sway bar quick disconnects - Page 2 - JeepForum.com
post #16 of 21 Old 10-11-2011, 02:56 PM
teamskiawa
I found that web site last week did it. It was easy to do. And cheap cost me 8 bucks at tsc. Yeah u have to be on level ground to get them in and out but level ground isn't too hard to find.
ForumRunner_20111011_165451.jpg   ForumRunner_20111011_165512.jpg   ForumRunner_20111011_165600.jpg   ForumRunner_20111011_165634.jpg   ForumRunner_20111011_165653.jpg
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)--o-)_)
i hope this isnt a major problem if so i hope its cheap
teamskiawa is offline
post #17 of 21 Old 10-11-2011, 05:32 PM Thread Starter
JeepXJMike20
Yeah they work great. level ground works best but i was able to get it back in on uneven grounds to. they are quick disconnects and about 1-2 minutes getting it all reconnected.
JeepXJMike20 is offline
post #18 of 21 Old 10-12-2011, 11:47 AM
Jeepy84
"After using this setup for over a year, one of my homemade discos failed while driving on the highway. Although this did not cause me to loose control or significantly change the driving behavior of my Jeep, it is never a good idea to drive at highway speeds with your swaybars disconnected. If you still plan to do this mod, I would strongly advise you to to check the hardware component on a regular basis for wear and replace them as needed."
All you need to know.
I snagged some free skyjacker discos before some discount JKSs that I had to practically rebuild (~$60). Highly recommend them over this if you drive aggressive, are in an area where people drive aggressive or like me, have to swerve a lot (to miss deer). One of those many things I have to think about again when I go higher next year...
"Hello people, would you like me to murder you now? I'm an offroad enthusiast."
"His station wagon is more Jeep than your topless minivan."
Jeepy84 is offline
post #19 of 21 Old 10-12-2011, 05:28 PM Thread Starter
JeepXJMike20
I check my suspension components about every 4 months. this set up works great for what i do.
post #20 of 21 Old 08-08-2014, 11:23 AM
howtowrangler
Will these work?
Does anyone know if these will work on a non-lifted JK? For $60 I want to try... Im planning on lifting it eventually and don't want to buy disconnects again after... http://www.amazon.com/gp/product/B00...jk via @amazon
howtowrangler is offline
post #21 of 21 Old 08-10-2014, 01:14 PM
indeepwithajeep
I've done the clevis pin swaybar disconnect and I didn't like it. It just seemed like it was slightly better than no connection at all. So I used a 1/2" bolt (iirc) and a wing nut and some washers. You also want to drill the bolt to get a cotter pin in so the wing nut won't back out. This setup felt just as it did from factory IMO..
I didn't have the holes drilled in the bolt yet for the cotter pins.. It will back out even with split washers. Except the top wing nut will stay put without a cotter pin.
indeepwithajeep is offline
Best Sway Bar Disconnects 96-XJ XJ Cherokee Technical Forum 5 07-14-2009 02:51 AM
sway bar disconnects Bobandbeans XJ Cherokee Technical Forum 1 04-20-2008 09:28 PM
Sway bar Disconnects ? OnlyinmyJeep XJ Cherokee Technical Forum 9 07-28-2004 09:24 PM
Sway bar quick disconnects quick question LOCKED UP XJ Cherokee Technical Forum 25 05-24-2004 04:31 PM
Sway bar disconnects ddoffroad XJ Cherokee Technical Forum 5 09-06-2002 05:11 PM
