Thundercracker Build Thread - Page 64 - JeepForum.com
Closed Thread
post #946 of 959 Old 11-12-2013, 08:31 PM Thread Starter
DNFJ
It was one of the boots on the spark plugs not being seated.
Drove it 40 miles tonight. Oh my god I missed it.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #947 of 959 Old 11-12-2013, 08:32 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Would that be the timing?
D3<!L!>3D
S8NNG8 is online now
post #948 of 959 Old 11-13-2013, 06:56 AM Thread Starter
DNFJ
Ahhh. Was on break at work and was going to go to the gas station to get cigarettes and the starter wire pulled away from the battery. Going to fix it on my lunch break.
Other than that she's running beautifully, now I should just come up with a name for her. New guts, new personality, y'know?
Previous:
DNFJ is offline
post #949 of 959 Old 11-13-2013, 09:52 PM
JeepRzKreepRz87
1987 XJ Cherokee
Just finished reading your thread good **** bro!
If its not one things its another.
Props on the new motor!
JeepRzKreepRz87 is offline
post #950 of 959 Old 11-14-2013, 06:51 AM Thread Starter
DNFJ
Thanks man! Yeah it's been a long year or so since I bought the thing.
I'm seriously considering making a new build thread and re-organizing it.
Previous:
DNFJ is offline
post #951 of 959 Old 11-15-2013, 04:18 AM Thread Starter
DNFJ
Slight ticking noise from near the rear of the engine now at idle. Given that I only hear it at idle, I think it's a minor exhaust leak.
Previous:
DNFJ is offline
post #952 of 959 Old 11-15-2013, 07:07 AM
Joshharris98xj
Check flex plate bolts
Joshharris98xj is offline
post #953 of 959 Old 11-15-2013, 07:17 AM Thread Starter
DNFJ
Seriously doubt it's those, I know the rear-most exhaust stud is missing, hence my assumption that it's an exhaust leak.
Previous:
DNFJ is offline
post #954 of 959 Old 11-15-2013, 09:42 AM
Joshharris98xj
Can't tell if your being a smart *** or not but you would be surprised. I have seen it pretty often cause the symptoms your referring to and it's a simple fix. Can't hurt to check them out...probably needs to be done anyway.
post #955 of 959 Old 11-15-2013, 10:00 AM Thread Starter
DNFJ
You realize that I just put this engine in right? Let alone the fact that I've re-checked every bolt on the entire driveline 3 times since installing it. Why would I assume it's the flex plate (and have to disassemble the entire engine-tranny connection) when I know that there is no bolt in the number 11 slot on the intake/exhaust manifolds?
Previous:
DNFJ is offline
post #956 of 959 Old 11-15-2013, 11:56 AM
Joshharris98xj
Ahh you are just a smart ***, you don't have to disassemble anything but the access panel on the bell housing...easy as pie. You just said you doubt it would be leading me to believe you have not checked them. Just trying to be helpful here.
post #957 of 959 Old 11-15-2013, 06:00 PM
Luke95
Potato!
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #958 of 959 Old 11-16-2013, 05:25 AM Thread Starter
DNFJ
You mean the flexplate to torque converter bolts?
Previous:
DNFJ is offline
post #959 of 959 Old 11-19-2013, 10:28 AM Thread Starter
DNFJ
New build thread, you're welcome guys
http://www.jeepforum.com/forum/f177/...hread-1807113/
Previous:
DNFJ is offline
Closed Thread
