Steering Stabilizer Suggestions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > Steering Stabilizer Suggestions
Halloween Savings to die for!THE NEW! VANCO DUAL MODE 15”/16″ Big Brake Kit w/BlaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-06-2014, 04:02 PM   #1
j4rama
Junior Member
j4rama's Avatar
I was wondering what you guys would suggest to replace my currently steering stabilizer with? I know stock ones are sufficient, but mine is currently leaking and needs to be replaced.
2001 XJ Sport - I am going to be lifting my Jeep with a RE 3.5" lift, Bilstein shocks, 31" tires and most likely a Rusty's Tie Rod Conversion kit.
Thanks!
'01 XJ - Work in progress - Build Thread
======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
j4rama is offline   Reply With Quote Quick reply to this message
Unread 10-06-2014, 06:07 PM   #2
ibjeepin95
ibjeepin95's Avatar
Thanks!
Stock one from advance or the zone.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2014, 08:03 PM   #3
VegasGT
Rustler of Jimmies
VegasGT's Avatar
X2 Im just running a stock replacement. No need for anything more.
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 10-06-2014, 09:53 PM   #4
j4rama
Junior Member
j4rama's Avatar
Thanks, guys. I appreciate the input.
======o00o.
Unread 10-07-2014, 08:41 AM   #5
grandkj
I just installed the Old Man Emu stabilizer in my XJ and the feel is sooooo superior to what I had previously which was a worn stock unit. OME stuff is superb
grandkj is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 10:16 AM   #6
j4rama
Junior Member
j4rama's Avatar
Someone had recommended that to me, but I noticed it was over $80, when most of them were around $40. I didn't know how much of a difference they actually make.
======o00o.
Unread 10-07-2014, 03:46 PM   #7
mschi772
mschi772's Avatar
1997 XJ Cherokee
Kevin's Off Road's stabilizer is as good as OME and cheaper when I bought one. I'll buy it again when this XJ needs one.
http://www.kevinsoffroad.com/cart/ha...istance-p-417/
Sent from my phone
mschi772 is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 04:12 PM   #8
j4rama
Junior Member
j4rama's Avatar
I ended up going with the OME instead of the OEM, like grandkj suggested. I ended up buying all my lift parts today, and got a great deal. The OME wasn't much more than the OEM, so I opted for that.
Here's the specs:
http://www.quadratec.com/products/16091_2000.htm
======o00o.
Unread 10-07-2014, 06:22 PM   #9
rugsucka
This doesn't mean it's comparably superior to an OEM quality steering stabilizer.
This means your old and likely original steering stabilizer was completely pooched and ANY new unit let alone the fanboy special OME brand would seem like significant upgrade.
A steering stabilizer does a fairly simple job compared to the shocks on the four corners of your XJ. You might get a marginally better lifespan out of OME, but muting some of the road noise in your steering doesn't take a big investment.
Spend your money upgrading things that matter.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 12:05 AM   #10
Charley3
Old Man Emu
Many brands have to much slop/play. OME is excellent and affordable enough.
Charley3 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 12:05 AM   #11
kadetklapp
1997 XJ Cherokee
My stabilizer is the original and completely roached for sure. I'd like something that is an improvement over stock, but like others have said, it does a simple job and I'm not willing to pay more than $40 for one.
**1997 Jeep Cherokee SE**
Former Police Car
2008 "Jeep" Patriot <-----Crap.
kadetklapp is offline   Reply With Quote Quick reply to this message
rustys , steering , steering stabilizer , tie rod
