Thundercracker Build Thread - Page 50 - JeepForum.com
post #736 of 959 Old 06-21-2013, 12:01 PM
VegasGT
1988 MJ Comanche
Originally Posted by DNFJ View Post
I can get the zj stuff at advance for cost. So it may be worth sticking with that.
That would work just fine too. I get the same deal with Advance so I use it when I can lol.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #737 of 959 Old 06-21-2013, 12:19 PM
DualPurposeXJ
1994 XJ Cherokee
Serious question: What is the benefit of DS over not? Just that it won't bind up (and twist because of the bind)?
Clayton has an even better price too, hmmm. Good call.
"Single shear"/"double shear" refers to how a screw/bolt is loaded when the force is perpendicular to the axis of the fastener (when the fastener is loaded parallel to the axis, it is loaded "in tension.")
If a screw/bolt is loaded in shear, it's usually being used as a pivot, and there are other design considerations that should be applied as well (for instance, a threaded fastener should never be loaded in shear on the threads - it should be loaded in shear on the shank, or "grip.")
"Single shear" refers to the fact that there is a single plane of shear force through the fastener - an example would be a tie rod end stud. Even with the taper to locate the parts, there is a single shear plane - it exists between the tie rod end housing and the knuckle surface (typically considered to be even with the lower plane of the knuckle surface.)
"Double shear" would mean that there are two shear planes through the fastener, or that the total shear force is "split" into two locations on the fastener body. It's most common to see hitch pins loaded in double shear - a good example of this would be the cross pin for your trailer hitch. You know how you put the shank of the ball mount into the receiver, and then retain it with a large (~5/8") pin? That pin is loaded in "double shear" - one plane on either side of the ball mount shank.
Loading a fastener in "double shear" allows you to either not quite double the load on it, or to use a smaller fastener (since the load is split.) You'll still want to select for the shear load to be placed on the shank instead of the threads (where the available shear strength is rather lower!) While I like to leave a good safe margin for anything (without testing, shear strength can be estimated as being 75% of tensile strength, and tensile strengths for ISO and SAE fasteners are easy to find,) this still gives guidelines for not wandering too far into overkill.
Note that there is a fairly significant reduction in strength when loading a fastener in shear over the threads (due to reduced cross-sectional area.) I don't have it to hand, but I've been planning a "fastener primer" that will explain just how you can figure the reduction in strength due to threading. There is a similar reduction in strength when loading in tension - same reason. You use the minimum cross-sectional area at the thread root for strength calculations in tension, and you should be able to use the full nominal diameter in shear (unless you screwed up, and loaded it in shear across the threads...)
If you're in control you're not going fast enough - parnelli jones
DualPurposeXJ is offline
post #738 of 959 Old 06-21-2013, 12:29 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Very nice explanation, thank you.
Gonna go to advance after work and check prices.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #739 of 959 Old 06-22-2013, 02:20 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
ZJ v8 tie rod, ends, adjustment sleeves and draglink are all currently sitting in my garage.
Clayton double sheer will be here tuesday.
What should I paint the steering with? I thought about using my unmixed monstaliner on it but meh.
Previous:
DNFJ is offline
post #740 of 959 Old 06-22-2013, 02:27 PM
Steelo805
Chassis saver if your not going for a color
Steelo805 is offline
post #741 of 959 Old 06-22-2013, 02:29 PM
tyvanwie
Why paint it..?
Sent from my iForum using JeepPhone
tyvanwie is offline
post #742 of 959 Old 06-22-2013, 02:43 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Originally Posted by tyvanwie View Post
Why paint it..?
Standard anti-rust procedure.
Previous:
DNFJ is offline
post #743 of 959 Old 06-22-2013, 02:46 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Paint? I'm gonna try epoxy floor coating that I have left over... that's the aluminum colored liner I'd mentioned in my build thread.
D3<!L!>3D
S8NNG8 is offline
post #744 of 959 Old 06-22-2013, 02:51 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
automotive paints only
Previous:
DNFJ is offline
post #745 of 959 Old 06-22-2013, 03:48 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Why? You didn't use paint for the body? Are you dyslexic?
D3<!L!>3D
S8NNG8 is offline
post #746 of 959 Old 06-22-2013, 03:49 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
The black wrangler in the dirt behind me ended up like this:
Previous:
DNFJ is offline
post #747 of 959 Old 06-22-2013, 03:50 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
wat.
"epoxy floor coating"
Is not automotive grade paint.
Right paint for the right job duder.
Previous:
DNFJ is offline
post #748 of 959 Old 06-22-2013, 03:56 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Bad angle but if you look at the sway bar links you can see how off center the axle is.
And you can sort of see where the track bar kinked.
Previous:
DNFJ is offline
post #749 of 959 Old 06-22-2013, 04:33 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
wat.
The hell, it's been repelling every chemical that goes in a vehicle on the floor of my shop for 4 years. I'm using it cuz it's free! And it may turn out to work friggin' awesome.
D3<!L!>3D
S8NNG8 is offline
post #750 of 959 Old 06-22-2013, 05:29 PM
Luke95
Where's the video of you in the rocks???
Sent from my xj
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
Closed Thread
