Which Suspension Kit Out Of The 3? - Page 2 - JeepForum.com
post #16 of 41 Old 10-22-2013, 10:52 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by jeepster383
Explain how this is horrible at 3 inches?? You can redril the hole and the axle WILL be centered. Would I like an ajustable? Yes but it's ridiculously expensive.
Redrilling a hole in thin metal is stupid I've seen redrilled mounts tear . 125 is not much to spend. The stock trackbar was not designed to work at the angle of a 3" lift especially when cycling offroad.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #17 of 41 Old 10-22-2013, 11:00 PM
jeepster383
It's plenty strong enough. To help mine I welded the right size washer to the bracket to help. And the stock track bar is fine for offroad. I've used my cheapie 36$ track bar off eBay for over a year with no problems. Flexes great. I can see tho where u can run into problems after somebody has instaled 12-14 travel shocks and it flexes so much it binds the factory trac bar.
jeepster383 is offline
post #18 of 41 Old 10-22-2013, 11:28 PM
Tom95YJ
Tom95YJ's Avatar
I think you need to start doing some research There is a reason HD trackbars use a Heim type joint instead of the standard tierod oem style it is because it is designed to work as the suspension cycles.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #19 of 41 Old 10-23-2013, 06:43 AM
jeepster383
I'm just sharing from experience no problems so far at all.
post #20 of 41 Old 10-23-2013, 09:15 AM
cbenez1
My biggest concern is also the mount but if your reinforcing it I'd say that might be adequate for mild lifting and average wheeling. Tom has a solid point though, you really can't be "to" careful when it comes to steering components.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #21 of 41 Old 10-23-2013, 09:55 AM
jeepster383
It all depend on the setup. 3 inches and 31 or 33s youl be fine for average wheeling. Have you personally broke that trac bar mount?
post #22 of 41 Old 10-23-2013, 10:00 AM
cbenez1
No, but I never relocated the hole either. I went right to replacing the bar with an adjustable one. I have seen many oval'd out after moving the hole.
cbenez1 is offline
post #23 of 41 Old 10-23-2013, 10:26 AM
jeepster383
Yup. What one did u go with? On my gfs zj we got her the pro comp one (180$) and I wasent impressed. The bar itself you could watch it slightly bend by just turning the wheel back and forth.
post #24 of 41 Old 10-23-2013, 10:29 AM
Tom95YJ
Tom95YJ's Avatar
Yes I have it sucks loosing steering.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #25 of 41 Old 10-23-2013, 11:09 AM
jeepster383
At the axle side? What broke and what were you doing?
post #26 of 41 Old 10-23-2013, 11:16 AM
Tom95YJ
Tom95YJ's Avatar
Mount on axle end wallowed out even with welded washers got death wobble then the part that connects to the frame busted and the bar dropped. While I was going 25mph on a road. I did wheel that jeep often but they were mild trails
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #27 of 41 Old 10-23-2013, 12:02 PM
jeepster383
So the problem is not with the OE style track bar it's with the brackets that it bolts to. The same thing can happin if you swap an ajustable trac bar in. I guess if you're having that problem you wana fab up some heavy duty brackets instead. Or buy some.
post #28 of 41 Old 10-23-2013, 02:25 PM
cbenez1
RE 1600's.
cbenez1 is offline
post #29 of 41 Old 10-23-2013, 02:37 PM
jeepster383
RE 1600's.
Holding up good?
post #30 of 41 Old 10-23-2013, 02:46 PM
cbenez1
Yeah never had any issues with them.
cbenez1 is offline
