Still have death wobble, what else could be causing this - JeepForum.com
post #1 of 12 Old 10-22-2013, 08:15 PM Thread Starter
93jeepREDSOX
I have a 96 xj, i have new drag link, zj tie rod, all new tie rod ends, new track bar, steering box brace, and gotten an alignment. What else could be causing the death wobble. It only happens sometimes, and only around 45-55 mph. Just wondering what else could need replacing to solve this.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #2 of 12 Old 10-22-2013, 09:04 PM
chriskeenan
Check the track bar mounting hole, axle side. they can oval out and cause DW.
chriskeenan is offline
post #3 of 12 Old 10-22-2013, 09:07 PM Thread Starter
93jeepREDSOX
If it has, how do you fix it?
The build thread
post #4 of 12 Old 10-22-2013, 09:21 PM
mschi772
1997 XJ Cherokee
How's your wheel/tire balance?
Drill it to match a larger bolt for a new snug fit.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #5 of 12 Old 10-22-2013, 09:24 PM Thread Starter
93jeepREDSOX
wheels and tires were just mounted and balanced
I may have to look at that this weekend.
The build thread
post #6 of 12 Old 10-23-2013, 12:35 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Ball joint's, Hubs, Bushings, Caster angle can all contribute
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 12 Old 10-23-2013, 12:42 AM
bailz812
Mine was the steering knuckle and ball joint
bailz812 is offline
post #8 of 12 Old 10-23-2013, 06:41 AM Thread Starter
93jeepREDSOX
When i had the alignment i had them look over the whole front end of the jeep, only thing they said was bad was the track bar. Are there any tests i can do to test a bad ball joint, steering knuckle, or hub. And to sound like like i have no idea about what i am talking about, castor angle? Haha thanks guys.
The build thread
post #9 of 12 Old 10-23-2013, 06:47 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Were the tires new and/or did you have the problem before the tires came into play...perhaps its one of your rims.
D3<!L!>3D
S8NNG8 is offline
post #10 of 12 Old 10-23-2013, 07:16 AM
VegasGT
1988 MJ Comanche
Consider control arm bushings, especially if braking around 50mph sets it off.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #11 of 12 Old 10-23-2013, 08:14 AM Thread Starter
93jeepREDSOX
Well if first started when it had stock rims and really old 28" tires on it. Now it has some micky Thompson 15x8 rims and used 31's. It's never gone away really. Something still doesn't feel right.
It doesn't happen when I brake only at speed and its getting worst each day I drive.
The build thread
post #12 of 12 Old 10-23-2013, 11:58 AM
Tom95YJ
Tom95YJ's Avatar
Well if first started when it had stock rims and really old 28" tires on it. Now it has some micky Thompson 15x8 rims and used 31's. It's never gone away really. Something still doesn't feel right. It doesn't happen when I brake only at speed and its getting worst each day I drive.
Possibly an out of round tire. I kept getting DW with my old 31's an they would balance perfectly. I installed 33's and the problem went away
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
