Tow Hook Mount Kit with D-Ring Mounts
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Does anyone have these?
XJ Recovery Products Im looking to order these but wondering about the install, do they mount to the existing holes or do you need to drill? also looking at my jeep the left side already has bolts and the right side does not does anyone know about this? Any information would be highly appreciated. thanks
#2 |
I have c4x4 brackets which are very similar, and they bolted to my XJ using all pre existing holes.
#3 |
By any chance do you have a picture of the mounting location?
#4 |
dring mounts
I have these, they are very simple to install, they use the existing holes and sway bar mounts, the left side bolts you are refering to are the steering box bolts, the kit uses these bolts to hold part of the braket on while the right side has minimal drilling because one of the existing holes has a little lip on the inside you have to shave off, a brill bit works the best. You do have to remove your upper sway bar mounts though. I love them and I think they are very strong. I did have to trim my plastic cowl thingy under my bumper, but if you dont have it then no worries.
Heres some info http://www.jeepforum.com/forum/f11/hooks-vs-shackles-863426/ |
#5 |
FYI- if you get these make sure you heat up those power steering box bolts before you remove them. PB blaster was no match for the bolt that was seized in the power steering box bracket that the bolts go through.
#6 |
I think im gonna invest in some of those D-Ring mounts once i get the money.. winters coming.. prolly gonna get stuck haha
http://www.jeepforum.com/forum/f177/01-xj-build-thread-1005537/ My Build Thread |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
