Towing capacity 99 Jeep Cherokee - JeepForum.com
post #1 of 5 Old 07-02-2013, 05:28 PM Thread Starter
laur99cherokee
What is the towing capacity of a 1999 Jeep Cherokee 4WD sport utility 4.0 liter 6 cyl with a class III hitch?
I'd like tow a travel trailer a long distance that weighs 3780lbs and wondered if my jeep was capable.
laur99cherokee is offline
post #2 of 5 Old 07-03-2013, 08:24 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Welcome to jeepforum.
The factory tow rating for an XJ Cherokee is 5,000 lbs and a class II hitch is rated for that as well.
The factory cargo capacity rating for your jeep is 500 lbs. With the ideal tongue weight for a trailer being 10-15% of it's total weight, the tongue weight of the travel trailer you mention will likely just about max out a factory set of rear leaf springs, so you'll probably not want to pull that trailer on stock springs with 4 passengers and a load of gear as well, but should be okay weight-wise if you're running solo or nearly so. You could always beef up the rear leaf packs if more weight capacity is needed.
The biggest challenge for your XJ towing that trailer will be stopping it, particularly in less than ideal conditions such as in rain or on gravel. If the trailer has brakes and you hook up a brake controller for them in your jeep, I think you should be good to go.
***Chris***
chris87xj is offline
post #3 of 5 Old 07-04-2013, 05:59 AM
MossGreen97
1997 XJ Cherokee
I have towed a TT that had a dry weight about the same. My XJ has the factory tow set up with aux. cooler, wiring harness w/ 7 pin connector. To trailer weighed aprox. 5000 lbs. at the time due to being loaded with hurricane evacuation gear and such(not my choice here). A weight distributing hitch along with a sway control is a must. The hitch levels out the Jeep, distributing weight front and back. The sway control lessens the the side to side wiggle the trailer will due even at moderate speeds. An adjustable electronic brake controller for the trailer brakes(which the trailer should have) is a must.
Braking and pulling with this load over flat terrain was not a problem. Hills were! The wind is another consideration. The XJ is a very light vehicle considering and not nearly wide enough to tow a TT that size. You must have mirrors extensions wide enough to see around the sides of the trailer in traffic.
Gas mileage went from 20 mpg to 10 mpg while towing (don't use OD while towing).
Good luck.
'97 XJ Moss Green Metallic. 2DR. 2WD AW4 tow pkg.,3.73 gears. Firestone Destination A/T 225/75x15.
MossGreen97 is offline
post #4 of 5 Old 07-04-2013, 07:22 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
IMO 5000 lbs is an overly generous tow rating for such a light vehicle as the XJ Cherokee. Towing almost 4,000 will be real challenge, especially if you are not skilled and experienced with towing. From experience, I would recommend a larger tow rig for that load.
If you choose to continue:
1) Install a transmission cooler.
2) Use 3rd on the transmission, OD will generate too much heat, even with a cooler.
3) Trailer brakes are not optional.
4) Practice towing before your trip begins.
CJ7-Tim is offline
post #5 of 5 Old 07-04-2013, 06:05 PM
MossGreen97
1997 XJ Cherokee
I would agree with CJ7-Tim. The Cherokee is too light and too narrow for that kind of load. I did it twice out of necessity but will not do again. Lesson learned, and both I and the XJ survived.
