Tow Hooks? D-Rings? - JeepForum.com
post #1 of 17 Old 04-15-2009, 12:44 PM Thread Starter
scclemson
Xj Tow Hooks? D-Rings?
I own a '96 XJ, and am looking into getting some Tow Hooks or D-Rings for the front and/or rear of my Cherokee.
What's the difference between them? Which is better? What is required to install them? Where can I find some?
scclemson is offline
post #2 of 17 Old 04-15-2009, 12:53 PM
Motorcharge
d ring and clevis generally goes on a bumper or hitch, tow hooks need plates that bolt to the frame.
Tow hooks are def cheaper.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 17 Old 04-15-2009, 01:57 PM
alexrule123
alexrule123's Avatar
I am a fan of d-rings but right now i have tow hooks on the front of mine, I just haven't had a chance to put the d-ring blocks on to use the d-rings.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #4 of 17 Old 04-15-2009, 03:11 PM
XJAl
1993 XJ Cherokee
Get a set of C4X4 fabrication tow hooks and brackets. I have had these on my XJ for over a year and have used them several times without any problems. Here's the link: http://http://www.custom4x4fabricati.../recovery.html
1999 XJ SE - Sold
1989 XJ- Sold
1989 XJ Wagoneer Limited
1993 XJ Sport
XJAl is offline
post #5 of 17 Old 04-15-2009, 03:31 PM
liquidforceb069
liquidforceb069's Avatar
i have d rings on my front bumper and one in my hitch in there rear.. i like them better cause the people i know that have tow hooks sometimes the strap falls off and its annoying to keep getting out and putting it back in... plus i saw a tow strap with a metal hook on the end fling off a tow hook and go through my friends window on his truck soooo...... i prefer d rings!
98 XJ Sport
8.5" BDS LA With Gas Shocks
Allied Rock 8 32Blt Beadlocks With 35" Trxus M/T's
RE Hack N' Tap
RE CVF Driveshaft 33.5" In Length
Warn Front Bumper With Winch
IPF Headlight Conversion
Drawtite Roof Rack
15% Tint All Around
Autolite Iridium XP Plugs And Wires
Optima Red Top
Tow Rig
2000 Dodge Ram 2500 Black
liquidforceb069 is offline
post #6 of 17 Old 04-15-2009, 03:56 PM Thread Starter
scclemson
Possibly then I'll put D-Rings on my Reese hitch in the rear and attach tow hooks to my frame in the front. Anyone know where I can get some good D-Ring sets?
post #7 of 17 Old 04-15-2009, 06:32 PM
1996BlackXJ
Local hardware store, or if you can find a deal online.
Here's a link I have bookmarked
http://www.trailduty.com/product_inf...products_id=34
Best online price I have found
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #8 of 17 Old 04-15-2009, 09:54 PM
the303hooligan
are you aware that they need to have a VERY sturdy welded tabs on bumper or whatever you plan on putting them on? they dont just come with brackets that u can screw on to a hitch or bumper..You can however get a hitch receiver kit that you plug right into ur hitch..(i have 2 of theses types for extra recov. points just in case).http://www.4x4groupbuy.com/store/rec...ng-p-3371.html..Sorry if u are aware of this..but your question seemed like u think you can pick up a kit and throw it on any surface....Just wanna make sure you do it a safe and reliable way....
Colorado Jeep Club Member #'303'
1998 Jeep Wrangler TJ Sport 4.0 I6, D30 and D44,4.56 G2 Gears,belly,gas & steering skids, 35x12.5 Wrangler MTR Kevlars,4" ProComp Coils,1.25" JKS BL,1"Currie MML,Bilstein 5100's, Chromoly LCA's front and rear, JKS Disco's,K&N intake,PSC BFH front stinger bumper w/winch & d-rings,PSC Rear stinger/carrier w/d-ring,PSC Rocker Knockers,Dynomax Ultraflo welded ss, APN header,PIAA 520 ATP, Bestop top,alpine CDA-105 deck,Tuffy underseat Security box, JL Audio speakers in sound bar and dash, Corbeau front seats, matching Neoprene cover on bench,trimmed flares...and PLENTY more to come..
**Oil Field Trash Makin' Oil Field Ca$h**
the303hooligan is offline
post #9 of 17 Old 04-15-2009, 10:48 PM
GregB_00XJ
I was thinking about a set of these....
May simply go with a receiver D Ring block for the hitch however.
For the front I have stock Chrysler Tow Hooks with the proper mounts.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #10 of 17 Old 04-15-2009, 10:53 PM
the303hooligan
I stand corrected on "cant just buy a set and screw them on a hitch"..ha..never seen those before...good find.
As far as "proper mounts" .. are you getting frame tie-in brackets or just using the hooks that are stock and maybe came with the jeep?
post #11 of 17 Old 04-15-2009, 11:41 PM
GregB_00XJ
Heh... yes, found them the other night when I was looking at their BPE's. Those Detours Class3 mounts look strong, and utilize what most people use (receiver hitch) for the rear. Actually they might even be better as they use 2 bolts each instead of one to tie in the receiver block?
The Front tow hooks are stock factory option tow hooks with the frame tie in mounts.
Same as these...
From this thread.
http://www.jeepforum.com/forum/f177/tow-hook-placement-730348/
They came on the jeep when I bought it. YAY free recovery crap!
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #12 of 17 Old 04-15-2009, 11:44 PM
ep191
Tow hooks are inexpensive, D-rings are nicer.
The strap constantly falls of tow hooks on multiple pulls, and i have even heard of straps getting torn in half from hooks.
D-rings you can take off to use in multiple different situations, i have even seen them used as a snatch block off a tree.
ep191 is offline
post #13 of 17 Old 04-15-2009, 11:46 PM
25jon25
those detours reciver d ring things are pretty neat but easy to make if you have a welder. I made a set that seem to work good.
25jon25 is offline
post #14 of 17 Old 04-16-2009, 01:28 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Since the XJ uni-body frame rails are no more suitable for recovery point mounting than the stock bumpers are, you'll need a load-spreading reinforcing plate for whatever form of attachment point you chose.
Many folks choose hooks for ease of strap hook-up, but since a strap will come off that hook as easily as it goes on, I prefer d-rings. Check out the setup in this thread. http://www.jeepforum.com/forum/showthread.php?t=747764 . I don't have any experience with it myself, but seems like it would serve the need.
***Chris***
chris87xj is offline
post #15 of 17 Old 04-16-2009, 01:33 AM
Veeb0rg
1995 XJ Cherokee
you can always put the tow hook brackets on and then use http://cgi.ebay.com/ebaymotors/D-Rin...spagenameZWD1V to attach d-rings to em
I do recommend c4x4 towhook kit, the brackets they send are just freaking pure beef.
Veeb0rg is offline
D rings or hooks? COLOUXJ XJ/MJ Cherokee Non-Technical Forum 29 03-18-2009 10:22 PM
Tow hooks or d-rings? 600dollarXJ XJ Cherokee Technical Forum 18 01-02-2008 10:53 AM
o rings 91xjgawes XJ Cherokee Technical Forum 4 05-10-2006 01:43 PM
C4X4 Tow Hooks VS. Rustys Tow Hooks??? bamafan378 XJ Cherokee Technical Forum 10 02-11-2006 09:15 AM
tow hooks vs. d rings 94xj1 XJ Cherokee Technical Forum 5 10-02-2002 12:50 PM
