tire size question no lift 95 Cherokee - JeepForum.com
post #1 of 23 Old 01-17-2011, 11:57 AM Thread Starter
rmetts
1995 XJ Cherokee
I'm getting ready to replace the tires on my Cherokee 4wd 1995. What would be the largest all terrain or maybe mild mud tire I could fit on it without a lift? I'm considering a small lift, but it needs to be budget. I'm not spending 600.00 for a lift and I don't want a bunch of problems to sort out.
Any suggestions?
Thanks
Ron
rmetts is offline
post #2 of 23 Old 01-17-2011, 12:00 PM
LobstahJeep
235 75 15's on stock height are pretty much the biggest you can go... That's what I have on my stock height Jeep, and while they don't rub at all, there's not much room for more.
1981 CJ7
2001 XJ
ΜΟΛΩΝ ΛΑΒΕ
LobstahJeep is offline
post #3 of 23 Old 01-17-2011, 12:11 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I agree, Iran that size for years at stock height and also with 2" lift. 30's will fit, but you will have some occasional rubbing.
xjfever is offline
post #4 of 23 Old 01-17-2011, 05:27 PM Thread Starter
rmetts
1995 XJ Cherokee
xjfever, do you mean 30's will fit with a little rubbing with OR without the lift? Likewise, If I get one of the out of the box 2" lifts to fit 30's will I have to do anything but install the components/follow the directions with it?
Thanks for the help
Ron
rmetts is offline
post #5 of 23 Old 01-17-2011, 05:35 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The 30's will fit it stock with minor rubbing, but will clear fine with 2" lift. The budget boost will require removing the coils and adding the spacer above it, but it can be done with basic tools and a good set of jackstands. Depending on which 2" lift you get you may have to seperate the rear leafs and add an extra leaf in or just remove the rear shackle and install a longer one. The directions may be a little vague depending on which one you go with but you can get all the info you need here on the install. Good luck with whichever you decide on and keep us posted with the progress.
xjfever is offline
post #6 of 23 Old 01-17-2011, 06:10 PM
steveedogg
budget lift and add a leafs will give you nothing but problems speaking from experience. you can put on 30-9.50x15 or 235/75/15 your choice, the 30's are a little bigger and wider. i had 30's and my stock xj and hated them. 235's are the way to go
99' Cherokee XJ sport R.I.P
97' Wrangler TJ work in progress :)
steveedogg is offline
post #7 of 23 Old 01-17-2011, 07:26 PM
DoctorTim
check your steering before you get the lift, if your ball joints are bad, a 2" lift will end up costing 600
BEWARE OF THE DEATH WOBBLE
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #8 of 23 Old 01-17-2011, 10:46 PM
Yucca-man
If your ball joints are bad, they're going to need a replacement either way.
For a stock Cherokee, 235/75R15 is pretty much the largest you're going to fit without rubbing, and even then you may find rubbing issues from time to time when turning and flexing. Part of that will depend on the wheel - with 15x6 stock rims, I never had rubbing on my '89 XJ. Likewise with 15x7 stock rims on my white '96 - no rubbing.
With 15x7 (unknown backspace) on my red '96 I rub occasionally, but oddly only while reversing while turned and flexing.
I only fit 30s on my white '96 after I put a 2" Budget Boost on; I'm not sure I'd even try it on a stock lift unless I didn't care about my sheetmetal.
Yucca-man is offline
post #9 of 23 Old 01-17-2011, 11:03 PM
Yucca-man
That's what we're here for - ask away.
post #10 of 23 Old 01-18-2011, 01:32 AM
DoctorTim
my ball joints are bad, but no death wobble yet (no lift installed). just sayin that it's still driveable (sometimes) until you put a lift on which in my case will definitely end up with death wobble
its kinda sketchy when your jeep starts changing lanes on its own so im replacing them anyways.
post #11 of 23 Old 01-18-2011, 02:18 AM
GregB_00XJ
My 2000 was running 235 x 75 x 16 on the stock Icons for the better part of a year. Rubbed a tiny bit on the LCA at full lock when you hit a bump, other than that no problems. They looked great and worked great, but looked SILLY when I added 3" of lift, so on went the 31".
I believe they worked out to be around a 29.8 or something like that, so a 30" tire.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #12 of 23 Old 01-18-2011, 06:20 AM
robhurlburt
how so?
robhurlburt is offline
post #13 of 23 Old 01-19-2011, 12:44 AM
DoctorTim
Originally Posted by robhurlburt View Post
how so?
if you have bad ball joints, but no death wobble... lifting the thing will be a catalyst for death wobble (in most cases)
post #14 of 23 Old 01-23-2014, 11:38 PM
jonnymilano
1994 XJ Cherokee
I've got a 1989 Cherokee, stock, that I'd like to put 235/75R15's on. Are you sure that they won't rub anywhere?
jonnymilano is offline
post #15 of 23 Old 01-24-2014, 12:33 AM
xjwheeler32
1990 XJ Cherokee
I have 235/75/15 on my 90 and am positive they don't rub, not even at stock full flex.
xjwheeler32 is offline
Best tire size for Cherokee w/ 2" lift? JeepsJeeps XJ Cherokee Technical Forum 35 12-27-2011 10:22 PM
gettin another cherokee. how much lift and what tire size? codyf44 XJ Cherokee Technical Forum 1 01-24-2010 06:39 PM
Biggest Tire size on 95 cherokee with no lift? dirtyjeepgirl69 XJ Cherokee Technical Forum 1 12-23-2009 06:31 AM
1991 Cherokee tire size question baldone XJ Cherokee Technical Forum 5 09-02-2009 10:59 PM
2000 cherokee with a Rubicon Express Lift..tire size?? BigJake737 XJ Cherokee Technical Forum 5 02-16-2009 08:17 PM
