Thundercracker Build Thread - Page 51 - JeepForum.com
post #751 of 959 Old 06-22-2013, 05:26 PM Thread Starter
DNFJ
Originally Posted by Luke95 View Post
Where's the video of you in the rocks???
Sent from my xj
That vid was the best I got they wouldnt let my buddy take a vid from close by.
Steering linkage and tre off
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #752 of 959 Old 06-22-2013, 08:21 PM
alexrule123
alexrule123's Avatar
Originally Posted by DNFJ View Post
Bad angle but if you look at the sway bar links you can see how off center the axle is.
And you can sort of see where the track bar kinked.
LOL sort of see? That thing is messed up! Reminds me of what I did to my IRO trackbar when I ran it.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #753 of 959 Old 06-22-2013, 08:27 PM
ibjeepin95
I can get the zj stuff at advance for cost. So it may be worth sticking with that.
The bend in the ZJ tie rod makes it weak and they like to fold easily there. I wouldn't even waste my money. I'd either do the IRO replacement or just get another stock one for now.
ibjeepin95 is offline
post #754 of 959 Old 06-23-2013, 12:56 AM
Muddy97Cherokee
1997 XJ Cherokee
Wish I would have had internet out in the boondocks to tell you about the wj crossover steering swap. 100x better than the crappy Y set up and it would have been way cheaper.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #755 of 959 Old 06-23-2013, 06:05 AM Thread Starter
DNFJ
Ripped it all off yesterday.
Previous:
DNFJ is offline
post #756 of 959 Old 06-23-2013, 07:24 AM Thread Starter
DNFJ
Any tips on aligning it with a ZJ set up?
Previous:
DNFJ is offline
post #757 of 959 Old 06-23-2013, 07:46 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Roll it down a hill in the back yard, if you miss the house, it needs straightened.
D3<!L!>3D
S8NNG8 is online now
post #758 of 959 Old 06-23-2013, 07:49 AM Thread Starter
DNFJ
Previous:
DNFJ is offline
post #759 of 959 Old 06-23-2013, 07:56 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
You're gonna be eyeballing it I assume. Just go based on a stock setup. Measure the distance between the backs of the tires, and the distance between the fronts of the tires, and make them match. Get it close, and take it in for an alignment if needed.
D3<!L!>3D
post #760 of 959 Old 06-23-2013, 08:02 AM Thread Starter
DNFJ
Eye balling it for now, because I'll probably have to re-adjust it slightly once the new track bar is on.
Then I'll get it as close as possible measuring, if need be, alignment.
Previous:
DNFJ is offline
post #761 of 959 Old 06-23-2013, 08:17 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
You'll have to find a shop that isn't gonna tell you "we can't do that cuz you don't have stock size tires."
D3<!L!>3D
post #762 of 959 Old 06-23-2013, 08:56 AM
alexrule123
Same as aligning it with factory XJ setup http://jeep-xj.info/HowtoAlignment.htm
post #763 of 959 Old 06-23-2013, 10:40 AM Thread Starter
DNFJ
New stuff on, now I just wait for the track bar.
Previous:
DNFJ is offline
post #764 of 959 Old 06-23-2013, 05:55 PM
ibjeepin95
Whose Fiero?
post #765 of 959 Old 06-23-2013, 06:05 PM Thread Starter
DNFJ
Whose Fiero?
My dad's, I'm borrowing it.
Previous:
DNFJ is offline
Closed Thread
