Stock roof rack or drip rail rack? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Stock roof rack or drip rail rack?
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 10-18-2012, 10:36 AM   #1
ttrevino
My XJ didn't come factory with a rack and I'd like to put one on. There's a great salvage yard near me and I can probably pull one, but wasn't sure how good of shape it would be in after the transfer.
I've considered a drip rail rack, but wasn't sure how strong the drip rails were? I don't plan on storing my spare up there, probably just fishing poles, etc. but might put luggage on a long trip. I'd also like to mount a couple of lights. I'd rather stay away from the one with straps that go into the doorways.
I was looking at one like this, and mounting a small basket on it.
http://www.prolineracks.com/proline-...ter-racks.html
Any suggestions? Thanks, Tony
ttrevino is offline   Reply With Quote Quick reply to this message
Unread 10-18-2012, 10:54 AM   #2
1990JEEPXJ
1990 XJ Cherokee
Racks that mount to the drip rails are far stronger than the factory rack that bolts to the roof. But it doesn't sound like you'll be carrying too much weight up there so I wouldn't worry about using the stock style rack. That being said, if you can afford the drip rail rack and it fits your needs, get it
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 10-18-2012, 03:58 PM   #3
ttrevino
Cool, thanks. I had used a rail rack on an old Cutlass years ago but didn't put much on it other than surfboards.
Unread 10-18-2012, 04:43 PM   #4
mschi772
1997 XJ Cherokee
If I can ever afford the body/rust work that I want done, my stock rack is going bye-bye. Eventually I'll get a proper rail mount rack for the times I need one.
mschi772 is offline   Reply With Quote Quick reply to this message
Unread 10-19-2012, 08:20 AM   #5
ttrevino
Something I noticed of my roof, which I'd like to fix before I put a rack on is there are some spots where it's either sagging or has a slight dip in it. Any suggestions on how to fix that or strengthen it from the underside? I need to replace the headliner anyway, so working from the inside won't be a problem.
Unread 12-12-2012, 05:44 PM   #6
welderjames84
Drip rail mount
The rain gutter are by far the best way to mount racks. I build these daily.
http://rebeloffroadcustoms.webs.com/
welderjames84 is offline   Reply With Quote Quick reply to this message
Unread 12-13-2012, 12:35 PM   #7
ttrevino
Nice looking racks!
Unread 12-14-2012, 11:01 AM   #8
Decimals
when i get back to our ambulance deployment ill snap some pics of my roof rack it is mounted on the roof not to the drip... but none the less it is strong as hell
project unknown 1989 Jeep XJ....
Decimals is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 08:37 PM   #9
muddymachinist
I'm building my own right now and I can't get an accurate measurement of the distance between the drip rails. I need to know so that I know how far apart to mount the gutter mounts. Do you know the width between the rails? Any help is appreciated.
muddymachinist is offline   Reply With Quote Quick reply to this message
roof rack
