for those rockin stock shocks on budget boosts - JeepForum.com
post #1 of 30 Old 07-12-2008, 01:26 PM Thread Starter
aircruiser
aircruiser's Avatar
so in the future, there is a 3" lift for the jeep. but thats when my 30s wear down and money is recovering from the bumpers and armor. for now, id like to get 2" spacers and 2" AALs for the jeep for now. but i dont want to swap the shocks since i dont want to break any bolts since i can only have the garage for one day. just curious who has still got stock size shocks with a bb. ive heard itll work and i only do mud and light trails as of right now and dont flex it alot so i should be good.
just wondering whos all doin it.
aircruiser is offline
post #2 of 30 Old 07-12-2008, 01:43 PM
itsge0ff
I've been on them for a couple months, Hit some trails and they were fine. They are starting to get pretty rough now. But for the first 6 months they were fine. Couldn't tell
1999 Desert Sand Cherokee Sport with some cool stuff
itsge0ff is offline
post #3 of 30 Old 07-12-2008, 09:11 PM
Scottmc01
1993 XJ Cherokee
It took all of 5 minutes to punch out the broken bolt+nut on my shock mount and fish a new one in from the top. So thats 20 minutes total if you break all four.
93 Jeep Cherokee Country 4.0 AW4
Flowmaster / APN header
3" mismatched lift
30" Bighorns on V5's
Scottmc01 is offline
post #4 of 30 Old 07-13-2008, 12:32 AM Thread Starter
aircruiser
aircruiser's Avatar
did you cut new access holes though? i want to lift it myself but tools are very limited and you know how the 2 hour job turning into a whole days job goes (im assuming).
post #5 of 30 Old 07-13-2008, 01:00 AM
winkosmosis
I hear you. I live in an apartment, no garage and no driveway, so I won't even attempt to do a "2 hour job" because I know it will end up being a 20 hour job.
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #6 of 30 Old 07-13-2008, 10:15 AM
Scottmc01
1993 XJ Cherokee
you can access the top of the shock mount from an already existing hole on the undercarriage. No need to cut through the floor.
3" mismatched lift
post #7 of 30 Old 07-13-2008, 08:34 PM
afguy
I had a bolt break off, not the nut, so I just drilled and tapped it.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies.
afguy is offline
post #8 of 30 Old 07-13-2008, 09:03 PM
wokkerk
Think of it this way...if you PB Blast the bolts for a few days in advance...and you are careful I doubt you are going to break a bolt on a 99. you just have to be careful about it. I did my 97 and PB Blasted them three days straight in advance and they came out really easily. I would also reccomend renting a spring compressor because it will cut down in time that you have to spend on the project by a couple hours. and....if you rent it at autozone you get all your money back when you return it...so its free. Have fun!
1997xj "SPQR" (in Jeep heaven)
2000xj Freedom Edition "Stormtrooper"
wokkerk is offline
post #9 of 30 Old 07-13-2008, 09:09 PM Thread Starter
aircruiser
aircruiser's Avatar
well my 99 has 205,000 miles on it...spent all of its life in virginia up until 2007 so it barely has any rust but of course, the bolts do. i also dont have much money for shocks.
post #10 of 30 Old 07-13-2008, 09:34 PM
Scottmc01
1993 XJ Cherokee
Maybe you should have saved your money for shocks instead of wasting it on a roof rack that serves no purpose.
3" mismatched lift
post #11 of 30 Old 07-13-2008, 09:45 PM Thread Starter
aircruiser
aircruiser's Avatar
right
10 char
post #12 of 30 Old 07-14-2008, 12:58 AM
wokkerk
get a kit that includes shocks such as the Rubicon Express BB. package deals are always cheaper.
wokkerk is offline
post #13 of 30 Old 07-14-2008, 06:40 PM
broncofire75
Id save for the whole kit first it will be cheaper in the long run. Also, if you get new shocks for a 2" BB they should do fine if you want to upgrade to some 3" coils and packs in the future.
I got you some spacers for the front if you wanna go with 2" for now...PM me...
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline
post #14 of 30 Old 07-14-2008, 08:49 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I'm running stock shocks with 2" in the rear and 1.75" up front. no problems so far, it will just make your ride a little stiffer. but I replaced the shocks a while back with stock shocks and broke all four upper bolts. If you have access to an air chisel, it's an easy fix. just punch out the weld nuts then run a wire through the bolt hole and out the access hole, then tape your new 1" grade 8 bolt with flat washer to the wire and pull it thru. you can reach the bolt with a wrench to tighten it. took me about 45 minutes to replace all four.
xjfever is offline
post #15 of 30 Old 07-14-2008, 08:53 PM
winkosmosis
It may be cheaper to build all the way up immediately, but IMO, building gradually is more fun. Besides, a BB is cheap if you keep stock shocks... especially if you can do it yourself.
recommended budget boosts SDH XJ/MJ Cherokee Non-Technical Forum 1 05-21-2009 11:06 AM
A few questions about budget boosts... Greg Sage XJ Cherokee Technical Forum 12 09-20-2007 11:44 AM
Help On Budget Boosts For Xj Country Cracker XJ Cherokee Technical Forum 6 04-15-2007 05:59 PM
Budget Boosts? cyka65 XJ Cherokee Technical Forum 8 02-01-2004 09:23 PM
Budget Boosts ctavel XJ Cherokee Technical Forum 5 10-26-2003 07:34 PM
