Slipping 1st gear AW4 - JeepForum.com
post #1 of 10 Old 04-02-2012, 05:51 AM Thread Starter
Hamid
2015 WK
When cold with the lever on D, my 2000 Cherokee drives for few seconds in the 1st gear then disengages, with a little acceleration it re-engages and shifts up normally.
It works fine in all speed ranges and normal acceleration.
The problem is at low speeds when trying to accelerate it slips few seconds just when I press on the pad, then re-engages in a high RPM but with a bang you don't like to feel, it may break a gear in the tranny after so many times.
On a steep hill or incline, it slips badly, looks like the oil doesn't reach some parts of the gearbox or the valve body even the level is OK.
I guess it is the #1 solenoid not working well, need your help in this issue, any comments will be greatly appreciated, .thanks.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #2 of 10 Old 04-02-2012, 07:17 AM
VBRubicon
VBRubicon's Avatar
Fluid level is good? If it is I would drop the pan and change the filter. Start with the simple things.
"Yeah well, that's just like...your opinion, man."
-El Duderino-
Mr. Madison, what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
VBRubicon is offline
post #3 of 10 Old 04-03-2012, 12:10 AM Thread Starter
Hamid
2015 WK
Good idea VBRubicon, but I changed the fluid with the filter at 102.5K miles 27Nov2010 (Mopar AFT +4), current mileage 123K. Next oil change at 132K.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #4 of 10 Old 04-03-2012, 04:22 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
ATF+4 is not the recommended fluid FWIW.
Not saying that's the problem. Did you have the problem before the last fluid change?
cruiser54 is online now
post #5 of 10 Old 04-03-2012, 09:09 AM Thread Starter
Hamid
2015 WK
Yes, and what is the correct fluid you recommend. Thanks.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #6 of 10 Old 04-03-2012, 04:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Dexron III/Mercon.
post #7 of 10 Old 04-04-2012, 12:25 AM Thread Starter
Hamid
2015 WK
The owner manual says DexronII !!!!
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #8 of 10 Old 04-04-2012, 05:11 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
They don't make it anymore and it's superceded by III.
post #9 of 10 Old 04-04-2012, 06:27 AM Thread Starter
Hamid
2015 WK
I will see if this type fluid is available around, is there an alternative?. Thanks.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #10 of 10 Old 06-13-2013, 09:21 PM Thread Starter
Hamid
2015 WK
I finally have tow choices after reading and searching all about AW4 slipping in 1st gear:
1- replace all 3 solenoids at the valve body. cost $109 for parts and I will do the work.
2- overhaul the tranny. cost $922
I wish someone can guide me to the correct decision. Thanks.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
AW4 slipping in 1st gear Hamid XJ Cherokee Technical Forum 8 03-16-2014 02:44 PM
New old XJ Cherokee slipping outa gear? Maxhog650 XJ Cherokee Technical Forum 8 09-11-2011 07:36 PM
Transmission issue, slipping out of gear. Garef XJ Cherokee Technical Forum 0 10-14-2009 06:38 PM
1st gear slipping??? smlducks XJ Cherokee Technical Forum 28 08-18-2009 09:48 AM
Transmission slipping in first gear when warm zoomin0074 XJ Cherokee Technical Forum 2 07-06-2008 06:04 PM
