So much cooling - JeepForum.com
post #1 of 5 Old 11-04-2013, 02:41 PM Thread Starter
VicOfAges
So much cooling
I was poking around near the grill and noticed that I have a radiator and two other systems hooked up behind the grill which I'm unfamiliar with (but should be). Anyone mind IDing these?
Right side
Left side
VicOfAges is offline
post #2 of 5 Old 11-04-2013, 03:19 PM
mschi772
1997 XJ Cherokee
Green = radiator
Red = Air conditioning condenser
Yellow = likely an auxiliary transmission cooler (you probably have a towing package?); follow the lines to confirm (could be an oil cooler but HIGHLY unlikely)
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #3 of 5 Old 11-04-2013, 04:17 PM Thread Starter
VicOfAges
Much appreciated, thanks.
That's what I thought re: yellow, but I couldn't find signs of a towing package in the factory build sheet. This used to be a gov't Jeep and it did come with a class II hitch when I bought it, so it makes sense that they would've set it up properly. I also thought to look underneath and follow those lines but the late hour and skid plate led me here for now.
Sales Code Description
*J5 Cloth/Vinyl High-Back Bucket Seats
ADL Skid Plate Group
APAS Monotone Paint
ARUP SE Decor Group
BAUS 117 Amp Alternator
BCDS 500 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CADP High Back Bucket Seats
CBWS Highline Door Trim Panel
CDBP Reclining Front Seats
CFMS Rear Folding Seat
CGTS Driver Air Bag Only
CKAS Carpets - Floor and Cargo Area
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CKXS Midgate Box Access
CSRS Passenger Assist Handles
CUMS Mini Floor Console
DGB All 4-Speed Automatic Transmissions
DGSS 4-Speed Automatic AW4 Transmission
DHAS Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DHSS Floor Mount Automatic Shift Lever
DJHS 230MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRMP Dana 35C/194MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
ERH 4.0L I6 Power Tech Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEDS Tinted Rr Drs/Qtr/Liftgate Glass
GEHS Fixed Door Vent Glass
GR1P Left Remote Mirror
GS1P Right Remote Manual Mirror
GT1S Black Mirrors
GVAC All Vehicles W/O Power Mirrors
HAA Air Conditioning
JAZS Analog Instrument Cluster
JBFS Instrument Panel Black Bezel
JCAS 85 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
LAJS Headlamps On Warning Chimes
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LPSS CHMSL Lamp
MB1S Black Front Bumper
MB5S Black Rear Bumper
MDAP Front License Plate Bracket
MFFS Black Grille
MHAS Black Windshield Moldings
MMCS Rear Qtr Solid Window Insert
MMGS Belt Moldings
MMKS Hi Black Gloss/Black Mirror Molding
MNAS Black Door Handles
MUKS MOPAR Chrome Bodyside Molding
NAE California Emissions
NBKS EVAP Control System
NFAS 20 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NMC Heavy Duty Engine Cooling
PW1 Stone White Clear Coat
QW1S Stone White C/C
RAAC All Radio Equipped Vehicles
RABS AM/FM Radio
RCBS 2 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
TBB Full Size Spare Tire
TBLS Inside Mounted Spare Tire
TRN P225/75R15 OWL Wrangler AT Tires
TZAP Goodyear Brand Tires
WJDS 15X7.0 Styled Steel Wheels
WKDP 17" Aluminum Spare Wheel
WLYC All Steel Wheels
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
XWC Warranty Registration Card-Govt Bid
YAAS Build To U.S. Mkt. Specifications
post #4 of 5 Old 11-04-2013, 10:15 PM
holysirsalad
Cool, skids and a limited slip.
NHBP is the transmission cooler.
holysirsalad is offline
post #5 of 5 Old 11-05-2013, 11:30 AM Thread Starter
VicOfAges
Holy crap. I'm blind as a bat (or just like coming here to ask you guys questions).
