.... got on the freeway, and the throttle stuck open. Stomped on it, that didn't work... pulled up on the pedal, that didn't work. By this time i had to dodge in and out of traffic. I finally turned off the ignition, put it in neutral, and coasted to the side. THAT SUCKED. 30-40 minutes later of pullin on cables, linkage, and inspecting plugs.... I disconnected just about every plug/harness on the throttle body which dropped the rpm's from 4k to about 3k.... which i very carefully limped back to the house with. Turning off the ignition, and putting it back into neutral when coming to a stop light. Got home and hit the forums... all the searches were leading me to a faulty Throttle Position Sensor (TPS), or the Idle Air Control Valve (IAC). So after calling around to several parts stores, finally but the bullet and picked both sensors up for $120. Got back to the house, and started to pull off the Throttle body. Upon removing the intake hose, i saw THIS:
Closer look:
Thank you Spectre Air Filters for not securing your fancy name plate!
(i'll be writing a letter tonight for sure)
While i was inspecting the damage (if there was any) i figured i'd clean things up while in there. Cleaned out the throttle body real good, (forgot to take before and after pics of that) and pulled out the IAC for a cleaning anyways. Glad I did!:
That was the before, and here's the after. (Yes its the same part!)
The Jeep idles fine now, however I still have CEL on (prob from driving with all the sensors disconnected.) I'm resetting the ECU now. I did notice though, that when i give it gas, it takes its own sweet time coming back down to idle. Figured that SHOULD drop pretty quick. It takes less that a second to rev up, but takes several seconds to come back down. It DOES do it, just slow and steady. We'll see if resetting the ECU and a drive clears that up or not.
Any thoughts on this?
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #2 of 74 Old 03-29-2011, 12:28 PM
avbcon12
Holy crap!
This is why I never put cheap parts into my cars! Glad you found it and that it was big enought o not get sucked all the way in!
avbcon12 is offline
post #3 of 74 Old 03-29-2011, 12:28 PM
jeepkid03
Winning
jeepkid03's Avatar
That sucks I would be pissed. You could've got in an accident or caused one. As far as the sensors. Disconnect the battery for like 15 minutes, then reconnect and let the jeep idle undisturbed until it reaches operating temp. This is how the computer relearns the idle.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #4 of 74 Old 03-29-2011, 01:03 PM
PhilipJ
PhilipJ's Avatar
After finally figuring out what that was and how it got in there...I definitely won't be putting their crap in my XJ. That stupid little bar is just a nameplate they stick on all of their filters, functioning only as a brand identifier. So stupid.
And yeah, throttle bodies can get pretty nasty. Wouldn't be a bad idea to pull it off and clean it up once a year.
PhilipJ is offline
post #5 of 74 Old 03-31-2011, 02:54 PM Thread Starter
NW99XJ
Sent off a letter to Spectre Performance last night. 5 pages including the pictures form above, and a PDF scan of the original receipt. a little too long to post here. But if you guys want me to, I'll go ahead and post it anyways. In my research, i found several others who had this exact same thing happen to them. A few guys on NAXJA, several Dodge guys from various Dodge forums, and a Chevy blazer guy. ALL had the same B.S. happen to them. One of the guys from NAXJA got a reply back, telling him that they would send him a new filter, one with out a name badge, and they'd pay for the shipping of him sending his old one back.... UNBELIEVABLE! In my letter i told them I thought that it was insulting to offer a customer something he already had... a filter w/o a name plate. I also said I would not be dissuaded so easily. I'm not going to let this go without a fight.
NW99XJ is offline
post #6 of 74 Old 03-31-2011, 11:09 PM
scavok
1993 XJ Cherokee
I hope you don't. Freak things happen, I can accept that. But if this has happened multiple times then it is a serious concern that will kill someone eventually and it needs to be taken care of.
ScavoK
scavok is offline
post #7 of 74 Old 03-31-2011, 11:15 PM
carguy68ssrs
1977 CJ5
Where did the name plate go on the filter? Trying to figure out how it got inside of air filter.
carguy68ssrs is offline
post #8 of 74 Old 03-31-2011, 11:21 PM
PhilipJ
PhilipJ's Avatar
It just lays across one of the filter ribs, probably loosely crimped on from the looks of it. Still impressive that it got sucked through the tubing.
PhilipJ is offline
post #9 of 74 Old 04-01-2011, 12:37 AM
carguy68ssrs
1977 CJ5
So now he has a hole in his filter?
post #10 of 74 Old 04-01-2011, 12:53 AM
PhilipJ
PhilipJ's Avatar
No, it just sits on top. You can see it in the pic:
http://www.spectreperformance.com/#CATALOG.883901
PhilipJ is offline
post #11 of 74 Old 04-01-2011, 06:58 AM
96-XJ
1972 CJ5
i remember that somthing like this happened to me in my 1st car a honda. i turned the ignition off while it was moving (stupid i know i was 16 and i panicked) and the steering wheel locked. thank god there was no cars coming the other direction
96-XJ is offline
post #12 of 74 Old 04-01-2011, 10:53 AM
jeeptorino68
1992 XJ Cherokee
there was one of these filters in an XJ in the junkyard, with the name plate, how did the name plate get into the air tube? is there a gap in the filter under the name plate? and the plate crimps the filter ends together or something?
i thought about snagging it, but the wire mesh was rusting, and then i remembered this thread.
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #13 of 74 Old 04-01-2011, 11:34 AM
the_weirdo
the_weirdo's Avatar
The name plate is facing the tube side. The air comes up from the bottom of the box, through the filter, pulls off the name plate, and shoots it into the tube.
the_weirdo is offline
post #14 of 74 Old 04-01-2011, 12:07 PM
jeeptorino68
1992 XJ Cherokee
oh so it was a drop in filter?
in the factory box?
or cone?
Kyle
post #15 of 74 Old 04-01-2011, 01:47 PM
carguy68ssrs
1977 CJ5
I say bogus thread, no way something that big gets past filter
Found out I got a D44 Flexinxj XJ/MJ Cherokee Non-Technical Forum 13 03-29-2009 07:59 PM
Look what I found mpwal099 XJ Cherokee Technical Forum 6 02-28-2008 03:37 PM
I think I found one Axl Jack XJ Cherokee Technical Forum 34 01-10-2008 06:31 PM
I found an XJ razzergreen XJ Cherokee Technical Forum 14 07-06-2006 02:50 PM
look what I found Jeepin_Al XJ Cherokee Technical Forum 13 01-10-2005 08:10 AM
