so they say.. - JeepForum.com
post #1 of 37 Old 08-27-2013, 06:48 PM Thread Starter
AM92
1992 XJ Cherokee
so they say..
build it right build it the first time,I have been doing endless research for my cherokee and have configured out this setup if anyone can tell me what they like or don't like about it let me know!!
so from re,iro,rc,clayton,bds, all have their bads and goods I came across this kit
http://dpgoffroad.com/products/44-5-...mu-hybrid-kit/
originally I was going to do 6.5" and 35s
changed my mind decided to save some cash and go with a 4.5" and 33s rancho adjustable shocks ,sye from teraflex,highsteer,33s hankook dynapros rt03
my rear is already swapped for the 8.8 regeared 4:56s with lsd
let me know what you guys think I'm curious to see what people who are riding this setup have to say!
AM92 is offline
post #2 of 37 Old 08-27-2013, 07:24 PM
cbenez1
Looks like a decent list of goodies except for the missing SYE.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #3 of 37 Old 08-27-2013, 07:39 PM
cmoore
cmoore's Avatar
Builds are use specific. It's hard to comment on how "right" a build is without knowing where/what you're planning to do with it. Looks like a thoughtful setup though and it would be a fun setup to run around the PNW.
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline
post #4 of 37 Old 08-27-2013, 08:30 PM
sAe23
1995 XJ Cherokee
33" (by what width??) tires will be a tight fit under a 4.5" lift.
At 4.5" / 5" you shouldn't need to go high steer, and you left out the shackle relocation brackets (jeez, you'd think I owned stock for all I've been suggesting these!), but they'll increase your lift by up to 2" and they'll change your pinion angle.
And I know OME is highly regarded but $2000?!?!? Ouch!
P.S. There is ALWAYS going to be something you'll want to change, so there is no such thing as doing it right the first time
Just
Empty
Every
Pocket
sAe23 is offline
post #5 of 37 Old 08-27-2013, 09:50 PM Thread Starter
AM92
1992 XJ Cherokee
Just
Empty
Every
Pocket
Haha 33 by 10.5 and for shackles I was thinking 1.5" 0r 2"
I think that j.e.e.p is a quote everyone lives by if you own one
AM92 is offline
post #6 of 37 Old 08-27-2013, 10:23 PM Thread Starter
AM92
1992 XJ Cherokee
I heard tera flex was good but there is one sye Kit on iro it's like super short sye for np231 not sure if I need that one or not seems like it's aimed for wrangler or tjs
AM92 is offline
post #7 of 37 Old 08-27-2013, 11:00 PM
Timo_90xj
Timo_90xj's Avatar
Although high steer isn't necessarily needed, I highly recommend going for it. It'll keep your steering angles a lot better, and it'll save you from all the trouble hitting the tierod on the rocks and tree stumps all the time. Stock steering is crappy anyways, so it needs to be addressed.
33s are NOT a tight fit on 4.5" lift by no means, unless for some reason you don't like to trim fenders. 35 x 12.50s fit pretty easily under 3-4" of lift with trimming and proper bumpstopping (and yes, you will have around 4" uptravel with that kind of setup). 33 , 10.50s will work perfect. I suggest to adjust CA lengths slightly longer than recommended by around 1". Depends on your overall setup though.
As was mentioned, shackle relocation brackets and a SYE + double joint driveshaft are more than likely required.
***Under construction***
Timo_90xj is offline
post #8 of 37 Old 08-27-2013, 11:18 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Couldn't Agree more.
I am running a 3.5" Rubicon Express/Teraflex Hybrid with 33x10.50's
Mine works great
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 37 Old 08-27-2013, 11:25 PM Thread Starter
AM92
1992 XJ Cherokee
Thanks for all the feed back guys I would run 35s but I would have to to add cost of new rims and tires and the only skinnys are 35 9.5 by interco although they run by a different name name q something..
I would prefer more uptravel 33s are perfect
AM92 is offline
post #10 of 37 Old 09-05-2013, 11:04 AM Thread Starter
AM92
1992 XJ Cherokee
What do you guys think 33s 12.5 3.25 bs or 3.75
AM92 is offline
post #11 of 37 Old 09-05-2013, 12:57 PM
psychoteen101
Still have the dana30 in front? Any locker or LSD like the rear? If so, you might want to think about upgrading the axles if you havent already. on 33"+ tires, once you start getting into serious wheeling, you might run into problems. More so with the U-joint ears warping then the u joint caps fall out or become loose. After that happens, theres no real fix to that other than replacing the axle. If you dont want to spend the money on aftermarkt axles, look into Almost Alloy. I run them on my dana 30, 33's with an eaton tru trac lsd.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #12 of 37 Old 09-05-2013, 01:16 PM Thread Starter
AM92
1992 XJ Cherokee
8.8lsd 4.56s rear and regearing front as well going with tru trac dana 30 hp
AM92 is offline
post #13 of 37 Old 09-05-2013, 03:21 PM
psychoteen101
yea then definitely upgrade the axles
post #14 of 37 Old 09-05-2013, 04:33 PM Thread Starter
AM92
1992 XJ Cherokee
What about the backspacing? 3.25 or 3.75
AM92 is offline
post #15 of 37 Old 09-05-2013, 06:00 PM
Tom95YJ
Tom95YJ's Avatar
I run 3.75 you wont have any issues with 3.75 or 4"
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
cherokee , lift , xj
