Thundercracker Build Thread - Page 3 - JeepForum.com
Closed Thread
post #31 of 959 Old 01-04-2013, 10:39 AM Thread Starter
DNFJ
Just ordered the shims and extended brake lines.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #32 of 959 Old 01-04-2013, 03:13 PM
sAe23
1995 XJ Cherokee
Shackle relocation brackets...
With extended shackles I got 2" net lift...
sAe23 is offline
post #33 of 959 Old 01-04-2013, 06:36 PM Thread Starter
DNFJ
All my IRO parts should be here tuesday. Yay.
Previous:
DNFJ is offline
post #34 of 959 Old 01-04-2013, 07:25 PM
dcorn
Better get some drop brackets from RCX or RE. 6.5" lift with short arms is going to suck. 4.5" was bad enough.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #35 of 959 Old 01-04-2013, 07:33 PM
ibjeepin95
This. I feel as if your XJ will ride like a$$.
ibjeepin95 is offline
post #36 of 959 Old 01-04-2013, 07:45 PM
Kevin108
Skip the t-case drop and get a SYE. The problem with the drop is that it isn't - it's more of a tilt. What you drop on the back, you raise at the front. A 6" lift is already pushing it for our short front drivelines.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #37 of 959 Old 01-04-2013, 10:10 PM
rugsucka
I run Rocky Road Outfitters Drop Brackets. They have a better bracket support system than the other 2 companies suggested. A bit more expensive, but worth it if you are not going with Long arms.
Also please consider the options available for shackle relocation brackets for the rear. As suggested, your ride and certainly your flex will be like poo if you do not. NO shock can fix that issue.
If you have not been drenching ALL fasteners with PB blaster type juice - shocks (expect to snap off the upper rear shock bolts and work that issue) upper shackle bolts, front leaf spring bolts, control arm fasteners, hitch (if equipped) hardware etc. you will have a great deal of effort ahead of you considering the 13 years of winter your XJ has seen. Have extra fasteners, torches, breaker bars, angle grinders, sawall etc. ready to go.
You do not need a bigger sway bar, you need longer swaybar end links.
IRO sells a very good adjustable double shear trackbar set up and a tough tie rod replacement as well.
rugsucka is offline
post #38 of 959 Old 01-05-2013, 01:26 AM Thread Starter
DNFJ
Like I said, its temporary until time and weather (and wallet) will let me properly install a SYE.
Yeah I meant a bigger tie rod, most likely will order iro's. Sorry operating on very little sleep. Anyways all my stuff should be here Tuesday.
Still looking into which control arm drops I will get, though I'll look into those. I do plan on shackle relocation once money allows. Basically the tc drop and drop shackles will only be on until I get my tax return and have time to properly install the last three things.
Did order my adjustable track bar though.
Previous:
DNFJ is offline
post #39 of 959 Old 01-05-2013, 08:47 AM
Kevin108
See what it does. You may wind up having to leave out your front DS until you can SYE. The IRO H&T works great although at your lift height you'll probably have to get a custom rear driveshaft made up if a ZJ front shaft isn't long enough.
The drop shackles are 50% of the cost of the relocation kit. Sounds like throwing money away to me unless you buy some cheapo shackles. I've got a set of Rough Country 1" / 2" I may be ready to part with if you haven't ordered yours yet. I ran them for maybe a year and a half before I built my bastard pack.
http://www.roughcountry.com/jeep_xj_shackles.html
Kevin108 is offline
post #40 of 959 Old 01-05-2013, 08:53 AM Thread Starter
DNFJ
Yeah I got a pair of shackles cheap from a friend. Most likely will be using my tax return to just order a hack n tap + go the jy for a ds.
Previous:
DNFJ is offline
post #41 of 959 Old 01-05-2013, 10:19 AM
Kevin108
Anxious to see it come together!
Kevin108 is offline
post #42 of 959 Old 01-09-2013, 04:05 AM Thread Starter
DNFJ
Blah, everything's here besides the control arms.
RC sent me the YJ rear brake line, will this work or do I need to call them and get the actual XJ one. One more headache, figures.
Previous:
DNFJ is offline
post #43 of 959 Old 01-09-2013, 06:31 PM
Kevin108
The fittings are the same. It it's long enough, you're good. For a 2"-3" XJ lift, a stock YJ line is the perfect length at 3-1/8" longer than the stock XJ line.
Kevin108 is offline
post #44 of 959 Old 01-09-2013, 09:24 PM
rugsucka
I use a '95 Dakota rear line for 5" and it's plenty long, Dodge ram van rear softline is good to at least 8" (they say...)
rugsucka is offline
post #45 of 959 Old 01-10-2013, 03:58 AM Thread Starter
DNFJ
Yeah it's good. Just wanted to make sure.
Anyways, got the rear passenger side almost all done, need to take the front leaf bolt out and cut the rear bolt out. It's in the metal circle inside the bushing and won't come out any further, so I'm just gonna cut it and pull it. Unless anyone has a better idea.
Previous:
DNFJ is offline
Closed Thread
