Spraying degreaser inside engine? - JeepForum.com
post #1 of 19 Old 12-24-2013, 10:40 PM Thread Starter
Mike934
Just got on my massive oil leak...yes on Christmas Eve..couldn't stand it anymore.
Oil filter housing had NO o-rings left and was jb welded to stop the leak. Fixed that & upgraded to a 97+ housings which have larger ports for oil to pass & drain compared to earlier versions. Installed a 97+ valve cover & new victor reinz "blue" gasket.
Oil pan & rear main is tomorrow. Then fill her with 15w40 rotella.
Anyway the valve cover & oil filter housing has a filmy build up of nasty black...oil? Sludge? Anyway when I pull the pan tomorrow I'm expecting to see that crap all over the rods, crank, ect. It's not mucky or muddy type of sludge, just a built up layer.
I was curious if I could or if it was safe to spray degreaser up/into the bottom end while I have the pan off to help clean things up?
Overlanders do it over land via overlanding because they like to overland?
Mike934 is offline
post #2 of 19 Old 12-24-2013, 10:57 PM
swampratt36
rotella in a gas engine ??? wow good luck . its good oil and i swear by it in my 500 detroit and my 600 cummins just never heard anybody running it in a dd gas engine lol.
swampratt36 is offline
post #3 of 19 Old 12-24-2013, 11:21 PM
dmill89
1995 XJ Cherokee
It is common to run Diesel oil in the 4.0L I6. Diesel oil has more ZDDP (Zinc dialkyldithiophosphates ) which is beneficial to engines with flat-tappet lifers/cam. It can be harmful to catalytic converters in more modern vehicles (mid 2000s+) which have smaller passages in the cat due to increased emissions requirements, this combined with the fact that just about all modern engines have roller rockers and roller lifters (if OHV) is why ZDDP was reduced in most standard automotive oil. This is not an issue with XJ Cherokees (or most other vehicles from that era.) since when they were produced every garden variety oil had as much or more ZDDP as Rotella/Delvac. The higher detergent content of these oils also tends to be beneficial in cleaning higher-mileage engines.
dmill89 is offline
post #4 of 19 Old 12-25-2013, 12:16 AM Thread Starter
Mike934
Been doing it in my 88 with the original motor & the new stroker. And my 92 before that. Totaling over 7 years with no issue.
However I prefer 5w40, the 15w40 was on sale anyway yes it does fine.
I started the stroker out with the recommended 10w30 but I can hear the motor working. Offroading it gets louder (heat). Just the lifters & rockers tapping away. Everything's new in spec nothing reused. This was in my fresh stroker, with tight clearances..meaning it should be quieter. Back to the tried 40 weight rotella and its perfect even under extreme heat while wheeling.
Doesn't burn a drop!
Anyway any advice on spraying out the bottom end with degreaser?
Mike934 is offline
post #5 of 19 Old 12-25-2013, 04:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Don't do it.
Could be corrosives in the degreaser which could damage bearings.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #6 of 19 Old 12-25-2013, 07:40 AM
cbenez1
X2. Don't introduce any kind of de-greaser the internals of your engine. Chances are your not going to find the 'sludge' you described on the rotating assembly of your engine simply because it is constantly moving at a high speed. The build ups tend to happen on non moving parts.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #7 of 19 Old 12-25-2013, 09:20 AM
DougE
1983 CJ7
Run STP Multipurpose Motor Treatment in the crankcase for 15 minutes prior to an oil change.
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
post #8 of 19 Old 12-25-2013, 09:21 AM
dmill89
1995 XJ Cherokee
X3 on top of the potential to be corrosive and the fact that there is unlikely to be sludge on the rotating assembly, degreaser will strip all oil from the bearings (there is a film left behind even with the oil drained) so it will be like starting a new engine that had been put together without assembly lube or priming the oil pump which will drastically shorten the life of the bearings.
dmill89 is offline
post #9 of 19 Old 12-25-2013, 10:18 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Engine oil has detergents in the additive package to clean the inside of your motor. Simply change oil a bit more often. My 1999 will turn over 200,000 miles this week, gets the oil changed every 4,000 miles, has 45 psi oil pressure, and gets 20 mpg's on the highway.
IDK what the inside of the motor looks like, it runs fine.
CJ7-Tim is offline
post #10 of 19 Old 12-25-2013, 10:21 AM
Motorcharge
I change mine religiously ever 3k (get free oil at work so I pay a whole $4 to change my oil) and seafoam every other oil change with a 1/3 of a can of it in the old oil for about 50 miles before the oil change. I know for a fact the inside of my motor is clean as hell.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #11 of 19 Old 12-25-2013, 11:10 AM Thread Starter
Mike934
This is my "new" to me jeep. First oil change lol.gonna run some additives and change it in 2k & see how it looks.
Mike934 is offline
post #12 of 19 Old 11-21-2015, 11:57 PM
swampratt36
Reason i said never heard of running it in a gasser being reccommended because i as a young man fell into a heckuva deal on 2 55 gal drums of dello 400 diesel motor oil and proceded to put it into several gas farm trucks and two mowers and a few other gas egines under the pretense " oil is oil it'll be fine " . Well turns out within weeks everything i had put this oil into could no longer hold oil for more than a few miles days or hours depending on application . Lawnmower ...mainshaft seal gone in minutes...others rings unseated and rear mains gone and valve covers spewing oil like a gusher . Understandibly this may be alll well and fine for new engines on a regular schedule which is unrealistic on most farms and older equipment and vehicles and i would not reccommend it by any meabs whatsoever . Just my $.02
post #13 of 19 Old 11-22-2015, 07:31 AM
mschi772
1997 XJ Cherokee
Tons of people use Rotella T6 in the 4.0. It performs great. The OP's choice of 15w40, however, isn't an ideal choice but shouldn't do any harm either.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #14 of 19 Old 11-22-2015, 07:47 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Your one-off experience is seriously trumped by everyone else's. Mine included. We were using Delo 400 in gas engines in the 70s with excellent results.
post #15 of 19 Old 11-22-2015, 07:57 AM
FairlanePhil
FairlanePhil's Avatar
Used to run Rotella T in my Torino, no issues
I'd probably use brake clean on a guncked up bottom end. It evaporates
Even better, kerosene and a wire brush
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
