Steering stablizer.. Looking for input.. - JeepForum.com
post #1 of 15 Old 12-05-2011, 10:05 PM Thread Starter
Guybub
1990 XJ Cherokee
I recently bought a 1990 Cherokee Larado, I got it with the intentions of putting some work and money into it to make it a nice daily driver with the option to hop off the road and handle things like snow ect.
I put new tires on it, some all terrain Goodyear Wranglers. They are 2 sizes larger than the old stock tires.
I'm finding that the steering has a little play at the wheel, i think it had this before also but it is more noticeable with the larger tires.. I have been looking into some skyjacker and Crown steering stabilizers.
Not sure if that is where I should start? Also if there is anyone who might have a recommendation as to what product they feel is best, from experience or otherwise.
Appreciate any input and suggestions!
Thanks
Guybub is offline
post #2 of 15 Old 12-05-2011, 10:53 PM
Planetcat
2010 WK
I like the Rancho steering stabilizers. They work good. I hear the Old Man Emu ones are very good too. I also had a Rough Country one on my 96 which in all honesty worked just as good as the others and cheaper.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #3 of 15 Old 12-05-2011, 11:47 PM
whitexj98
Before you put on a stabilizer you should first do a good inspection to make sure you are not just covering up worn components like tie.rod.ends or a bad.track bar.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 15 Old 12-06-2011, 12:20 AM
Wearingthin
x2
slopping steering isn't from a stabilizer
and if you do get one, not something that you need to spend a lot of money on
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #5 of 15 Old 12-06-2011, 12:23 AM
Corcor4
1990 XJ Cherokee
Get on off a zj.. its the same as the xj's except its heavier duty. Meaning, its not hollow and light like the xj's. direct bolt on too
My second try: 1990 Jeep Cherokee Xj 6.5ish" lift with tj componets, 33" duratrac's, oversized roof rack, onboard air, body armor.
-OREGON JEEP OWNERS, NORTH WEST CREEPING JEEPERS
18 years old and lots to learn :D
Corcor4 is offline
post #6 of 15 Old 12-06-2011, 06:56 AM
motoxxxman
1995 XJ Cherokee
x3
you'll most likely find worn steering/suspension parts, especially on a 21 year old jeep. and in most cases, anything up there that can develop play can also cause some hefty highway crashes
motoxxxman is offline
post #7 of 15 Old 12-06-2011, 08:51 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
before you put on a stabilizer you should first do a good inspection to make sure you are not just covering up worn components like tie.rod.ends or a bad.track bar.
Originally Posted by wearingthin View Post
x2
X4
Get the front end checked out (Balljoints, Trac Bar, Tierod ends, Control arm bushings, ect.........
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #8 of 15 Old 12-06-2011, 09:21 AM
egodfrey
egodfrey's Avatar
this is whjy i always tell people with dual stabilizers that they are stupid
Truth is you dont need any stabilizer at all, if all your steering components are good and tight and you have a good alignment then your fine without one.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #9 of 15 Old 12-06-2011, 09:27 AM
ytowntj
Yup^ No stabilizer on my TJ and I run 80 on the highway daily.
OP check all the wear items suggested above. Search "dry steering test" and perform that with the front tires on the ground with the vehicle runnng. Id especially look at the TRE at the pitman arm if you are have a large dead spot.
A steering stabilizer is a steering stabilizer. The are all valved 50/50 and will perform the same. Hop on rockauto and buy the TRE's you need and the stabilizer all at once. I got a Moog one for the XJ for like 22 bucks from there a few months back.
Search driveway alignment to get you set back up after replacing parts.
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #10 of 15 Old 12-29-2011, 12:25 AM Thread Starter
Guybub
1990 XJ Cherokee
Thank you all for the input. I will go through the basic front end components first off.
That sounds like the consensus and makes sense.
It's really not that bad I'm coming to realize. I think a lot of it was shock value from going from driving a 2006 Mazda 3 for 5 years back to a rear wheel drive older rig.
Still I will defiantly look over the essentials and go from there.
Thanks again for all the input!
Guybub is offline
post #11 of 15 Old 12-29-2011, 08:54 AM
Azzy
Just a note, if it came with a stabilizer, and the inspecting mech knows this, it may not pass in your state. If you find you still need / want the stabilizer, there is a very nice HD Monroe one on Amazon for about $28, Ive got one for both my XJs.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #12 of 15 Old 12-29-2011, 10:08 AM
Tom95YJ
Tom95YJ's Avatar
I agree with this post, I would also check to see if the steering box is loose.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 15 Old 12-29-2011, 10:22 AM
MountainMan864
Old Man Emu is the only one you want to consider. Around $85 shipped. Shop around and use internet coupon codes and price matched.
MountainMan864 is offline
post #14 of 15 Old 12-29-2011, 10:29 AM
Tom95YJ
Tom95YJ's Avatar
If he has slop in the steering the stab. wont do anything it would be a waste of $
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 15 Old 12-29-2011, 05:01 PM
ytowntj
Really, why is that? Does it perform any differently than any other twin tube stabilizer with equal valving? Aside from the ghey yellow paint and 85 $ price tag there is no measurable difference in steering stabilizers.
If you want more than what a basic stabilizer offers then talk to blaine about one of his hydro assist kits.
Parting my TJ:
ytowntj is offline
stabilizer , steering , steering box play , steering box upgrade
Dual Steering Stablizer? Any Pros or Cons... Doitsouthstyle XJ Cherokee Technical Forum 5 05-07-2010 11:41 PM
Steering stablizer SuperStreetJeep XJ Cherokee Technical Forum 34 11-16-2007 10:48 AM
Steering Stablizer Silver TeeJay XJ Cherokee Technical Forum 4 06-25-2005 04:04 AM
Looking for a steering stablizer, suggestions? cazs_98 XJ Cherokee Technical Forum 3 07-10-2004 10:06 PM
Steering stablizer Question glennv XJ Cherokee Technical Forum 2 03-31-2003 05:39 AM
