Switch (factory?) under dash on XJ??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Switch (factory?) under dash on XJ???
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!DIY tube fender kitsAmsteel Blue Synthetic Winch line Free Shipping
Unread 08-05-2010, 01:05 AM   #1
gorko
1988 XJ Cherokee
I know this might be a dumb question, but can anyone tell me what the mini toggle switch (with on/off badge) under the dash on the driver's side is for? I have a '88 and a '89 XJ and both have it. On the '88 it is just hanging under the dash and on the '89 it is mounted high up on the kick panel. I turned it on with the engine off and got 4 clicks in a couple seconds and then nothing. Makes no diff when running or not in either position. Does this possibly have something to do with command start? I don't have the remotes or manual so I don't know. Thanks in advance guys
"If we weren't supposed to get dirty, there wouldn't be mud and grease!"
88 Cherokee Limited
gorko is offline   Reply With Quote
Unread 08-05-2010, 06:37 AM   #2
justxj
Sounds like previous owner fitted an anti-theft switch/device or maybe changed the circuitry so the jeep could be "held" in 2nd gear. Try and trace the wires that connect to the switch and maybe the mystery will be revealed.
justxj is offline   Reply With Quote
Unread 08-05-2010, 06:40 AM   #3
justxj
Sorry, I did'nt read your whole message properly. Can't be a security switch. Best still to back trace the wiring
Unread 08-05-2010, 05:24 PM   #4
vx1kxj
i had one too in my 94 didnt seem to do anything you could tell it was factory too
2000 forest green pearl coat xj,FACTORY HIDDEN 6000bl ramsey winch Up country package I installed myself (even the decal). then i added 3" RC lift with full packs, bilstein 5150's with jks BPE's, amc long black swap from a '95, K&N drop in, Helix throttle body spacer, IRO 2.5" cat back, Hella 500's. Kevin's Offroad light bar, jks quick disconnects MOOG v8 zj steering. 31x10.50 bfg rugged trail on factory steelies, tan power leather seats swapped in from a limited. MINT
vx1kxj is offline   Reply With Quote
Unread 08-05-2010, 05:49 PM   #5
Holder350
1995 XJ Cherokee
May be a valet mode for a alarm system.
95' XJ Country - Stock Skids - Limited Slip Rear Diff
Off Road Package - 4.0 HO - AX15 - NP231
Repeal Ohms Law!!!
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline   Reply With Quote
Unread 08-08-2010, 11:58 PM   #6
Mkonyn
1997 XJ Cherokee
Do you know much about PO of the jeep? I doubt this applies to yours, but I notice I had a random switch under the steering column in my '97, turns out it was a police jeep and the switch was for extended idle, something about higher output alternator or something for running electronics. Very useful for running an air compressor off your car tho.
Mkonyn is offline   Reply With Quote
