So.. liking that K&N filter? - JeepForum.com
post #1 of 13 Old 04-29-2012, 10:03 PM Thread Starter
Azzy
Thought this was the case when i started going though more and more oil in the Saturn, it coming out dirtier and using more of it... after going K&N
http://www.bobistheoilguy.com/airfilter/airtest1.htm
and
http://www.bobistheoilguy.com/airfilter/airtest3.htm
Found this test after looking for some info on some of the cone filters out there. I am tentatively thinking going cone filter and doing a cowl snorkel, but I will have to find a paper filter first, because one of those wont cut it here. Heck, I dont wash the car anymore because how dusty our road is (gravel and oil). Couldn't imagine what that would do to the cylinders... and for not much gain.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #2 of 13 Old 04-30-2012, 02:30 AM
DullesJeep
1995 XJ Cherokee
I recently went with a THOR cowl intake air filter system. Mainly because K&N filters don't do all too great of a job, and because the location of the K&N FIPK filter I had was terrible. I was always afraid of sucking up water with the placement of that thing. I haven't driven enough to really take a good look at the filter on the THOR kit yet, but I hear the filter it comes with (green filter) is an improvement over K&N's cone filter. Regardless, I killed 3 birds with one stone with the THOR kit: Actually introducing fresh, cooler air into the intake, Improved location of air intake, and removal of the questionable K&N filter. Plus it was a fun and easy install to boot!
It's a Jeep thing. Sometimes I don't even understand.
DullesJeep is offline
post #3 of 13 Old 04-30-2012, 07:25 AM Thread Starter
Azzy
Is the thor filter paper or oiled cloth?
Azzy is offline
post #4 of 13 Old 04-30-2012, 10:03 PM
joe108
K&N filters are crap, when I had one on my TJ there was a very fine coating of dust inside the tube, I'm sure the inside of my cylinders and pistons got that fine grit too.
I would just stay with stock paper filters, filters air better and when they get dirty you throw it away. Also no milage gains as claimed by k&n, just my 2cts.
joe108 is offline
post #5 of 13 Old 04-30-2012, 10:51 PM
XJ-JekL
1995 XJ Cherokee
Hmmmm, who would've thought? OME parts seem to do the best, while the Autozone special came in, well, not first.
XJ-JekL is offline
post #6 of 13 Old 04-30-2012, 11:44 PM
DullesJeep
1995 XJ Cherokee
Oiled cloth.
post #7 of 13 Old 05-01-2012, 08:41 AM
PR1AWRet
2002 KJ Liberty
Nice test, but I think needs more testing done maybe at 2k, 5k, 7.5K, and 10K to see the difference for airflow and filtration.
PR1AWRet is offline
post #8 of 13 Old 05-01-2012, 09:04 AM Thread Starter
Azzy
I think it would be nice to see more testing as well, but moving more air will always equal moving more grit along with it.
It wont start magically filtering at 7K
Azzy is offline
post #9 of 13 Old 05-01-2012, 09:21 AM
PR1AWRet
2002 KJ Liberty
Apples to apples, it would be neat to see a test done for the entire life of 1 engine using 1 brand filter, breaking the engine down and measure the wear and do this with as many different filters, oil included. A controlled test per se. With the 4.0 they can go 250K to 300K if properly maintained using any quality air/oil filters.
Just my $.02.
PR1AWRet is offline
post #10 of 13 Old 05-01-2012, 10:16 AM
wsar10
2003 WJ
there's no "real" need to run a test for the life of an engine, or 10k to see the results.
UOA's don't lie and you could see the elevated metals content from wear along with a higher silicon and insoluble's count.
I learned the downside of K&N's a few years ago, and switched every air filter to an AMSOIL filter.
It was a hard pill to swallow since every motor I've ever owned I put a K&N on it..........
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #11 of 13 Old 05-01-2012, 10:40 AM
jeepkid03
Winning
jeepkid03's Avatar
I agree. UOAs don't lie. I have experienced first hand the dust in my intake when I used a K&N. I think what bothers me the most is the price. Very expensive for a crappy filter that maybe adds 5 hp at the most. I doubt you will notice 5 hp on a 4.0L.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #12 of 13 Old 05-01-2012, 11:46 AM
DerMeister
I came to the same conclusion, I ran a spectre air filter that fit in the stock box. It is exactly like a K&N for 1/3 the price. One day the thin metal name tag that was on the filter got sucked into my TB and caused it to be stuck open at 70mph.
Anyway, I ditched it after that, but when dis-lodging the metal strip I noticed dust all over everything past the air filter. I had it for a year, and didn't maintain it however. No power or mpg gain was noticed either.
$4 for a Fram works better.
DerMeister is offline
post #13 of 13 Old 05-01-2012, 05:44 PM
DullesJeep
1995 XJ Cherokee
I remember reading your thread on that back before I was even a member here.
Changing Air filter with performance filter vecky4858 XJ Cherokee Technical Forum 2 05-08-2009 09:39 PM
Fuel Filter 99 4.0 Cherokee?? 159.98 for the filter alone? Mike94ZLT1 XJ Cherokee Technical Forum 24 05-07-2007 05:04 PM
Oil and Oil Filter JeepFreak91 XJ Cherokee Technical Forum 18 08-29-2006 08:40 PM
Update: Cone Filter VS Drop in Filter ..... trailblaze XJ Cherokee Technical Forum 4 07-08-2006 12:55 PM
which oil filter???? marcocor XJ Cherokee Technical Forum 34 07-08-2006 06:20 AM
