Thundercracker Build Thread - Page 17 - JeepForum.com
post #241 of 959 Old 03-14-2013, 06:09 AM
whitexj98
Originally Posted by phfister View Post
Absolutely not. Bending it back is a terrible choice imo because of the amount of stress that mount gets, bending rusty metal is going to make it weaker, even with the new welds. Instead it would just crack in a different spot.
I'm not happy about it, but $150 to have new mounts on both sides of the axle is a damn good deal.
A welder is coming, I just need to find a used one on craigslist or something.
You should have them weld mini skids on and box the upper control arm mount as well...
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #242 of 959 Old 03-14-2013, 06:10 AM Thread Starter
DNFJ
May wait until I buy my own welder and do that, don't like paying shops tons of money if I can avoid it. That is a good idea though.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #243 of 959 Old 03-14-2013, 06:15 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Hmm, what to buy next?
This my friend!
It'd pay for itself in no time.
***Chris***
chris87xj is online now
post #244 of 959 Old 03-14-2013, 06:16 AM
Project1
Originally Posted by Luke95 View Post
E fan conversion? 789 injectors?
Sent from under my broken Heep
On mine I had a stock E-fan that runs all the time and that works great for normal driving. Then if you get hot offroad I had a Ford SHO fan 2 speed... that was pretty good really, but mine was used and had a bit of an off balance to it So i swapped to an Audi turbo fan, which is a bit more powerful than the stock E fan. Look at PSC though, the people who make the hydro steer, they have some nice fan set ups. and while your their do a trans cooler. I didn't do one and I really need one and I'll have to go back and fix it, so much easier to do it all at once.
Project1 is offline
post #245 of 959 Old 03-14-2013, 06:18 AM Thread Starter
DNFJ
Originally Posted by chris87xj View Post
This my friend!
Too much for now sadly.
Soon though, soon.
Previous:
DNFJ is offline
post #246 of 959 Old 03-14-2013, 06:22 AM Thread Starter
DNFJ
http://www.dirtboundoffroad.com/feat...onversion-kit/
http://www.dirtboundoffroad.com/jeep...oler-with-fan/
Hmmm, might be time for some cooling upgrades.
Previous:
DNFJ is offline
post #247 of 959 Old 03-14-2013, 06:27 AM
whitexj98
Do you have cooling probems?
I seem to see more problems with deleating the mechanical fan then not... IMO a good 3 row radiator and a properly maintained cooling system works perfectly fine, is simplier and much more cost effective.
post #248 of 959 Old 03-14-2013, 06:40 AM Thread Starter
DNFJ
Heh, do I ever.
Heat soak issues when the engine is hot, who bunch of crap, rad is new, flushed the cooling system late last year.
I need injectors (heat soak) and more cooling (or hood vents).
E: Surprised you think that the stock cooling system is good, as XJs are notorious for overheating and having ****ty cooling systems.
Previous:
DNFJ is offline
post #249 of 959 Old 03-14-2013, 06:50 AM
whitexj98
I have never had a cooling issues wheeing in Kansas summer heat (~105F) on 33s, 35s and 4;56s... and many times when I see people chasing cooling issues they go to e fan conversions and still have problems. but I have also heard of the heat soak issues problems with the "newer" xjs, mines a 98...only mods are e fan swith to turn on at anytime and CSF 3 row radiator
Have you pressure checked your cooling system?
Stant pressure cap? (OE spec)
Replaced water pump?
Replaced thermostant (OE spec)
post #250 of 959 Old 03-14-2013, 06:54 AM Thread Starter
DNFJ
Yeah, at the time it was fine. Mines a '00 so I have the ****ty 0331 heads and terrible heat soak issues.
Blah.
Previous:
DNFJ is offline
post #251 of 959 Old 03-14-2013, 06:59 AM
Project1
yea that fan looks sweet .. Love to see it. I really like the efan, i think its the way to go.
Project1 is offline
post #252 of 959 Old 03-14-2013, 07:03 AM Thread Starter
DNFJ
whitexj98, new OE radiator, 180* thermo, water pump, cap, hoses, and flush last November (in the OP).
I am curious about how that fan on the oil cooler works, there is a plug but no wiring harness. Hmmm. Ideas?
Previous:
DNFJ is offline
post #253 of 959 Old 03-14-2013, 09:56 AM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Hood vents did wonders for me. I have yet to see 210 since I installed them.
April 2014 & 2015 COTM
MOBBiN is offline
post #254 of 959 Old 03-14-2013, 10:01 AM Thread Starter
DNFJ
http://www.xjtalk.com/showthread.php?t=2033
I already have the grill o sheets painted and the door trim sitting at home, but it got cold before I could install them.
Previous:
DNFJ is offline
post #255 of 959 Old 03-14-2013, 10:06 AM
MOBBiN
MOBBiN's Avatar
I hope you have a steady hand. There's not a lot of room for mistakes doing it that way. The finished product does look great though.
MOBBiN is offline
Closed Thread
