super fun sye install - JeepForum.com
post #1 of 4 Old 04-07-2011, 11:29 PM Thread Starter
med
So i started taking things apart and the first problem i had was the tail housing seal thing. took me a gear puller, a screw driver and a BFH. 20 minutes later i got it off.
I continue on and my next issue the Inner and Outer snap rings. Awhile later I ended up breaking my first pair of pliars. Went to the store and got another pair. This pair actually worked. wonderful! I continued got everything apart and switched the shafts, etc etc.
I started to reassemble everything and wasnt paying any attention and put the oil pump on the inside of the case half. I ended up snapping off one of the lips that holds it from going inside the case half. I decided to just use the part still, there were still 3 others to do its job.
I fixed that issue and got everything back together and as i was cleaning up and noticed i still had a snap ring laying out from the sye kit. I took the entire thing back apart only to find out that nothing was missing. Awesome...
Everything after that went smooth. I also noticed a tiny spring that looks like its from inside a pen laying around. I Don't see any place where it goes.
My problem now is my Transfer case grinds when I have the TC in N and shift the Tranny into park. It may or may do that normally but I do not know.
This was my first real project aside from a thermostat change. It sucked but im glad I now have the knowledge.
98 XJ Sport
IRO 4" Coils | OME 2.75" Leafs | Teraflex 1.5" Shackles | IRO Trackbar | OME Steering stabilizer | Rustys Intake | APN header | Putco Harness | AA SYE | Tom Woods CV DS | 33" KM2s | 16x9 AEV wheels | Bilstein 5100s | JKS Discos | Brown Dog Motor Mounts | IRO L/UCA |
med is offline
post #2 of 4 Old 04-08-2011, 12:39 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by med View Post
.....My problem now is my Transfer case grinds when I have the TC in N and shift the Tranny into park. ....
Just don't do that. Probelm solved.
CJ7-Tim is offline
post #3 of 4 Old 04-08-2011, 12:47 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
x2. the transmission is still spinning when you do that, thats the grinding you hear. not t-case related at all. the only little spring i can think of is in the shift detent ball on the bottom of the back half of the case. but if you never took it apart and your transfer case shifts and drives fine i wouldnt worry.
1990JEEPXJ is offline
post #4 of 4 Old 04-08-2011, 12:08 PM
dcorn
I learned my lesson as well. Don't run the engine and try to shift the Tcase around with no driveshafts. Everytime you switch it in and out of gear, something will grind. Scared the crap out of me. Wait until you have the whole drivetrain back together to try it out.
2014 Jeep Grand Cherokee Summit
dcorn is offline
stuck between RE 3.5 super flex or 3.5 super ride HACKGT350 XJ Cherokee Technical Forum 28 02-09-2009 05:13 PM
Rubicon Express 3.5 lift super-ride vs super-flex Ewen91 XJ Cherokee Technical Forum 20 09-18-2008 07:22 PM
RE 3.5 Super-Ride Kit install - Need 3/4 Spacers? Elderce XJ Cherokee Technical Forum 7 08-21-2008 06:51 PM
My super amazing JCR Stage 4 bumper install log *20+ PICS* UltimatE XJ Cherokee Technical Forum 28 03-05-2007 11:18 AM
Need info before install of RE 3'' super flex kit 1badxj XJ Cherokee Technical Forum 8 03-11-2004 11:06 PM
