so they say.. - Page 2 - JeepForum.com
post #16 of 37 Old 09-05-2013, 05:16 PM Thread Starter
AM92
1992 XJ Cherokee
Originally Posted by Tom95YJ View Post
I run 3.75 you wont have any issues with 3.75 or 4"
I think I'll run that by 15x8 rims
AM92 is offline
post #17 of 37 Old 09-05-2013, 05:18 PM Thread Starter
AM92
1992 XJ Cherokee
Want to have an aggressive look
AM92 is offline
post #18 of 37 Old 09-05-2013, 06:28 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Mine are 15x8's also
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #19 of 37 Old 09-10-2013, 06:05 PM Thread Starter
AM92
1992 XJ Cherokee
AM92 is offline
post #20 of 37 Old 09-11-2013, 09:23 AM
psychoteen101
Good choice in wheel. They look good and are fairly cheap. I have them in 15x10. And if you wanted to get into some serious offroading, they are very easy to convert to beadlocks.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #21 of 37 Old 09-11-2013, 12:05 PM Thread Starter
AM92
1992 XJ Cherokee
how would those rims convert to beadlocks?
AM92 is offline
post #22 of 37 Old 09-11-2013, 12:10 PM
Timo_90xj
Timo_90xj's Avatar
Basically any steel wheel converts to beadlocks very easily: get precut weld-on 15" (or whatever you wheel diameter is) beadlocks, burn in, install tires, bolt in beadlock outer ring, you're done.
For example these, or any other similar:
http://www.ballisticfabrication.com/...ck_p_1589.html
***Under construction***
Timo_90xj is offline
post #23 of 37 Old 09-13-2013, 03:46 PM
psychoteen101
Google DIY beadlocks and youll get a few companies that make them. If you know how to mig weld, its very easy to install. A set will cost around $225 +shipping, got mine from diybeadlocks.com. The only issue with them is i doubt they are very streetable. I have them on my cherokee which is strictly a trail rig, so i have not attempted to balance them. Im assuming they will be near impossible to get right. Dyna beads may help, but i dont know how much. In any sense, on a trail rig, these things are a great mod to have. Even with the cost of the locks and wheels, its still cheaper than buying a set of bead lock wheels and they work just as well.
post #24 of 37 Old 09-13-2013, 03:48 PM
psychoteen101
And the cost of hardware if not included. I bought grade 5 nuts, bolts, lock and flat washers in bulk from napa. Cost me about $150
post #25 of 37 Old 09-13-2013, 03:54 PM
krawler510
I had to pound the heck out of the inside of the wheel well to make 33x12.5 hankooks work. And trimmed and 3" bump stop and it still just barely nicks the fender.
I'm mostly worried that the tires will rip the brake lines off the frame when turning/flexed up.
4.5" lift btw
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #26 of 37 Old 09-17-2013, 04:26 PM Thread Starter
AM92
1992 XJ Cherokee
4.5" lift btw
What's the backspace on your wheels?
AM92 is offline
post #27 of 37 Old 09-17-2013, 04:52 PM
krawler510
-19 offset so 3.75"?
post #28 of 37 Old 09-17-2013, 05:06 PM Thread Starter
AM92
1992 XJ Cherokee
And you still rub at 4.5?
AM92 is offline
post #29 of 37 Old 09-17-2013, 05:07 PM Thread Starter
AM92
1992 XJ Cherokee
Do you have stock brakelines?
AM92 is offline
post #30 of 37 Old 09-17-2013, 05:44 PM
krawler510
No, they're extended. I haven't fully tested but it looks like the tire can get dangerously close to the hard line. But I could be wrong.
The tires hit the fender liners while turning on flat ground so I ripped them out. They hit all over inside the wheel well with the sway bar unhooked, hence me cutting and bending all the pinch seams and cutting the fenders. Still a tight fit when fully stuffed as you can see.
The rear has plenty of room so far.
I had to take this from totally stock to its present form in 3 weeks so testing wasn't much of an option until now.
cherokee , lift , xj
