Switch for Factory Switch Panel - JeepForum.com
post #1 of 11 Old 01-27-2013, 08:38 AM Thread Starter
FarrellX
anyone know where i can get on that will fit next to the rear defroster and rear wiper switches on my 99???
Mine 1999 XJ
SOLD Hers 1999 XJ 2", 31" MTs
R.I.P. 88 YJ 6 1/2", 36" Iroks, '99 4.0, etc. etc.
FarrellX is offline
post #2 of 11 Old 01-27-2013, 01:25 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
You looking for something like this?
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #3 of 11 Old 01-27-2013, 06:51 PM Thread Starter
FarrellX
yea, mine has a blank spot where your fog light switch is. i was hoping to find a switch that would fit there....to use as my winch kill switch. it is going to run a relay, so not a lot of draw...just need a toggle switch really...
Mine 1999 XJ
FarrellX is offline
post #4 of 11 Old 01-28-2013, 01:20 PM
98muddyjeep
That is a spare switch panel I picked up at the junk yard,I would start there if you want to look factory,the switch panel you have does have the blank cut out for a switch but no molded clip in the back of the panel.
post #5 of 11 Old 01-28-2013, 09:26 PM Thread Starter
FarrellX
yes..has the blank cut out. was hoping someone found an aftermarket switch that fit in that spot..even if it isn't a direct fit, i just want it to be close.
i can add any switch i want, anywhere i want...just wanted to try and use that spot
Mine 1999 XJ
FarrellX is offline
post #6 of 11 Old 10-30-2013, 05:25 PM
morrie
fog light switch
Attachment 551960
My fog lights stopped working and I am assuming the switch has gone bad. I understnd the circuits have a habit of melting thus causing the contact not to be made. Also I think there is a relay switch inside the engine compartment...right? My question is: Can just the fog light switch be replaced without replacing the entire panel and if so can I find it online somewhere? Please advise. Thanks Much!!
morrie is offline
post #7 of 11 Old 10-30-2013, 05:49 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I've successfully picked up a few used OEM XJ dash switch panels from ebay.
And yes the switch is removeable from the panel.
***Chris***
chris87xj is online now
post #8 of 11 Old 10-30-2013, 06:01 PM
BrandonYJReed
2016 JK Wrangler
Could buy this instead... http://www.gaugeplates.com/offroad.php
'16 JK Sport
-2.5" TF Spring Lift
-315 BFG A/T
-3.73
BrandonYJReed is offline
post #9 of 11 Old 10-30-2013, 06:43 PM
Motorcharge
Dirtbound makes a nice one like that as well.
http://www.dirtboundoffroad.com/xj-c...tch-panel.html
I like the ashtray replacement one better but it only works on pre-97. The Dirtbound version I mean.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #10 of 11 Old 10-30-2013, 06:46 PM
LimeLJ
LimeLJ's Avatar
On Board Air USA carries some nice switches that are direct replacements.
http://stores.ebay.com/on-board-air-...=p4634.c0.m322
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #11 of 11 Old 10-30-2013, 07:30 PM
BrandonYJReed
2016 JK Wrangler
Some more direct replacements, these are pretty much the same as above but a little cheaper.
http://www.otrattw.com/products.php?cat=31
'16 JK Sport
-315 BFG A/T
-3.73
