Thundercracker Build Thread - Page 58 - JeepForum.com
post #856 of 959 Old 09-19-2013, 08:49 AM Thread Starter
DNFJ
Originally Posted by S8NNG8 View Post
That's a better plan...if you're willing to do all that work, wouldn't you just keep it then?
Probably. Just weighing options y'know?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #857 of 959 Old 09-19-2013, 08:58 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'm all for weighing options before I jump if you bought the 4.6 block from Quadratec you could just reuse all the bolt-ons you already have.
D3<!L!>3D
S8NNG8 is offline
post #858 of 959 Old 09-19-2013, 09:01 AM Thread Starter
DNFJ
Not going to do that either way. Best I'd do is buy a short block and build it over the winter.
Previous:
DNFJ is offline
post #859 of 959 Old 09-19-2013, 09:21 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I have a block for a 351 Cleveland I'm willing to sell
D3<!L!>3D
S8NNG8 is offline
post #860 of 959 Old 09-19-2013, 06:14 PM Thread Starter
DNFJ
Got denied for the loan, probably going to buy an ATK long block since they are only a few hundred more than a rebuild.
Previous:
DNFJ is offline
post #861 of 959 Old 09-19-2013, 06:54 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Well that's the spirit, right? Adapt and overcome.
I always say there's a reason for everything - guess the loan just wasn't meant to be.
Probably not what you wanna hear, I'm sure, but it could always be worse........
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #862 of 959 Old 09-20-2013, 03:57 AM Thread Starter
DNFJ
Doesn't mean I have the 2200 for the block.
Previous:
DNFJ is offline
post #863 of 959 Old 09-20-2013, 06:22 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Its too bad the engine you're looking for wouldn't be in the $800 models. I got one here in town with a D44 rear
D3<!L!>3D
S8NNG8 is offline
post #864 of 959 Old 09-20-2013, 10:07 AM
AKIQPilot
Real sorry to hear about you luck DNFJ. I would think good used 4.0's should be available in your area for $400 or less, maybe much less. Have you tried looking at local salvage yards or on Craigslist for a motor? I think any 4.0 from '91 to '01 would work for you, you would just have to install your accessories and electronics over to the new motor. Obviously stay away from any motor with a 331 head but other than that they should all work.
You obviously have the skills to swap out the motor so that part should be pretty easy for you. Hopefully you get it running soon.
AKIQPilot is offline
post #865 of 959 Old 09-20-2013, 10:11 AM
AKIQPilot
Here is a motor in the Youngstown area. Not sure how close that is.
Jeep 4.0 in Youngstown.
post #866 of 959 Old 09-20-2013, 03:00 PM Thread Starter
DNFJ
Only issue with that is that it's almost impossible to verify mileage.
Previous:
DNFJ is offline
post #867 of 959 Old 09-20-2013, 04:07 PM
AKIQPilot
You are right about that for sure. After just a little looking I found about 6 motors in your area from $250 to $600.
You could look at a few of the cheaper ones and see if you can confirm mileage as well as looking to see which one is the cleanest looking. You could buy the one you felt the best about and drop it in to get you back on the road.
Once you're back on the road you can take your time and disassemble your existing motor, clean everything spotless, inspect the crank, cam and Cyl that had a piston problem and then put a new rod and piston back in your existing motor. From that point you can decide if you are up for another motor swap or maybe just hold on to the motor for a spare.
Or you could skip all of that and just start the teardown and inspection today and get the motor back together and in the rig before the weekend is up.
post #868 of 959 Old 09-20-2013, 06:47 PM Thread Starter
DNFJ
Links to these motors? Can't find any on my craiglists.
Previous:
DNFJ is offline
post #869 of 959 Old 09-20-2013, 08:16 PM
AKIQPilot
Well based on your profile I can only assume you live near Pittsburgh PA. A quick CL search shows up with several 4.0 Cherokee motors and several others from rigs other than a Cherokee. I'm not implying these are all in Pittsburgh but they all come up with a CL search of Pittsburgh. I am quite sure there are several 4.0 motors available at your local salvage yards too.
http://pittsburgh.craigslist.org/pts/4049882419.html
http://youngstown.craigslist.org/for/4070601057.html
http://youngstown.craigslist.org/pts/4035587665.html
http://cleveland.craigslist.org/pts/4045857879.html
http://cleveland.craigslist.org/pts/4077082160.html
http://tuscarawas.craigslist.org/pts/4073028919.html
http://akroncanton.craigslist.org/for/4070610090.html
http://akroncanton.craigslist.org/bar/4067875362.html
post #870 of 959 Old 09-20-2013, 09:37 PM Thread Starter
DNFJ
Local salvage yards almost never have full motors and the full service yards around here are huge rip offs. But thanks sir.
Previous:
DNFJ is offline
Closed Thread
