Tips, things to look for when trimming flairs tomorrow - JeepForum.com
post #1 of 8 Old 07-28-2011, 10:48 PM Thread Starter
Joshharris98xj
So tomorrow I will be trimming my fender flairs with the cut and fold any tips or things I should look for/do
And if you have any pics if your setup now before or after will help thanks
Joshharris98xj is offline
post #2 of 8 Old 07-29-2011, 12:01 AM
Greenxj
have a good face shield so you can see... took off the flare cut above the factory holder crap took the end caps off ...... looks alright if not weather stripping cleans it up
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)--o-)_)
Greenxj is offline
post #3 of 8 Old 07-29-2011, 12:03 AM Thread Starter
Joshharris98xj
So do you think it will look worse?
post #4 of 8 Old 07-29-2011, 12:18 AM
Greenxj
if you cant see by using a messed up face shield then it could when you look at it close, just go slow, let the sparks fly lol
______ooooo
/__l_l_,\____\,___
Greenxj is offline
post #5 of 8 Old 07-29-2011, 07:20 AM
donthelegend
If you're using an angle grinder to make your cuts, cover the paint with something. My paint is royally screwed from the sparks the cutoff wheel threw everywhere.
donthelegend is offline
post #6 of 8 Old 07-29-2011, 12:25 PM
lilnapsak
1997 XJ Cherokee
Use a dremel with reinforced cut off wheels. It will take longer to do but the results came out awesome for me. Its easier to control to get the cut you want
lilnapsak is offline
post #7 of 8 Old 07-29-2011, 02:23 PM Thread Starter
Joshharris98xj
I am using a grinder with a 4 1/2 blade and a sawzaw
post #8 of 8 Old 07-29-2011, 03:20 PM
mj40
1989 MJ Comanche
http://www.jeepforum.com/forum/f13/c...enders-737700/
guess the tape and take it slow... maybe a fine-24 tooth blade for the saw...
mj40 is offline
