Thundercracker Build Thread - Page 44 - JeepForum.com
post #646 of 959 Old 06-10-2013, 05:45 AM Thread Starter
DNFJ
Originally Posted by Muddy97Cherokee View Post
Its a bummer that the armor doesn't fit snug. IMO I would rather bend it than cut it and see what it looks like. If it looks dumb then you could still cut it. My buddies zombie jeep that's in my build thread has that orfab armor and it looks great and fits just right but it is a pre97. Maybe they need to advertise the problem. Did you contact orfab?
Not yet, probably won't as I'm sure they're aware of it. I might do what ibjeepin said and cut it then flap disk it.
He would have to get the hatch also.
And re-paint it.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #647 of 959 Old 06-10-2013, 09:29 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Ya, that's too far to have to go to solve the this. Looking at your pic, I'd say cut it at the holes and leave an inch or so to protect the tail light. Maybe try to leave the ORF on and wrap it around the light.
D3<!L!>3D
S8NNG8 is offline
post #648 of 959 Old 06-10-2013, 09:32 AM Thread Starter
DNFJ
So far it doesn't bother me, but honestly bending it around seems less worth it and harder to accomplish (quality wise) than simply cutting it and smoothing it out.
Previous:
DNFJ is offline
post #649 of 959 Old 06-10-2013, 09:59 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
You wouldn't bend it while their on the rig. Can you pull the screws, or are they taped also?
D3<!L!>3D
S8NNG8 is offline
post #650 of 959 Old 06-10-2013, 10:21 AM Thread Starter
DNFJ
I'm aware of this, however it's thick plate steel, to get a nice bend (that also looks nice) is going to be a lot of work, plus it will most likely crack the powder coating and I will have to repaint it.
They are bolts, not screws. 9/32" bolts with washers (to disperse the weight) and nuts on the inside of the quarter panels.
Previous:
DNFJ is offline
post #651 of 959 Old 06-10-2013, 03:46 PM
Midnightluckey
You know.. Looking at the picture of the black xj on the last page, his is a 97+ and looks like it fits a whole lot tighter. Maybe you could try shifting the whole panel forward until you like the tail light clearance, and if anything interferes with your rear door closing, trim it down in front of the door until you have no clearance issues with opening/closing.
It's a bummer they need so much extra work to be fitted, because they really do look amazing.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #652 of 959 Old 06-10-2013, 04:25 PM Thread Starter
DNFJ
There's at most a 1/4" space left before the rear doors probably less IIRC.
Previous:
DNFJ is offline
post #653 of 959 Old 06-10-2013, 04:59 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
That's not a 97+, the rocker tails are behind the tires. '97+ doesn't have them, the rear bumper goes there.
D3<!L!>3D
S8NNG8 is offline
post #654 of 959 Old 06-10-2013, 05:00 PM Thread Starter
DNFJ
That's a 97 with the plastic end caps removed
Previous:
DNFJ is offline
post #655 of 959 Old 06-11-2013, 08:17 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Ok, I see the rounded edge on the hatch. Anyway, the ultimate solution is to give them to my '95
D3<!L!>3D
S8NNG8 is offline
post #656 of 959 Old 06-11-2013, 05:28 PM Thread Starter
DNFJ
Bored at work.
Previous:
DNFJ is offline
post #657 of 959 Old 06-12-2013, 04:00 AM Thread Starter
DNFJ
Got my hood pins, and struts for my hood yesterday. Woo.
Previous:
DNFJ is offline
post #658 of 959 Old 06-12-2013, 06:01 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I have a set of struts off the ZJ. All I need to mount them is a notch cut in the lip on the side of the hood, and mount the receiver. Then I can buy replacements at O'reilly's.
D3<!L!>3D
S8NNG8 is offline
post #659 of 959 Old 06-12-2013, 06:06 AM Thread Starter
DNFJ
Wat. Zjs have spring lift hoods
Previous:
DNFJ is offline
post #660 of 959 Old 06-12-2013, 06:28 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Ya, and the struts have the bracket attached by J-Joint. This is looking like a damn easy mod for all of us. The only piece we need is the silver zirk looking part the other end attaches to. It's the same piece our hatch struts attach to.
D3<!L!>3D
S8NNG8 is offline
Closed Thread
