Should I bother with jeeps? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Should I bother with jeeps?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-12-2015, 11:31 AM   #1
BenRalphy
My friend wants me to install a 2" lift spacer kit on his xj, but from what I've seen, everyone breaks a **** ton of bolts on the install. I'm a watercooled Volkswagen guy, so I never have to deal with rust. I live in Virginia, and he says the car has some rust. My question is should I even bother with it, and what should I look out for? Finally can someone lead me to a good diy? And yes, I know I'm a lazy piece of **** for not using the search tool; you don't need to remind me of that.
Last edited by chris87xj; 03-12-2015 at 04:13 PM.. Reason: please do not bypass the forum language censor
BenRalphy is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 11:33 AM   #2
BenRalphy
My friend wants me to install a 2" lift spacer kit on his xj, but from what I've seen, everyone breaks a **** ton of bolts on the install. I'm a watercooled Volkswagen guy, so I never have to deal with rust. I live in Virginia, and he says the car has some rust. My question is should I even bother with it, and what should I look out for? Finally can someone lead me to a good diy guide? And yes, I know I'm a lazy piece of **** for not using the search tool; you don't need to remind me of that.
Last edited by chris87xj; 03-12-2015 at 04:17 PM.. Reason: please do not bypass the forum language censor or create duplicate threads
Unread 03-12-2015, 11:48 AM   #3
indeepwithajeep
Mainly the trouble bolts are the leaf spring bolts and the rear upper shock bolts. Soak them days in advance. You can get to the leaf spring bolt threads from small access holes on the uniframe. I guess it'd be worth while if he needs shocks and really wants that lift. If he has a 97+ w/ a 242 transfercase (has both full time and part time 4x4) I wouldn't bother with it.
indeepwithajeep is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 12:12 PM   #4
sAe23
1995 XJ Cherokee
If you are a TRUE friend, you'll help no matter the condition
Spray all the nuts and bolts with your favorite penetrating fluid (PBlaster, WD40, Acetone/AFT homebrew, et.c.) everyday for a WEEK before attempting to work on the Jeep.
Have a source of heat available too if it comes down to it (just be sure any of those fluids have evaporated!!).
Use lots of "gentle persuasion"
YouTube probably has lots of videos on something like this.
And rust has nothing to do with how the vehicle's engine is cooled :/
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 12:18 PM   #5
BenRalphy
No, it's not that. Aircooled vw's have rust issues.
Unread 03-12-2015, 01:08 PM   #6
jonsnw93
Alright lets be fair aircooled Volkswagens are normally 40 years old so unless you get one of the later ones there is going to be rust. I know because I own a 74 that I will do anything for
jonsnw93 is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 03:09 PM   #7
FairlanePhil
No.
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 03:27 PM   #8
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
The real question, IMO, is why your friend wants someone that doesn't know his *** from his elbows, when it comes to Jeeps, to install a spacer kit on his Jeep.
The next question is how much is your friend offering you for the install?
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 02:40 AM   #9
Jameslol
So do mk3's lol.
Spacer kits are easy, honestly jeeps are way easier to work on then a vr6 or something low. If youre competent with suspension work, and can use a grinder for the leaf springs, and probably the upper strut mounts in the rear, you'll be fine.
Black 1996 Jeep Cherokee Sport, 4.0, 4WD, NP231.
31 inch Yokohama Geolanders.
3" Rough Country AAL Kit. ZJ tierod.
C4x4 Front tow hooks.
Nates 4x4 rear bumper w/receiver and shackles
Iron rock offroad double shear adj trackbar
Jameslol is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 09:48 AM   #10
BenRalphy
Chipotle.
He also said when I told him to buy some pb blaster, and spray the **** out of the bolts, was that he was too poor; Soooo, it doesn't make sense how he can pay for chipotle.
Unread 03-13-2015, 09:49 AM   #11
BenRalphy
Yeah, his car looks like a tractor compared to my 1.8t.
Unread 03-13-2015, 06:38 PM   #12
TidbitWJ
2003 WJ
I can drink your displacement in 45 minutes Benny. Jeeps. All. The. Way.
2003 Grand Cherokee - I6 4.0
TidbitWJ is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 06:42 PM   #13
billiebob
Well said !!
of all the things you can do to a Jeep installing a BB has to be the definition of "do it yourself"
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 02:18 PM   #14
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Chipotle.
If your friend is too poor to afford a few can of PB Blaster than he's got no business with aftermarket suspension setups on his Jeep.
- Justin
1992 Cherokee Laredo - all stock, DD. Needs some minor rust repair, then on to the mods!
1996 Cherokee Classic - 3.5" lift / 31.0x10.5 Mastercraft Courser CTs / Warn XD9000i - Stripped for parts / junked :(
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
NJ F-Body Owners Association
Tru2Chevy is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 08:11 PM   #15
FISTFULL
Home depot is running a sale on PB Blaster with a can of their general purpose spray lube for under $5 right now.
99 Sport, 3.5" RE front coils and Quadratech HD rear leafs with RE AAL, Rusty's shocks. RE HD ADJ Track Bar. RE Hack n Tap SYE. 32"Falken Mountain Peak AT's on 15x8 (4.5"bs) procomp rockcrawlers. YJ Front Brake Lines. 2.5" IRO catback with Magnaflow cat. C4x4 Tow Hooks. Rear Diff Guard. Warn Front Diff Guard and TC Skid. Yakima rack. Mega Warrior Safari Rack. Cobra CB. AJ's Rocker Guards. JCR Stage 1 rear bumper. JCR Stage 4 front bumper. ORE front steering box brace.
FISTFULL is online now   Reply With Quote Quick reply to this message
