Steevs unnamed build thred - Page 2 - JeepForum.com
post #16 of 27 Old 02-10-2013, 11:15 PM Thread Starter
Steev89
Well I haven't been on here for a while but I have done a little work to the jeep. I saw the roof was getting some rust spots on it so I sanded it down a bit put some rustoleum rubber underliner stuff and then truck bed liner on top turned out pretty well but I don't have any pictures of the process unfortunately. I'll try to find some here though
1999 Jeep XJ : 5" lift, TnT y-link radius arms and belly pan, Rugged Ridge sye, TnT body StiffinerZ. Socket forever stuck inside unibody
Steev89 is offline
post #17 of 27 Old 02-10-2013, 11:23 PM Thread Starter
Steev89
Just noticed I didn't post on here my roof rack that I got it will post pictures of that also.
But the best thing I got this weekend was a Dana 44 of an 86 xj for 300$ woo! I started cleaning it tonight and will hopefully get it painted up soon, some disc brakes and get it on the jeep.
Steev89 is offline
post #18 of 27 Old 02-11-2013, 11:38 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Yellow dif covers! I like the yellow accents
April 2014 & 2015 COTM
MOBBiN is offline
post #19 of 27 Old 02-12-2013, 06:51 PM Thread Starter
Steev89
Thanks man! Ya I was thinking yellow cover also, just gotta find a way to get some affordable disc brakes since my friend is getting my 8.25 with the disc's I got for only like 70$ haha
Steev89 is offline
post #20 of 27 Old 03-02-2013, 06:52 PM Thread Starter
Steev89
Well got it all cleaned and painted up will probably put on another coat then get the disc brakes on there.
ForumRunner_20130302_174959.jpg   ForumRunner_20130302_175017.jpg   ForumRunner_20130302_175034.jpg   ForumRunner_20130302_175052.jpg   ForumRunner_20130302_175113.jpg
ForumRunner_20130302_175130.jpg   ForumRunner_20130302_175147.jpg   ForumRunner_20130302_175159.jpg
Steev89 is offline
post #21 of 27 Old 03-03-2013, 01:33 PM
Camfam07
got a question for ya? im thinking about grabbing a d44 from a 86-88 xj with the 44 on it... 1st question- It looks like this will bolt right in? 2-are you concernced with the bearings or anything inside it? lemme know thanks...
Camfam07 is offline
post #22 of 27 Old 03-03-2013, 01:51 PM Thread Starter
Steev89
Yep, as long as it's out of the xj it will bolt right up, from everything I've read and seen that's been the case anyway. I opened it up and the gears look good it's something I would definitely check though. And the bearings I am going to replace because they need to be taken off for the disk brake kit I got anyway. But since these axles are getting fairly old now I would suggest replacing them anyway.
Steev89 is offline
post #23 of 27 Old 03-03-2013, 02:08 PM
Camfam07
ok thats what im thinking purchase it like you did... strip everything out and replace carrier and pinion bearings.. as well as wheel bearing... another question where are you getting the disc brakes?
Camfam07 is offline
post #24 of 27 Old 03-03-2013, 02:22 PM Thread Starter
Steev89
I ordered the g2 disk brake conversion kit, it kinda sucks because it was expensive but I've heard good things about the kit and I wanted to get new brakes on it. I haven't gotten it on yet but it seems real nice and I got it on sale.
Steev89 is offline
post #25 of 27 Old 03-03-2013, 02:44 PM
Camfam07
oh ok I didnt know if there is a "ZJ" style swap on a 44 or not... i'll have to look into it.. does that one have a LSD? I can grab one for $300 and its so tempting or imma grab a 29spline 8.25 for almost half the price.
Camfam07 is offline
post #26 of 27 Old 03-03-2013, 03:05 PM Thread Starter
Steev89
I believe you can but the on the 44s you need to have like a spacer between the axle bearings because it's too short for whatever reason, I've heard that some people were able to get brakes off crown vics to work. Unfortunately my 44 isn't an lsd. I had the 8.25 on before but wanted to upgrade and I'm giving my friend my 8.25 with disc's because he's got the 35 rear. My 44 was only 300$ also great deal man
Steev89 is offline
post #27 of 27 Old 03-10-2013, 07:40 AM
Camfam07
ok yeah I think im going to grab the one around here for about $300 I believe its an LSD something about a 44 is just more appealing to me than the 825.
Camfam07 is offline
build thread , steev
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 02:50 PM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
Which should I build out of the other??? ct157167 XJ/MJ Cherokee Non-Technical Forum 3 01-19-2011 09:53 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 04:52 PM
Another Flex Thred... WMW0505 XJ Cherokee Technical Forum 17 05-01-2007 08:20 AM
