Tires - JeepForum.com
post #1 of 7 Old 09-15-2013, 05:07 PM Thread Starter
troydg
Tires
Do I need new rims for 31 inch tires?
troydg is offline
post #2 of 7 Old 09-15-2013, 05:52 PM
LimeLJ
LimeLJ's Avatar
Not to mount the tires, but rims with less backspacing may resolve issues with tire rubbing. 31" is the range where it could go in either direction for rubbing depending on the tire. Some are fine and others have issues.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #3 of 7 Old 09-15-2013, 06:09 PM Thread Starter
troydg
Well I'm putting a 3 in lift tomorrow so if I threw 31's on stock rims would I be good?
troydg is offline
post #4 of 7 Old 09-15-2013, 06:13 PM
Finallyajeep
With 3 inches you should be good with 31's, might rub on full steering lock on the control arms, but you will find out.
Firefighters Jeep Club
Finallyajeep is offline
post #5 of 7 Old 09-15-2013, 08:15 PM
rugsucka
Assuming they're 31x10.5x15R the tires will fit the rims very well and hold a bead if you air down to low psi offroad.
They WILL rub stock control arms at full lock unless you adjust your steering stops out or put spacers on.
You could also consider stock WJ Lower Control Arms which bolt up with a minor bushing modification. They have a bend in them to clear the tire when the steering is fully locked.
or
Buy aftermarket rims with 4" backspacing vs stock 5.25". You will clear your stock arms with that extra 1.25" offset.
rugsucka is offline
post #6 of 7 Old 09-15-2013, 08:43 PM Thread Starter
troydg
If I got wheel spacers would that make a difference? Thanks for the help also their bf Goodrich ATs
troydg is offline
post #7 of 7 Old 09-15-2013, 09:11 PM
LimeLJ
LimeLJ's Avatar
Yes, wheel spacers can be substituted for new rims. However, at $220 for a set of good spacers a set of aftermarket rims is not too far off.
LimeLJ is offline
