Things you need to know about Jeeps. LOL - JeepForum.com
post #1 of 12 Old 03-15-2012, 12:44 PM Thread Starter
danb303
DW = Death Wobble and it's not caused by a bad steering stabilizer.
Yes your exhaust manifold is cracked and yes it's a pain to replace
TPS = Throttle postion sensor and they go bad all the time. I keep a spare.
Brown coolant is not muddy coolant. If you have mud inside the radiator you are in trouble.
No, Dana 35's will not last with 35" tires. Don't believe me...try it...
Yes, that is oil leaking under your Jeep.. it wasn't there when you parked there.
Your Cherokee runs hot.... Wow, mine too....
At 210 degrees 15 lbs of oil pressure is pretty good 10 lbs is probably ok and at 5 lbs you had better switch to Rotella.
Keep it going!!!
danb303 is offline
post #2 of 12 Old 03-15-2012, 01:18 PM
AZ Jeff
2014 JK Wrangler
No, you cannot ignore a brake leak until you get some money to fix it.
The water pump is NEVER supposed to have any play in it's shaft, not even a little.
Knocking in the engine is not the same as "ticking", and where the sound comes from on the engine makes a BIG difference is how serious it is.
You cannot just throw in some R134a on your AC system and expect it to be fixed. Do it right, or pay someone to do it, if you don' t know how or have the tools.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 12 Old 03-15-2012, 01:27 PM
Metro55
You need to learn the simple difference between a D35 and a C8.25 already! O VS (_)
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline
post #4 of 12 Old 03-15-2012, 01:32 PM
Ben
Everything:
http://www.jeepforum.com/forum/f11/t...ks-tsbs-89273/
Ben is offline
post #5 of 12 Old 03-15-2012, 01:49 PM
Metro55
Originally Posted by ben1.8t View Post
/thread
.,,_____,====,
Metro55 is offline
post #6 of 12 Old 03-15-2012, 03:44 PM
jeepnphreak
1989 XJ Cherokee
I have a 2.5 L and it gets the same gas milage as my 4.0... why is that?
Jeeps parts are expensive, Gm parts are not as much, but a lot of GM parts fit on a jeep... humm
Jeep cherokee, grand cherokee, jeep yj and TJ have many interchangabel parts. good to know next IM at the JY
I have a jeep, for some reason I compled to lift it, put on bigger tires, winch, SYE and still drive trails that it could stock...
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #7 of 12 Old 03-15-2012, 09:32 PM
Azzy
Yes, your stock leaf packs are shot. No, an add a leaf wont fix them.
Yes, you should have checked that CEL light before the engine went.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #8 of 12 Old 03-15-2012, 09:39 PM
Millermagic
If it stops leaking ... something is empty.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #9 of 12 Old 03-15-2012, 09:47 PM
honeybadger2038
That's not a tax refund, that's new somethings for your jeep
Your wife will be jealous of your relationship with your jeep
Your jeep will love you if you love it, but is the most high maintenance women you will ever be with
honeybadger2038 is offline
post #10 of 12 Old 03-15-2012, 09:52 PM
joe108
1. Jeep get very poor gas mileage, if Jeep could have got more MPGs out of our engine, they would have done it and bragged about it.
2. Don't try to improve on #1 by putting on after market add on stuff and expect great results, you will generally not get your money out of those things.
joe108 is offline
post #11 of 12 Old 03-16-2012, 11:49 AM
bigdisaster89
Soo true lol
bigdisaster89 is offline
post #12 of 12 Old 03-16-2012, 12:11 PM
Millermagic
The tax refund is the government mandated jeep savings account.
First things to do? Dutch253 XJ/MJ Cherokee Non-Technical Forum 2 01-18-2012 06:45 PM
It's the little things buggs67 XJ Cherokee Technical Forum 12 05-18-2011 08:38 PM
it's the little things tizzdizz XJ Cherokee Technical Forum 4 05-23-2010 09:51 PM
name these things! jackdup XJ Cherokee Technical Forum 8 10-13-2008 07:42 PM
Those little things AYBRB2U XJ Cherokee Technical Forum 1 01-04-2008 01:32 AM
