Snorkel practicality? - Page 2 - JeepForum.com
post #16 of 51 Old 05-07-2013, 05:41 AM
Kettles
Originally Posted by Muddy97Cherokee View Post
I think go for a real snorkel. I don't like the cowl intakes everybody does. For one, there's a better chance of water going over the hood and into the cowl than actually into the airbox. Now if you are going slow through deep puddles that are up over you engine with a cowl intake, then you are just stupid. Expect faulty electrical items if you do. Another thing I would like to point out is if your tires are out past your fenders, your snorkel is not going to get ripped off on trails. They are not any wider than the stock flares on a jeep. I go down trails that are meant for ATV's at a local park and have never had a flare taken off, only rubbed up against. Never have I had anything torn off my jeep because of a tight trail. The snorkel is also a true cold air intake system. The cowl still gets hot and you will still be sucking in hot air. Don't let anybody tell you that cold air means nothing. The cold air allows more oxygen into the engine since cold air is more dense than hot air. Just my $.02 about this whole cowl, snorkel controversy.
My $.02 on that, while I have not checked my intake temperature (maybe ill do it on the way to work today), I have felt the ducting to my intake from my cowl snorkel and it is cool to the touch when running. Even with the air filter sitting on the valve cover. I would imagine it is a fairly effective cold air source.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is online now
post #17 of 51 Old 05-07-2013, 10:14 AM
Kevin108
Think about how a radiator works. Something metal has air blown across it to keep it cool.
Sound like any part being discussed here might work similarly?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #18 of 51 Old 05-07-2013, 08:59 PM
motorsports3
1997 XJ Cherokee
I would go snorkel. Down in FL I have seen first hand a Cowl intake fail, and never a properly installed snorkel. Plus you can get snorkels so cheap now a days that it almost doesnt make sense to do a cowl, unless you are afraid of the hole.
motorsports3 is offline
post #19 of 51 Old 05-08-2013, 08:50 PM
PhilipJ
PhilipJ's Avatar
Well properly installed things probably shouldn't fail now, should they?
Unless you really intend on regularly driving through water that is going to be going over the hood (thereby ruining your interior and maybe anything electrical you haven't waterproofed anyway) there's no significant advantage to a snorkel over a cowl.
PhilipJ is online now
post #20 of 51 Old 05-08-2013, 09:38 PM
Muddy97Cherokee
1997 XJ Cherokee
Again, I still say a snorkel is more practicable. Thought I'd chime in again. I run the river in my area often and I can't tell you how many times I have had water come over the hood. I'll post the pics I got when I was stuck. In that occurrence water came up over the hood when I entered the bottom of the river. After I got pulled out and made sure I didn't suck in any water, I checked the cowl because I was going to do a cowl intake. It turned up being pretty soaked with water. That was the point where I got deterred from the cowl intake set up. Not only have I had water over my hood at that river, I also ride trails that have some high water crossings that cause water to go over the hood. If you have momentum in moving water, it will not rush in the doors nor flood the engine bay completely.
549223_612675522082691_556619917_n.jpg   526486_612675555416021_1732712552_n.jpg   285385_612675585416018_1329417795_n.jpg
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #21 of 51 Old 05-08-2013, 09:48 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I had a ARB Safari Snorkel on my YJ it saved me from Hydrolocking when I went in a small hole at the Pine Barrens . I mainly play on rocks now out west and of all the trails I go on there is only 1 water crossing which is rarely over 20" deep .
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #22 of 51 Old 05-08-2013, 10:59 PM
Kevin108
The cowl snorkel failed or the mounting height was insufficient for the depth of the water the driver went into?
Kevin108 is offline
post #23 of 51 Old 05-09-2013, 04:02 AM
DNFJ
You can only mount a cowl so high, the access to the cowl isn't all that big.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #24 of 51 Old 05-09-2013, 10:47 PM
motorsports3
1997 XJ Cherokee
Remember that I live in Miami and deep water crossings are the norm. But it has enough water splash in that the cowl area filled with water and made its way into the hose.
post #25 of 51 Old 05-10-2013, 08:24 AM
BigBadWuf
1992 XJ Cherokee
Not if you run it into the cowl, then straightup like a H1.
They have the deepest fording depth of any stock vehicle. So they only way you could swamp it is either water above the hood, or a leak.
BigBadWuf is offline
post #26 of 51 Old 05-10-2013, 09:57 AM
DNFJ
An H1 and an XJ are not the same.
Previous:
DNFJ is offline
post #27 of 51 Old 05-10-2013, 10:22 AM
Motorcharge
Can't see what year you have but pre 97 you could run it through the cowl into the cab up through the roof with a roof scoop. Full snorkel functionality without worrying about it hitting anything and getting ripped off.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #28 of 51 Old 05-10-2013, 10:33 AM
DNFJ
Curious as to how you would run it from the cowl to the roof.
Previous:
DNFJ is offline
post #29 of 51 Old 05-10-2013, 10:36 AM
Project1
I lost a motor to not having a snorkel once .. I wont do that again .. Cowl snorkel at the VERY least
Project1 is offline
post #30 of 51 Old 05-10-2013, 10:40 AM
Motorcharge
Through the firewall and eliminate the glove box.
|SOLD|
| June 2015 COTM |
