Which spark plugs work best for my Cherokee? - JeepForum.com
post #1 of 16 Old 02-08-2010, 01:02 PM Thread Starter
krazykawl18
Xj Which spark plugs work best for my Cherokee?
I have an '01 cherokee with no engine mods done to it, and I just want to replace the current plugs and wires, cause she just hit 100k. I've researched hundreds of forums and web pages, but I still haven't come up with much. I think I might look at running some Autolite Copper Core plugs, since I've heard that Copper lasts longer and maintains better engine temperature.... I'm open to opinions on the wires as well...
krazykawl18 is offline
post #2 of 16 Old 02-08-2010, 01:44 PM
hidperf
1992 XJ Cherokee
I've always ran NGKs in every car I've ever owned. When I used to tune my buddies big block Chevelle, NGK plugs were the only plug we could run that would survive the amount of nitrous we threw at it. I also ran them in my methanol powered street car with no problems.
In fact, I just orered a set for my own 92 XJ.
hidperf is offline
post #3 of 16 Old 02-08-2010, 02:02 PM
crosschecker
1995 XJ Cherokee
NGK's or Champion will do what you want.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #4 of 16 Old 02-08-2010, 02:05 PM
dlane2155
I have been thinking of switching over to these plugs myself. I hear they are good but I do not know. Spark Plugs | Automotive Spark Plug | Motorcycle Spark Plugs | E3 Spark Plugs
dlane2155 is offline
post #5 of 16 Old 02-08-2010, 02:29 PM
jeepkid03
Winning
jeepkid03's Avatar
I've found that the 4.0L runs best on champion copper plugs. The same kind that it came with. Since your XJ is a 2001, it won't have plug wires or a distributor but instead has a coil pack ignition.
As far as the E3 plugs or other fancy ones, thats your own decision. Some people have issues running them, while others swear by them. I have personally seen a '94 Cherokee that ran fine on copper plugs, and couldn't idle right with the fancy plugs. It just seemed to run rough. Put in new copper ones and it ran great. The 4.0 is an engine of very old design and resembles more of a tractor engine compared to the high performance motors in modern cars. If it were me I'd just throw some new copper ones in and be done with it. Since you said yours are the original ones you might even see a gain in mpg.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #6 of 16 Old 02-08-2010, 06:21 PM Thread Starter
krazykawl18
Thanks guys, I think I'm going to go with the champion coppers. Seems to be proven, since they've been highly regarded on this website and in other research I've done.
post #7 of 16 Old 02-09-2010, 12:51 AM
suzzeyv
Just Put in new copper ones and it ran great.Since you said yours are the original ones you might even see a gain in mpg.
Jeep LED Tail Lights
suzzeyv is offline
post #8 of 16 Old 02-17-2010, 09:43 PM
mxboarder17
Go with some french fries I heard they work well!
Karl, Jeepforum will run your f-ing life!!!
I can't wait to get home from Cali so we can test out that Cherokee!!!
Biotch!
Life is Good!
mxboarder17 is offline
post #9 of 16 Old 02-18-2010, 08:23 AM Thread Starter
krazykawl18
Haha kev, yeah, it has taken over my life. Just waiting for that K&N intake kit to come in, that should hopefully help with the mpg's, as well as the spark plugs I'm putting in. Got the Champion copper plus. Yeah, we'll have to take the jeep out, I still haven't thought of a nickname for it yet though....
post #10 of 16 Old 02-18-2010, 10:04 AM
jsmiddleton4
1997 XJ Cherokee
There are several threads on this by the way.
I found the Autolite 3924's to be quite satisfactory and when on sale at Autozone I pick them up for about a buck a piece.
jsmiddleton4 is offline
post #11 of 16 Old 02-18-2010, 10:27 AM
My1989Jeep
1989 XJ Cherokee
I got some Split Fire plugs for $1.50 each at autozone they work pretty good.
Autozone Part Numbers:
NGK = 3248
Bosch Copper = 7927
Champion Copper = 344
Splitfire Copper = CC392D
1st 1989 Jeep Cherokee Laredo. 4 Door. Automatic. 4.0L Straight Six.
My1989Jeep is offline
post #12 of 16 Old 02-18-2010, 10:36 AM
mxboarder17
He's new to this give him a break.
Life is Good!
post #13 of 16 Old 02-18-2010, 11:10 AM
rustyoljeep97
1997 XJ Cherokee
I'm running the autolite platinum plugs. The plugs have given my 4.0 a lil more power under acceleration. I was running regular autolite plugs before they all overheated causing my no spark problem.
rustyoljeep97 is offline
post #14 of 16 Old 02-18-2010, 01:56 PM
BigD 275
I currently run the E3 plugs in my Jeep. Over a year and no issues whatsoever.
Over the years I have used Champion, NGK, Autolite, etc. No real difference in any of them (at least that has been my experience).
99 Jeep Cherokee Limited
BigD 275 is offline
post #15 of 16 Old 03-15-2012, 03:47 PM
JVR6109
1997 XJ Cherokee
I've had copper Champions in my '96 sport with the 4.0L for the past year and a half. Engine runs perfect with no hesitation and pretty decent pick up. I'm satisfied. And they were cheap as *****!
JVR6109 is offline
2001 Cherokee Sport spark plugs archygyrl XJ Cherokee Technical Forum 43 01-18-2017 04:48 PM
How To Replace Spark Plugs On 1996 Cherokee Sport? wick001 XJ Cherokee Technical Forum 15 11-12-2013 08:12 PM
What spark plugs do you recommend for 2000 Cherokee Sport ayeroff XJ Cherokee Technical Forum 3 07-07-2008 05:36 PM
Need good spark plugs for my 2000 Cherokee Jenniegirl XJ Cherokee Technical Forum 14 02-14-2006 08:24 PM
2000 Cherokee Spark Plugs BTK681 XJ Cherokee Technical Forum 5 09-25-2003 11:29 AM
